Question about Dishwashers
Fisher paykel dish draw
I have a dd fisher paykel. Three lights are lit The HEavy fast and rinse lights are constant. The led dispplay is diplays all sort of different times codes arn errors. I think it's shorted. It only displys a 5 min was when was button is pressed.
  • Anonymous Mar 13, 2014
    light not working on fischer paykel dish draw
Turn the power off to your dishwasher for about 30 seconds by flipping off the circuit breaker in your home's breaker box. When you turn the breaker back on it will have reset the dishwasher and should begin working just fine.
Posted on Nov 24, 2008
Fisher and paykel double dish draw has stopped working and is coming up with F5
Hi.
F5 is Lid Fault.
Try clearing the error code by disconnecting power from circuit breaker for five minutes. If that does not help, then there is a problem with lid switch. The part must be tested and replaced.
Regards.
Ginko
Aug 20, 2011 | Fisher and Paykel 23 in. DD-603SS Built-in...
I have a DD603 Double drawer Fisher and Paykel dishwasher, it is leaving a residue on the dishes. I currently have Jet Dry in the rinse aid reservoir. What is causing the dishes not to get clean?
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
Dishwasher Residue and Film on Dishes
heatman101
Nov 29, 2010 | Fisher and Paykel 23 in. DD-603 Built-in...
Fisher Paykel double drawer built in top drawer stops mid cycle.
It would help to know which LEDS are on when it stops. Are you able to open the lid etc. Does this happen with the short rinse cycle as well?
Oct 17, 2010 | Fisher and Paykel 23 in. DD-603 Built-in...
Fisher and paykel dd603
Flood switch is at the very bottom underneath the bottom draw in the base floor.Unplug cord.Open bottom draw all the way & squeeze a towel or sponge under the draw & soak up the water..The washer should work now..Why did it flood in first place?
Check that dishes are not stacked higher than top edge of the draw otherwise it can't seal.this can happen when children are asked to stack the dishwasher.Another cause is some models the seal is an inflatable tube that seals the top edge of the draws,it gets cut or sliced buy a plate that was stacked to high when you closed the draw.there should be no clunk of dished hitting when the draw is closed.
May 30, 2010 | Fisher and Paykel 23 in. DD-603 Built-in...
Fisher Paykel control panel to far left side has a film on it that chipped off - showing a shinner stainless steal under it. I guess this is a coating of some sort. Dish draws are 4 1/2 yrs old. Mild det...
You can buys the parts that look chipped/ broken and replace them. Panel parts are very easy to replace.
Check out which parts you need from the parts manual and order from the local fisher and paykel distributor.
http://www.stokes-aus.com.au/StokesAP/Manufacturer_Info/FP/DISHWASHERS/599084%20Dishdrawer-Version%203%20%20eg%20%20DD603%20etc.pdf
The parts that you need are listed from page 6.
Jan 02, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
Th dish washer that we have is the 2draw dd-603m
A lot depends on how it happened. Is this a new installation or everything was working well until now? F1 error implies the float switch in the drawers is activated as the inlet water soneloid could not turn off. This prevents the units from being flooded.
Are you using the correct pressure setting for the water supply. Check the user manual for details. IF you don't have one, download from the fisher & paykel website.
Nov 08, 2009 | Fisher and Paykel 23 in. DD-603 Built-in...
I have a F&P DD603I with NO lcd, just lights on top at the wash control panel. The HEAVY, FAST, and RINSE lights are all on at the same time. At one point the thing was playing the national anthem...
HI- I think your controller is faulty. I've only encountered the Star Spangled Banner issue once and replacing the controller fixed the issues. You may try to unplug the power cord for a few minutes and plug it back in and see if it resets but I don't think that will resolve it. I'd give Fisher/Paykel a call and see if they can narrow it down for you, they are often helpful.
Oct 04, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Dishwashers Logo
283 people viewed this question
Top Dishwashers Experts
