Question about Cuisinart DLC-8S Pro Custom Food Processor
My cuisinart food processor has only been used twice, but the motor doesn't work. help
  • Anonymous Nov 27, 2008
    The cuisinart will not come on and I don't even hear power going into it. I ave checked the outlet with other appliances.
I don't feel like spending $$$ so that someone can tell me where to send the motor, or where to get a new one. Finally found a Cuisinart support phone nno on the bottom of the appliance and will try that tomorrow.
Posted on Aug 25, 2008
I have a Cuisinart DLC-8S TX Pro Custom 11 Cups Food Processor that I purchased in spring 2004 and used only sporadically. Last week, I burnt the motor by using it to make fondant. Big mistake. I take...
If you already have a lot of attachments for this model, I would purchase a used motor unit. I got a complete setup at a yard sale minus the work bowl cover for $3 as a spare, and often see them at thrift stores priced quite inexpensively. You could also check ebay. Motor units routinely go for less than $25 including shipping. I'm pretty sure most dcl-8 series motors will work with you bowl and attachments. I like the quality of the older units better than the newer ones. And if you watch ebay closely, you can pick up a lot of pieces really cheaply. Good Luck,
Marc
Oct 21, 2010 | Cuisinart DLC-8S Pro Custom Food Processor
I have a Cuisinart 14 cup food processor which will not turn on
Hi-
We have a Cuisinart and these tools are very rugged- so I doubt that the motor is bad. My only suggestion would be to make sure that the safety catch is being actuated when you click the cover clockwise to secure the mixing chamber. There is a hole in the housing that the acuator pin sticks into to disengage the safety switch. Perhaps the switch is not being pressed off.
Hope this helps,
Jeff
Oct 28, 2009 | Cuisinart DLC-7SFP Pro Food Processor
I have a small Cuisinart food processor and I cannot figure out how to turn it on. It has two levers low and high. I have it plugged in and the lid on? Please help. Fiona Slattery 858-752-8591
Your PowerBlend Duet™ comes with a food processor button. This button is the perfect speed for all your food processing tasks. Always use this speed when using the food processor. You may also use the Pulse button with this function for pulse-chopping.
To use your food processor, make sure that the bowl is assembled properly and the blade or slicing/shredding disc and the cover are locked into place.
When you use the control panel, the LED will light next to each button you press.
Press the On button. For continuous operation, press the Food Processor button. Motor will start if you have followed assembly instructions.
To turn motor off, press the Food Processor button again or the Off button.
For on/off operation, called pulse-chopping or pulsing, press the On button, press the Pulse button, and then press and release the
Food Processor button the desired number of times. Motor runs as long as you hold the Food Processor button down. The motor stops when you release control switch. Try it a few times.
You control the duration and frequency of pulses by the length of time you hold the Food Processor button down and the rate at which you press it. Pulses should be short bursts. Allow enough time between pulses to let food in work bowl fall to bottom.
Always use the Food Processor button for pulse/chopping. Never turn cover back and forth to start and stop processor.
You can download manual from the below link
http://www.cuisinart.com/share/pdf/manuals/bfp-10ch.pdf
ENJOY! RATE THIS SOLUTION
RNJ VINOD KUMAR
Sep 12, 2009 | Cuisinart Food Processors
Tried to use my powerprep pluss cuisinart food processor and nothing happens. The on button lights up but nothing happens when i press the pulse button.
Remove the work bowl from the base of the food processor, and separate the bowl, lid, and pusher sleeve.
Plug the base into the wall outlet, turn the food processor ON, and then use a pen to press in the dark grey or black button on top of the base of the food processor - if you hear some kind of noise, then your motor is still good.
Put the work bowl on first, with the handle facing the front of the food processor.
Put the lid on, with the lid lined up with the handle of the work bowl.
Put the pusher sleeve in the lid, with the metal piece facing the front of the processor.
Your processor should now turn on.
If it doesn't call Cuisinart and see if you are still in-warranty (3-year warranty).
-Tha Mp3 Doctor (also loves Cuisinart)
Mar 23, 2009 | Cuisinart DLC-2014 PowerPrep Plus Food...
Cuisinart Food Processor Custom 14 turned off
Cuisinart Food Processors – Motor Test
First, do a motor test by removing the work bowl completely and using a pen to press in the grey button on top of the base (with the food processor turned on of course), toward the back. If the processor spins, the motor is still good. At that point, I would inspect the work bowl pieces, lid, pusher assembly, etc for cracks/damage. If all appears well, insert ALL the pieces back into place and try again. If even one piece is out of place, the processor will not spin.
If it no longer spins, the motor has a problem.
-Tha Mp3 Doctor
Dec 21, 2008 | Cuisinart DFP-14BC Custom Food Processor
Motor won't turn on
You can test the motor by plugging the food processor in, pressing the on switch and using a pen to press the dark grey or black button on top of the base of the food processor. As long as it spins, the motor is definitely good. Next, unplug the food processor. For the food processor to work, you need to have the work bowl, lid, and pusher sleeve all inserted - if one part of the work bowl is not attached, then the food processor will not spin the blade. Once all three pieces have been inserted, plug it in and turn it on. If the blade is still not spinning, then there is a problem with the element that runs from the back of the pusher sleeve down through the work bowl that triggers the motor button. In that event, you can go to Cuisinart's website and order a new bowl, lid, and/or pusher sleeve - if you see any obvious damage to one part, you can order just that one part. If it is not apparent which part is damaged, order the whole work bowl. Make sure you enter your exact model# at Cuisinart's website, because a DLC-7 is not the same as a DLC-7E or 7P, for instance. The work bowl parts are expensive, so I would just write down the part numbers from Cuisinart's website and find them cheaper elsewhere. There is also a video on the website that shows you how to use the food processors - the first part of the video describes work bowl assembly. Once you get this food processor working, it is going to last forever. Have fun!
-Tha Mp3 Doctor
Nov 27, 2008 | Cuisinart DLC-8S Pro Custom Food Processor
My food processor turn on button won't work.
-Tha Mp3 Doctor
Nov 25, 2008 | Cuisinart DLC-5 Food Processor
I can't get my food processor (DLC-2007N) to start. It looks like everything is locked in place, and the light goes on, but the motor won't start.
Aug 31, 2008 | Cuisinart DLC-2007 7 Cups Food Processor
The cuisinart food processor doesn't work.
-Tha Mp3 Doctor
Aug 26, 2008 | Cuisinart DLC-8S Pro Custom Food Processor
Cuisinart MP14 Will Not Turn On
If it no longer spins, the motor has a problem. (This one has a 20-year motor warranty)
-Tha Mp3 Doctor
Oct 30, 2007 | Cuisinart Limited Edition Metal MP14 Food...
Cuisinart DLC-8S Pro Custom Food Processor Logo
120 people viewed this question
Top Cuisinart Food Processors Experts
Colin Stickland
Colin Stickland
Greg Cann
Greg Cann
Are you a Cuisinart Food Processor Expert? Answer questions, earn points and help others
