Question about Compaq FS7600 17" Flat Glass Monitor
MONITOR MENU COMES UP BY ITS SELF AND FLASHES
Monitor menu comes up by it self and flashes somtimes and other times it does not flash but will not let adjustments be made...I have no idea why this is happening or how to cure it ...it just started today...
please help
  • WV SCROUNGER Aug 27, 2008
    I guess HP are JUNK
There is a problem with the IC which is the driver IC. The part number of that IC is 24LC08B. It is manufactured by Microchip. I'm sure the brand of your CRT monitor is HP. I have the same problem too and HP can't fix this problem. Even their service center can't fix it also. This is the problem usually of new HP/Compaq monitors. I think this is a factory defect problem but HP isn't doing anything to repair these defective monitors. HP sucks!
Posted on Aug 24, 2008
My HPL1530 monitor flashes from time time the menu of the monitor. Even when my CPU is off it still continues to flash the menu. Now my monitor is blank already and display is gone. Any help is much...
Sounds like you might have a faulty circuit board either where your buttons are or in the screen itself. I would check with the manufacturer for a recall or for other support information.
Dec 13, 2010 | HP L1530 (Carbonite, Silver) 15" LCD...
My TV shuts off as soon as I turn it on...What is causing it to do this??
When it shuts off. Try doing what's called a self-diagnostic test. As soon as the television shuts try these steps.
Pressing on the front panel's 'INPUT' and 'MENU' buttons at the same time, and holding for 5 seconds, activates the Self Diagnostic Code Mode. The LED flashes denoting a two digit Error Code, or indicating no problem has occured since the last Initalization.
Note: The front panel buttons must be used, NOT those on the Remote Control.
-The number of flashes indicates the value of the MSD (tens digit) of the Error Code.
-The flashing then pauses for approximately 1/2 second.
-The LED then flashes indicating the value of the LSD (ones digit) of the Error Code.
-The Error Code is repeated a total of 5 times.
-Example: If the Error Code is ?24?, the LED will flash two times, pause, and then flash four
times.
The Error Code designations indicating a malfunction, or no malfunction, are listed below:
Self Diagnostic Code Description
1 - 2 = no error detected
2 - 1 = X-ray protect (high voltage or beam current)
2 - 2 = Short protect (short protect monitors low voltage supplies)
2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection)
2 - 4 = Vertical protect (usually loss of vertical from the source).
Thank you for using FixYa! Have a nice day and please remember to rate this solution.
Warm regards,
BearWeb
Apr 08, 2010 | Haier 20" TV/DVD Combo
My computer monitor will not stay on.
The problem may with the Ram inside your computer
Jul 07, 2009 | Dell E153FP 15" LCD Monitor
From time to time my menu will come up and then the remote wont work the buttons on the front are all backwards but if i pull the speaker cover off to get to the back of the buttons and wiggle the 5 wires...
My bet is that the MENU switch has become leaky. That's why the menu keeps coming up on it's own. If any of the front buttons are held down the remote won't work. A leaky switch is the same thing. That menu switch needs to be replaced. A real solid repair would be to change all the switches on that control panel.
Jun 02, 2009 | Televison & Video
LCD Monitor Blank/Non-Responsive - Dell E173FPC
Next thing I would check is the VGA cable between PC and monitor.
Make sure is in at both ends and if possible try another one.
Do the Dell Menus come up with no VGA cable plugged in? Is the light amber? Flashing or static?
Mar 18, 2009 | Dell E173FPc 17" TFT LCD Flat Panel...
Will not turn on
Pressing on the front panel's ?INPUT? and ?MENU? buttons at the same time, and holding for 5 seconds,
Please do Note: The front panel buttons must be used, NOT those on the Remote Control.
? The number of flashes indicates the value of the MSD (tens digit) of the Error Code.
? The flashing then pauses for approximately 1/2 second.
? The LED then flashes indicating the value of the LSD (ones digit) of the Error Code.
? The Error Code is repeated a total of 5 times.
times.
Self Diagnosic Code Description
Jun 09, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
My tv willnot turn on
times.
3yr old got ahold of monitor
ok, get to the event where you get this to happen "...then turn it back on the monitor does come on normally...", but just after power-up, press the F8 key to go to safe mode. If nothing visible, press ENTER anyway...get to safe mode yet?
Oct 27, 2007 | Computers & Internet
Compaq FS7600 17" Flat Glass Monitor Logo
147 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
