Question about Wabash Valley Farms Old Fashioned 4 Popcorn Maker
Air popt popcorn machines
I bought a big popcorn machine last week from a garage sale it runs and all the moters and heating elements seem to be working this popper you put the popcorn in on top as with the salt and butter it has no kettle but works off heat and convayors
Hello I have a 39s popcorn machine . I have power kettle spins but not get hot . anything I can do ?
It could be a bad switch, plug, thermostat or heating element. These items will need to be tested by a qualified electrician to determine which are faulty and causing the element not to heat up.
Dec 30, 2014 | Star 39S-A Stainless Steel JetPopcorn...
Gold Medal Deluxe Pinto Pop Popcorn Machine Model 2147 will not heat up
If the switch is OK and you have. Power at the kettle plug and you are not getting any heat it's one of 3 things. Burned wire inside the kettle. this is common. Or it could be the thermostat is bad or the element itself is out?
May 07, 2014 | Gold Medal Products Gold Medal 2147 120208...
Miele heating element
sorry - may seem odd - but your hot water tank is set to 120 or higher yes ? so why are you re-heating you water? - if you want to know you need the 2000w /230v - but really turn the re heat off - at 120 you kill the bacteria and will save $$
Mar 20, 2014 | Dishwashers
I bought a Presto Popcorn Now continuous popper at a garage sale. There were no instructions and the seller never learned how to use it, having recieved it as a "hand-down". I want to know how...
WAIT! Do not add any oil or butter. I don't know what kind of machine you have, but only POPCORN goes inside the Popcornnow. I have an old one that melts butter on the top cover, although I don't recommend that. I recommend butter in the microwave. Repeat: DO NOT ADD OIL where the popcorn goes or you will set a fire.
Jul 20, 2011 | Presto Kitchen Appliances - Others
I have a gm 2086 that was my aunts and does not seem like it was cleaned very much. I tired hot water and mild soap but its really not making much of a dent, is there any type of cleaner I can use on it?
That depends on which part you are cleaning. If you are trying to clean the heating element of the machine, do not attempt to use excessive force to remove the grim. It is normal to have a little brown coating on the heating element in popcorn machines.
However if you really desire, you should look for a stove or grill cleaner. They are usually a white fluid that you leave on, then scrub and remove. After that wash it with soap and water to remove the cleaner itself before using.
Mar 14, 2011 | Gold Medal 2086 Popcorn Maker
Instruction/User Manual
I just took over a position as Activiyies Director for a community association. Found the popcorn popper in the closet, no maual of course, I just cleaned it up, added kernals to metal cup & plugged it in. Within 3 minutes I had a huge bowl of fresh popcorn for the kids to enjoy. They love watching it pop. Only problem is finding the perfect way to season. Any suggestions???
Dec 12, 2008 | Kitchen Appliances - Others
Well pump
i bougth mini jet star popcorn machine in a garage sale but without instructions and i don´t know how to make the popcorn
Jun 22, 2008 | Kitchen Appliances - Others
Instruction Manual
I had the same problem. If you are in Australia, the Dimplex Customer Service number is 1300 6739 033. I phoned and they are mailing me the instructions. Maybe don't say you bought the machine at a garage sale.
If you are not in Australia, try the way I did to get your local customer service number - Google the product number and go to the Dimplex website, and there should be a "Contact Us' button with a phone number or mailing address.
Pat
Jun 21, 2008 | Heating & Cooling
Not popping the corn
Here is the link to the user manual for your machine; http://www.gopresto.com/downloads/instructions/04821.pdf If the kernels are not popping, then the heating element that heats the air is likely faulty and would need replacing - Check page 4 of the manual for service info Hope this helps :)
Feb 09, 2007 | Presto 04821 Orville Redenbacher's Popcorn...
Wabash Valley Farms Old Fashioned 4 Popcorn Maker Logo
202 people viewed this question
Top Wabash Valley Farms Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Are you a Wabash Valley Farms Kitchen Appliances - Other Expert? Answer questions, earn points and help others
