Question about Goodman Heating & Cooling
  • 182 Answers
Dirty filter or low on freon
Posted on Aug 24, 2008
What is going on with our Goodman unit?
If your going to pay that much just have them put in a new unit. It is not that much more and you can get free financing. All the repairman can do is guess and keep putting in new parts till it works. Had a new unit put in and it still didn't work found out it was a bad thermostat. But at lest we don't have the repair bills or high electric bill anymore so it paid for its self in saved money.
Jul 21, 2014 | Goodman Heating & Cooling
Not staying cool
sounds like it is either low on Freon or the compressor is going out. The blowing ice cold is an indicator that it may be freezing up because the low Freon. when it stops blowing cold, turn it to fan only mode and see if it gets colder again. If that is the case then the unit is low on freon and freezing up. I know that sounds confusing but that is how AC works. The low freon pressure means the gas is expanding too fast and the air flow cannot take up the cold from the evaporator fast enough. Turning the compressor off and keeping the fan on will alow the room air to take up the cold.
Apr 22, 2014 | Frigidaire FAM157S1A Air Conditioner
Not blowing cold air
If one line is freezing up with ice accumilation on it, the unit is low on freon. You may want to take the unit to your local appliance repair shop and have it looked at. I would request a quote for the repair before the work is done. Most of the time it is cheaper to buy a new unit than it is to pay the labor for repair.
Jun 06, 2010 | AmcorAire UCHW-H18AF2 Split System Air...
No cold air....external fan blowing....line between furnace and compressor unit is cold (with ice on it)and dripping water
Check your air filters and replace if necessary. Check the indoor and outdoor coils and clean if needed. If the line is still is freezing get the refrigerant charge checked.
May 03, 2010 | Honeywell ER150B Air Conditioner
Whirlpool refrigerator bottom bin is freezing
you likely have a problem with your evaporator fan motor not blowing air throughout unit. when this fails, the cold temps fall towards bottom of both sides. You can reply here or send me a question from my website:
Mar 15, 2010 | Refrigerators
Unit is icing up and not blowing cold air
Usually when this happens, the unit is low on freon. If you have an AC tech come out, make sure he does a leak check for you. Hope this helps... good luck!
Sep 02, 2009 | Samsung AW0505M Air Conditioner
Central air unit problem.......It starts out blowing cold then will only blow room temp air after some time. I don't see anything freezing up..Filter is clear. The unit outside is not clogged up. The...
Check your outside unit to see if fan is running. If it is running check to see if air is blowing out if not you have a bad capacitor. Some times if a capacitor shorts out the fan will run backwards and the line will get very hot same as if the fan is not running. Russ
Jul 20, 2009 | Heating & Cooling
Freezer not freezing and blowing luke cold air. Fan running full time.
rotate the defrost heater timer until it clicks and see if the defrost heater is working
Jun 02, 2009 | Refrigerators
Home central air conditioning unit
check the filter, make sure it's not plugged. Make sure all the vents are open. Are the lines freezing up (have ice on them?) Could be a lot of things but if it is not blowing much air then you may have a motor problem or dirty filter. If the unit is freezing up then probably have a leak and will need to be found, fixed and recharged.
Jun 09, 2008 | APC Heating & Cooling
Heating & Cooling Logo
32 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
