Question about Lands Phones
No signal after water damage - Lands Phones
Hey my name is sunshine and i will be helping you taday if u have no signal after water damage your phone will not work you would have to get a new one sorry for the bad news have a good day
Posted on Aug 24, 2008
After a period of time on the phone,sound breaks up
This could be a fail with the speaker in the phone (water damage is a favourite), electronic faults (The Analogue to digital converter is failing), or simply a lack of signal strength in your area causing the signal to fail. Remember mobile phones are actually a radio transceiver and that all the problems that affect them also affects mobile phones (Crackly signal loss of signal bad audio etc etc).
Mar 12, 2015 | Panasonic Lands Phones
Rear turn signal is not working
check for water damage inside the light (circuit board)
Feb 19, 2014 | 2004 Mercedes-Benz Mercedes Benz S Class
No or bad signal
Check in the Installation Menu that Antenna Power is set to OFF.
There is a chance that the water that came down the aerial lead has damaged the tuner module in the Humax.
Dec 28, 2013 | Humax PVR9300T HD DVR
Wega nova
Could be a couple of different things.
I'd first check the water level probe to make sure it isn't dirty or damaged.
After that it can be the inlet selenoid valve thats damaged or has limescale in it. If that selenoid is broken it will not allow water into the boiler.
Either way if the pump is running it means the machine is sending a signal calling for water so it has to be something associate with the water level probe, etc.
Dec 16, 2013 | Wega Coffee Makers & Espresso Machines
Panasonic plasma/water damage/won't power on for more than three seconds
Main digital board has damaged. I2C bus line has lost all sync signals from other boards. Contact the Panasonic service center.
Sep 30, 2012 | Panasonic Televison & Video
Hi, my wife recently got her Nokia 6303i phone wet. We have managed to dry it out etc and the phone powers up all ok,, however we haven;t been able to obtain a signal since in order to use the phone! Any...
It appears, that the water damaged the transmitter and/or the antenna of the phone. This happens due to the rust caused by the water. Or it may due to short circuiting due to water. Take it to a service centre to get it repaired. Remember, water damage is not covered by the warranty!!
Hope this helps you.
Aug 16, 2011 | Cell Phones
I put in a load. The machine filled up but did not stop filling. The dial did not proceede to next step, it stayed at the 10. Overflowing EVERYWHERE. When we moved the dial manually to spin, it drained...
your fill switch is either bad or "gllitched" and the timer cannot move until this switch senses the right amount of water for the load unless its an electronically sensed water/load capacity filled machine,when it starts,the water fills the unit and the pressure switch shuts the water fill off when at selected water level and powers the timer to continue the wash cycle,it works off a "bellows" on air pressure to change a switch by air pressure to operate the machine when full of water
Dec 27, 2010 | Kenmore 22622 Top Load Washer
My 2000 Dodge Ram 1500 stalls out while I'm driving and a No Bus signal comes on the odometer reading. It starts again usually after a few minutes but how can I fix this?
i had a jeep that flashed that and wouldnt start i ended up replacing the pcm(engine computer) after checking the wire harness and connection if im not mistaken the pcm is in a place where it can be exposed to water so it might have water damage hard to tell without the truck but the bus signal is a state of health from the computer like a self diagnostic of it so without the signal it wont run hope this helps good luck
Aug 22, 2010 | 2000 Dodge Ram 1500 Truck
No signal water damage no on going call not charging
It also coud be an area that does not receive signal and there is nothing wrong with the phone!
Jul 08, 2010 | Nokia 1208 Cellular Phone
No signal
do a network settings check and see if thaht helps, if not try servicing the phone.
Feb 29, 2008 | Nokia N70 Cellular Phone
Lands Phones Logo
103 people viewed this question
Top Lands Phones Experts
Are you a Lands Phone Expert? Answer questions, earn points and help others
