Question about NAD C162 Amplifier
C355Bee and C162 Problems
Used to have C355BEE, but it broke twice without any apparent reason. Would not turn green, maintained at amber. Dealer suggested to upgrade to C272/C162 combo. Played sweet music for 12 hours straight, turned off the system, following morning, same problem with the C355BEE... the LED's would not turn green anymore, maintained at amber... please help
my email: pacisam@yahoo.com
  • dindop Aug 24, 2008
    In addition to the above, the C272 power amp is still good, all LED's turn from amber to green. My C542 player also is good, no problem whatsoever. That's why i tend to rule out power supply issues.
    It seems the problem with the C355BEE integrated amp is also with the pre-amp part, based on the same symptoms i got with the C162.
Get your money back. I had similar problems with new NAD purchases a year or so back. NAD has had all sorts of repair issues.
I'll never buy anything from them again.
Posted on Jul 29, 2009
Input selection indicators off
little mini light bulbs are blowing, remove top cover, remove 1 bulb, take it to electronics store and get replacements for them all (I think there are 5) reinstall the new bulbs and the cover. good to go
Feb 03, 2014 | NAD C355BEE Amplifier
Schematic diagram
Try http://hifiengine.com/
Jan 04, 2014 | NAD C355BEE Amplifier
Schematic diagram
check the pcb mounted fuses on the power supply board They look like resistors only they have 1 colored stripe. replace the open (resistance above 1 ohm) fuse and enjoy your amp.
Nad c355bee
Check to see if it works with headphones. If it doesn't then you might have a main power amp failure.
Aug 06, 2013 | Audio Players & Recorders
My C355Bee amplifier will not switch on. The power light stays on orange and won't switch to green.
This is usually called "protect mode". See the link below for an explanation. If the unit remains in this condition even after disconnecting all speaker wires, it likely will require service. Please update this if you need further information.
Thanks,
Dan
Link: http://www.fixya.com/support/r5390728-protector_means
May 29, 2011 | NAD C355BEE Amplifier
Can I get the video off of my Sony Handycam DCR-40 without the docking station? It broke, so I want to know if I can connect it to the computer directly? I'm not willing to lose the video we've taken, so...
I bought my DCR-SR40 used (just camera) and I have the same problem. Downloaded the instruction manual from sony and discovered the only way to connect to a computer is through the
Sony Camcorder Docking Station
#DCRA-C162
and a Special USB Cable!
Jun 02, 2010 | Sony Handycam DCR-SR40 Camcorder
My canon i850 printer head will not move. When I turn the printer on I get a green light followed by 5 amber lights then it alternates 1 long green followed by a short amber,short green, short amber and...
Start with the printer OFF
1. Hold down RESUME and then hold down POWER
2. Release RESUME
3. Press RESUME twice, then release POWER
4. Let green light blink until printer is done futzing
Select function with RESUME press POWER to execute:
presses - light color - function
Number of presses - light color - function
0 presses - green - Test print (or exit service mode on i960)
1 press - orange - EEPROM info print (plus grid nozzle diagnostic on i850)
2 presses - green - EEPROM initialize
3 presses - orange - Reset waste ink counter
Nov 15, 2009 | Canon i850 InkJet Photo Printer
Display / Clock display not working
SONY MHC-EX50
Het is al een paar weken verder, maar ik ben eruit: C161 en C162 (100uF/35V) in de voeding zijn slecht.
wel 105 graden elco's gebruiken en hoger dan 35 volt, liefst 100v
et gaat dus om een VFD (Vacuum Fluorescent Display) die geen gloeispanning krijgt. Het vervangen van C161 en C162 lost het probleem helemaal op.
Radio: ST-EX100
Amp: TA-EX50
Symptome=Tuner-Display zeigt nichts an, sonst Tuner OK.
Defekt=C161 und C162 (100µF,35 V) auf der Tunerplatine ersetzen.
Wenn bei dem Sony-Tuner RDS EON ST-EX100 (z.B. zu der Anlage Sony MHC-EX5, aber auch MHC-EX 70) pünktlich eine Woche nach Ende der Garantiezeit die Beleuchtung im Display wegfällt und man deshalb leider keine Sender mehr programmieren kann, dann handelt es sich vermutlich um eine fiese Soll-Bruchstelle.
Auf der Platine des Tuners sind zwei Kondensatoren zu schwach ausgelegt und gehen zwangsweise früher oder später kaputt. Die Reparatur ist ganz einfach. Man kauft zwei neue Kondensatoren (100µF,35 V) - kosten nur ein paar Cent! - und besorgt sich einen Lötkolben. Dann schraubt man den Tuner auf, entfernt auf der Platine die Kondensatoren C161 und C162 (die sind namentlich gekennzeichnet) und ersetzt sie durch die neuen.
Nov 12, 2008 | Sony ICF-2010 AM/FM/SW Radio
Charging the battery the amber light comes on, but then after a while the amber light flashes. Does this mean the battery is charged? It used to turn to green with the battery that came with my...
if it turns green that means that it is charged, but it then if it turns amber that means that it is going bad
thanks
hope this works for you
Aug 27, 2008 | Acer Computers & Internet
NAD C162 Amplifier Logo
1,702 people viewed this question
Top NAD Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a NAD Audio Player and Recorder Expert? Answer questions, earn points and help others
