Question about Samsung RS2630SH Side by Side Refrigerator
A GE refridgerator
The freezer is at room temp and not freezing anything. The surrounding outside is hot to touch.
  • 639 Answers
Dear friend,
ngfam at you service! happy to assist!
Hot means danger , beware!
The only course of action is service!
Below I give you a good nation wide repair service
How old is the appliance ?
If it's 10 years old or more it's not worth sinking good money into bad !Todays appliances are so much more efficient that you save money on you electric bill!
Below I gave you a nation wide service thats very good!
We sell appliances for 65 years and I recommend this nation wide Factory repair service!
Call A&E Factory Service /They service nation wide
And are available 24/7 for making appointments!
If the appliance is 10 years old or more,it may make sense not to invest any money to fix it!
Happy to assist you,
PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OFF!
Posted on Aug 28, 2008
How do i reset my ge txr26kp side by side refridgerator
Generally a compressor is either warm or hot when running if cold it may not be running
Nov 22, 2013 | Refrigerators
We have a ge hotpoint HSS251FMBWW refridgerator. The power lights are on but neither the refridgorator nor the freezer will get cold.
Take a look at the compressor and compressor fan. If the fan inside is going the one outside by the compressor should be going also. Look for air restrictions around the compressor and clean em up. Feel the compressor: Hot to the touch means the relay is fried, cold to the touch means the relay has died.themobilian_1977.jpgthemobilian_1978.jpgthemobilian_1979.jpgthemobilian_1980.jpg
I have your late model GE service manual and some videos HERE
Mar 19, 2011 | Refrigerators
I have a GE GSS25XSRSS Side By Side refrigerator
no defrost taking place
a clock
b heater element/hot gas valve
defrost terminator or safety fuse
Mar 17, 2010 | GE GSS25XSRSS 36" 25.4 Cu. Ft....
Things in freezer melt and re-freeze
Your condenser fan motor at the compressor is either filthy or needing to be replaced. Air flow is pulled over compressor to keep it at a good operating temp. If the fan cannot pull air across compressor it will over heat and shut down on overload. Imagine working in yard on hot summer day and wearing a dust mask over your mouth and nose. Your body shuts down more needing more rest. Same thing with refrigerators, they have to be able to breathe properly also.
Jan 27, 2010 | GE Freezers
Chest Freezer not freezing
check the temp dial. and set to a lower temp. *be mindful of the surrounding temp of the freezer. it will not work properly if it is in 125 degree surrounding air. * check the coils on the freezer and make sure that they are clean. this allows for proper heat transfer from the inside of the box to the outside air. also check to see if the blower is running. * Check to see if there are signs of oil around the freezer, if so contact a service tech
Nov 14, 2009 | Freezers
The outside of the freezer door is cold, and the surrounding floor is cold - even in the hallway outside the room the freezer is in. Can't find any obvious leaks around the door seal. The sides of the...
the # should be inside, the temp in side the freezer needs to be checked. does the thing ever shut off, if not it may need a cold control
Jun 28, 2009 | Freezers
DOES NOT FREEZE WHEN ITS HOT OUT
The principle of refrigeration is to remove heat from inside the cabinet and dissipate to the outside via the condenser. if the outside is too warm, it will not be able to dissipate the heat, therefore it will not freezer. Very likely your freezer is not tropicalized.
May 04, 2009 | GE Profile Stainless Bottom-Freezer...
Freezer side is hot outside
There is no problem at all. The outside of the freezer is hot because it is rejecting heat from the inside of freezer compartment to the outside surroundings, this is a normal refrigeration cycle. As for the seals being hot, this may be to prevent the door from freezing shut. i know that commercial and industrial freezers have heated seals for this reason.
Nov 13, 2008 | Maytag MSD2756G Side by Side Refrigerator
My freezer is hot!
It is normal for the freezer or fridge walls to be hot sometimes, some important points are to make sure that there is enough ventillation around the fridge/freezer, especcially the back, so that air can circulate around it freely. Also maybe just check that there hasn't been anything fallen down the back blocking the vent, and that there isn't a dust collection or anything. Otherwise as far as I know this is normal.
Aug 19, 2008 | Frigidaire 16.7 cu. ft. / 473 liter...
My ge profile side by side bottom freezer is hot to the touch
is you condenser fan runnig at all. look in the back ot the unit and if you have a cover plate hten you need to either put your hand close to the opening and feel if there is a draft or if ther is air being blown out that is warm. If not then the condenser fan may be toast.
Jul 16, 2008 | GE PSS26SHRSS Side by Side Refrigerator
Samsung RS2630SH Side by Side Refrigerator Logo
121 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
