Question about Olympus Camedia D-390 Digital Camera
Quality settings Why are there so many quality settings?
    Master:
  • 852 Answers
Different quality settings are used for different purposes; for example, lower quality settings can be used to e-mail pictures because of its small file size. Higher quality settings are used for printing photo quality images.
Posted on Aug 31, 2005
4 Suggested Answers
neta
  • 852 Answers
SOURCE: Quality mode setting
Press the monitor button. The amount of images that can be stored and the selected quality mode will appear in lower-left corner of the LCD display.
neta
  • 852 Answers
SOURCE: Changing the quality setting
There are three groupings of shooting modes on the C-720UZ - 1) Program & A/S/M, 2) Auto & Sports & Portrait & Landscape, 3) Movie mode. Each group can retain a quality selection for all modes in the group. Therefore, you cannot have a different quality setting for each shooting mode within a grouping.
Posted on Sep 04, 2005
neta
  • 852 Answers
There are three groupings of shooting modes on the C-725 UZ: 1) Program & A/S/M, 2) Auto & Sports & Portrait & Landscape, 3) Movie mode. Each group can retain a quality selection for all modes in the group. Therefore, you cannot have a different quality setting for each shooting mode within a grouping.
Canon ip4850 print quality
Whats the question?? if poor quality printing, it could be dirty ink cartridges, dirt on the print head, poor quality paper ??? try looking at the printer settings, sometimes they may be set to economy rather than top quality printing.
Feb 18, 2015 | Canon IP4850 Inkjet Photo Printer
Streaks on copy
Try these steps first:
1. Check ink level.
2. Nozzle Check Pattern
  1. Load A4- or letter-size plain paper in the Auto Sheet Feeder (ASF) or cassette.
  2. Press the <Feed Switch> button to select the appropriate paper source.
  3. Press <Menu> repeatedly until [MAINTENANCE] appears.
  4. Press <OK>.
    The machine prints a nozzle check pattern.
  5. Confirm the pattern is not broken, missing, or a specific color is not printed.
3. Print Head Cleaning / Head Refreshing If the printed Nozzle Check Pattern is broken, missing, or a specific color is not printed, clean the print head.
  1. Press the <Menu> button on the printers operation panel repeatedly until [MAINTENANCE] appears in the LCD.
  2. Press the left [<] or right [>] arrow buttons to select the cleaning setting you want. Select [HEAD CLEANING] or [HEAD REFRESHING] for deep print head cleaning.
    Note: [HEAD REFRESHING] uses more ink than [HEAD CLEANING], so perform [HEAD REFRESHING] only when necessary.
  3. Press the <OK> button.
  4. Print a Nozzle Check Pattern and perform at least two Head Refreshings if the pattern is not correct.
You can also try using a higher quality print settings as follows:
Change the Print Quality Settings (Windows) The Quality setting controls how finely ink droplets are placed on the printed page. Depending on the type of paper being used a higher Print Quality setting does not always insure a better print. Print speed will decrease as the Print Quality setting is increased. Follow the instructions below to change the print quality settings in the Canon printer driver for the Windows operating system through a printing application.
  1. Click 'Properties' in the Print dialog box.
    Note: Depending on the Application software, 'Properties' may be displayed as 'Preferences'.
  2. Set the desired print quality in the 'Print Quality' section.
  3. Select 'High', 'Standard', or 'Draft / Fast'.
To set more detailed print quality settings, follow this procedure:
  1. Select 'Custom' and click 'Set'.
  2. In the Set Print Quality dialog drag the slide bar from 'Fast' to 'Fine' to select the print quality.
    Note: There are five options in 'Quality'. However, selectable options are limited depending on the media type.
  3. Select 'Auto', 'Dither', or 'Diffusion' from the 'Halftoning' section.
If the above steps do not solve your problem, it may be a time to purchase a new printhead.
Oct 09, 2009 | Canon PIXMA MP750 All-In-One InkJet...
Canon Printer IMAGE QUALITY
use the canon software and set up fax seperately.
Aug 05, 2009 | Computers & Internet
When I print photos, they have uniform vertical streaks.
Issue: Banded or streaked prints
Solution: Change the Print Quality Settings (Windows)
Apr 22, 2009 | Canon PIXMA iP4000 InkJet Photo Printer
Can't figure out how to adjust darkness/tone for printer output
Below you can see a step by step procedure on how to change the print quality of your work....you need to make test printouts in order for you to see the results....at the end there is a link to the manual for your printer...GOOD LUCK!!!
Print-quality settings affect print resolution and toner usage.
Use the following procedure to change print-quality settings:
1. Open the printer Properties (or Printing Preferences in Windows 2000 and XP).
2. On the Paper/Quality tab or the Finishing tab (the Paper Type/Quality tab for some Mac drivers),
select the print quality setting you want to use. The following options are available:
● 1200 dpi: This setting uses ProRes 1200 to provide fine-line detail at 1200 x 1200 dpi.
● 1200 dpi effective output quality: This setting provides 1200 dpi effective output quality
using FastRes 1200.
● 600 dpi: This setting provides 600 x 600 dpi output with Resolution Enhancement technology
(REt) for improved text.
● EconoMode: Text is printed using less toner. This setting is useful when you are printing
drafts. You can turn on this option independently of other print-quality settings.
Manual
Apr 13, 2009 | Office Equipment & Supplies
Photos are not good
Make sure that your quality is set to best and you are using a high quality photo paper for maximum resolution and quality.
Jun 11, 2008 | HP PSC 1210 All-In-One InkJet Printer
Print quality
Paper type must be set to "Plain" to select Normal or Fast for Print Quality. Every other paper type selected will automatically set print quality to Fine (Photo).
May 30, 2008 | Canon PIXMA MP780 All-In-One InkJet...
Settings
The best picture quality setting on the D-390 is SHQ (Super High Quality). The SHQ file is the largest of all four quality settings. The image file size is approximately 786K.
Aug 31, 2005 | Olympus Camedia D-390 Digital Camera
My pictures are not the quality I expected. What can I do?
Use the Quality setting on your camera to select a picture resolution. To change the quality setting: Press the Menu button. Select Picture Quality, and then press the OK button. Select the Picture Quality setting you want to use, and then press the OK button. Press the Menu button to exit the menu. NOTE: The setting remains until you change it.
Aug 29, 2005 | Kodak EasyShare CX7530 Digital Camera
Pictures are not the quality I expected
Aug 29, 2005 | Kodak EasyShare C360 Digital Camera
Olympus Camedia D-390 Digital Camera Logo
50 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Jerry Greenberg
Jerry Greenberg
Are you an Olympus Camera Expert? Answer questions, earn points and help others
