Question about Car Audio & Video
How to by pass the jensen dvd player prk sw parking brake.
Jensen vm9512
  • jeff65 Aug 24, 2008
    how to by pass the jensen dvd player prk sw parking brake.
  • Anonymous Jan 16, 2009
    i tried to use a toogle switch but it still wouldnt play
  • 1,586 Answers
You have to hardwire it to bypass the e-brake. Take the peach-colored wire and ground it to metal inside the dash. Put a toggle switch inline on the wire and mount it somewhere you can reach it. When you get the blue screen when starting a movie, open the switch for 3-5 seconds, then close it again to reapply the ground. Your movie will start up, and you can then drive away with it playing.
Posted on Oct 08, 2008
Dude **** all the complicated shyt... just wire up the harness like u normally would then forget about the peach colored wire... i have my screen all hooked up like a normal head unit and it still plays while i drive
Posted on May 18, 2009
How to by past the brakes wire for the dvd to play
According to the owner's manual, the pink wire is your parking brake wire and it has a label 'PRK SW' on it. It requires a negative signal to show that the parking brake is engaged. If it is currently hooked to your parking brake, you will need to trace it to where it is connected and remove it first. Be sure not to leave any wires exposed that can short out. Then connect the wire to a source of ground. this can be the black wire coming from the head unit, or a convenient screw nearby that is mounted to the vehicle chassis.
The manual can be found here:
http://www.crutchfield.com/S-x3LxzvPnGLv/p_110VM9312/Jensen-VM9312.html
Please note that it is likely illegal to have video playing where the driver is in view of it. Check your local laws before considering making this modification.
Feb 16, 2010 | Jensen's VM9312 Car DVD Player
Question jensen vm 9512 put in pat code still getting cannot wash wille driving
You cannot watch while driving as it's a safety feature of in-car dvd players, to by pass, disconnect from handbrake/parking brake switch.(found at the base of handbrake/parking brake). But doing so makes the use illegal in most countries not to mention dangerous.
Jun 16, 2009 | Audiovox VM9512 Car DVD Player
Jensen VM9512 Zone Lock
go to tool menu,select language,than take the remote controle and type 543210,hiden menu will open and there u can chose a region code, e-brake override and lott of stuff :))
Jan 14, 2009 | Jensen VM9510 Car DVD Player
Jensen Vm 9512
if you want to play dvds well you drive you just need to put parking brake wire (pink) to ground no code needed
May 25, 2008 | Audiovox VM9512 Car DVD Player
JENSON VM9512 CODES FOR BRAKE BYPASS
turn on the player, start the radio option, go into the setup menu, tap the language tab, ON THE REMOTE press "stop, stop, 5,4,3,2,1" This will bring up the secret menu, you do not need to connect the pink wire
Mar 10, 2008 | Audiovox VM9512 Car DVD Player
Jensen VM9512 in-dash DVD player
with the remote:
press set up button
scroll to highlight language
enter 5,4,3,2,1,0
you will now be in a secret menu
turn on brake bypass
and exit
done
Dec 14, 2007 | Audiovox VM9512 Car DVD Player
I need toby past e brake
on your remote control press 1 2 3 4 and then press and hold the number five until the hidden menu appears
there is an option to by pass the brake
David
Dec 07, 2007 | Jensen VM9510 Car DVD Player
Car Audio & Video Logo
1,257 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
