Question about TruTech TT320
Cannot shut off progressive scan on Samsung DVD-VR357
  • 2 more comments
  • kcyl Sep 15, 2008
    cannot shut off progressive scan when a dvd is playing.
  • Anonymous Dec 07, 2008
    with progressive on no picture
  • Anonymous Dec 09, 2008
    I accidently put my Philips DVDR615 into progressive scan mode. I have no picture to get it back. How can I put it back to a normal mode.
  • bart4455 Jan 08, 2009
    i just put my dvd player on p-scan and it just says it across my screen i dont know how 2 get rid of it any help?
Some dvd's have a switch on the back to take it out of progressive scan, its usually very small and had to spot if it exists.
This is what I found that works, this is what you need:
* 1 single rca-to-rca cable
I'm assuming you are using the Svideo or component cable(s) for your video to
your receiver or to your tv.
For me, I have game hookup on the front of my tv, so it was really quick.
Just connect the "video out" from the back of the dvd to the video in some other input
(so you don't have to disconnect the svideo or component cables)
Switch to the *other* output on your tv using the tv/video button or something.
That should get you to be able to see the setup menu.
Once you get there... write down the 'remote' keypad sequence in the manual or something so that you can do it blind without getting up from the couch.
Hope that works.
Posted on Jan 25, 2009
Progressive Scan
Try these steps:
Locate the output jacks DVD player. Sometimes they are standard female RCA A/V jacks, like those found on the front of many VCRs. Others are more tricky, having a small jack that looks like a stereo headphones plug. These camcorders require a special cord that converts a 1/8" stereo signal into RCA A/V male plugs.
  1. Using the proper cord, connect your PLAYER to the VCR's RCA A/V input jacks, usually found on the front or back of your VCR.
  2. Turn on your VCR and TV, so you can see the input from the camcorder. You might have to select "Input 1/2", "Line 1/2", or "VIDEO" depending on your VCR model. You should now see whatever is on your camcorder displayed on your television.
  3. Press "Record" on your VCR, then press "Play" on your camcorder. That's it!
Sep 07, 2008 | Samsung DVD-VR357
My samsung vr357 will not load a disc
The laser lens needs cleaning . You can try a DVD cleaning disk from Target or Walmart . If that doesnt work , the player will need to be opened and manually cleaned
Apr 20, 2010 | Samsung DVD-VR357
Samsung DVD VR357 when on DVD gives blank screen on TV, Works normal in VCR mode
hi there
please see that you vcr is on a.v channe or see your.r.c.a is plug in right hope it will will
Dec 19, 2009 | Samsung DVD-VR357
Vhs to dvd
Recording is disabled when the progressive scan mode is on. You have to reset the unit first.
Take out any disc or tape. With the unit on, hold down the Rewind and Fast Forward buttons together for 10 secs.
Then turn the unit off and on. It should work fine after that.
Jun 29, 2009 | Samsung DVD-VR357
I am trying to record to a blank dvd-r. I load a
If exact model is Samsung DVD-VR357, than it doesn't even has to recognise blank disc as your unit is DVD PLAYER with Video Casette Recorder.
See Specs. for your unit below:
Function Combination VCR Y Compatibility Playback Media DVD-R,DVD-RW,DVD+R,DVD+RW,CD-R/RW,CD,VHS, DVD-RAM Playback Formats MP3, WMA, JPEG, MPEG-4, DivX A/V Quality Progressive Scan Y HD Upconversion 720p/1080i Digital-to-Analog Converter 10-Bit/54MHz DTS Output Y Dolby Digital Surround Sound Y Connectivity HDMI CEC Y Convenience Child Protection Parental Control Physical Features Connectivity HDMI Output Y Component Video Output 1(Rear) S-Video Output 1(Rear) Composite Video Output 1(Rear) Coaxial Digital Audio Outputs 1(Rear) Optical Audio Output 1(Rear) Product Weight & Dimensions Dimension 16.9" x 3.1" x 11" Weight 8.8Lbs. Shipment Weight & Dimensions Dimension 20.2" x 7.1" x 15.1" Weight 12.1Lbs.
Closest model match for DVD recording unit would be DVD-VR375
Unfortunately you have player only and you won't be able to recor DVDs with it whatsoever.
Good luck
Jun 24, 2009 | Samsung DVD-VR357
Trying to find a setup code for the samsung dvd vr357
Try 0573, 0820, 1932, 0240, or 0045. I also have comcast but just use the remote that came with the recorder/player.You can control all the player functions as well as the up/down volume.
Jan 26, 2009 | Samsung DVD-VR357
How to record ?
I don't know a whole lot about electronic equipment, but I've never seen anything connected in so many ways at the same time. Maybe the antenna and one other type of connection. The different signals from all the connections are probably confusing each other. I would try one connection at a time to see if the problem improves. Good Luck.
Dec 16, 2007 | Samsung DVD-VR357
SD-K530SU - Turning Off Progressive Scan Mode
Once the setting for Progressive Scan output is entered,
an image will only be visible on a Progressive Scan compatible
TV or monitor. If you set Progressive Scan to On in
error, you must reset the unit. Pointing the remote at the
player, press the STOP (x) button to stop any disc that is
playing. Next, press the STOP (x) button again and hold it
for five seconds before releasing it. The video output will
be restored to the standard setting, and a picture will once
again be visible on a conventional analog TV or monitor.
Nov 06, 2007 | Insignia NS-DVDR1 DVD Recorder
TruTech TT320 Logo
133 people viewed this question
Top TruTech Televison & Video Experts
Jason Morris
Are you a TruTech Televison and Video Expert? Answer questions, earn points and help others
