Question about Fedders A6Q10F2B Q Chassis Room Air Conditioner
Fedders A3X06F2G window air conditioner fan does not spin
I have a fedders A3X06F2G window air conditioner that I have had for 2 years. The motor will turn on and the compressor kicks in, but the fan will not spin. I took off the cover and it is difficult to spin the fan. Any suggestions?
    Problem Solver:
  • 8 Answers
Fan motor is stuck or defective it might need replacement. Check for broken fan blades or obstruction.
Posted on Feb 04, 2010
Does Fedders AEY08F2B window air conditioner have an oil port to stop squeaking motor.
Most air conditioner units don't have oil ports on motors any longer.
Sep 13, 2014 | Fedders Heating & Cooling
Unit turns on,compressor kicks on but fan does not turn,motor makes humming noise
sounds like fan motor has gone bad or the capacitor to fan motor is bad...open up unit ,see if motor is frozen..does it turn freely..if so ,replace capacitor,or fan motor is bad...
Jun 09, 2010 | Fedders AED24E7F Wall/Window Air...
Blower lockes up when u turn it on but it spins freely when
mcdevito75 here, Fan Motor appears fine while running, once shut off won"t strart again, fan needs help in starting, If so replace, the fan motor. See your local A/C repair shop, they come to the house.
May 31, 2010 | Fedders Y Chassis AEY12F7E Air Conditioner
Compressor comes on, some cold air, no fan?
Try spinning fan by hand. If it spins freely, change capacitor. If fan is tight, change fan motor.
Apr 08, 2010 | Fedders AED24E7F Wall/Window Air...
AC 'squeak'
inside fan blade could be hitting styrofom houseing
Aug 27, 2009 | Fedders A6Y12F2D Thru-Wall/Window Air...
My Fedders air conditioner, that I purchased approximately 3 years ago, has developed a fan motor bearing problem. I would like a technician to come to my home, and repair the problem. Is this possible?
If this is a window air conditioner, an option is to remove from window and take to appliance repair shop for evaluation. It can also be repaired
at your home but is generally more expensive. In both cases, it is best
to have model and serial number available just in case still under
extended warranty.
Jun 26, 2009 | Fedders Appliance Air Conditioner Wall
Won't "kick" on
need a little clarification but will try to answer....if the fan is not spinning or no air is coming out, then try taking off the front cover and spinning the fan by hand (With unit unplugged). it should spin freely and not feel rough or stop suddenly. if so the fan motor is bad. now if the fan motor works but the air does not cool then the compressor is not turning on in which case either 1. you are too low on freon (leak), 2. the compressor has gone bad, or 3. there is a wiring problem or bad run capacitor. i find it odd that this would happen to 2 units over the same storage period, any out-of-the ordinary environmental situations there? water damage? it could simply be a wiring short also.
Jun 09, 2009 | Haier ESA306 Air Conditioner
Need to replace seized fan motor
Fan motor has nothing to do with the refrigerant portion.
May 12, 2009 | Fedders A6P09S2A Air Conditioner
Fan won't come on.
First shut the power off then pull the blower out and try to spin the wheel if it spins freely then check the capacitor look for any swelling or dents and unless you know how to check it out, some AC parts stores may check it for you, but a lot of people just replace it first before the motor (it costs less usually around $5.00) if it's ok then the motor is probably bad and would need to be replaced.
Apr 23, 2009 | Fedders A6P09S2A Air Conditioner
Fedders A6Q10F2B Q Chassis Room Air Conditioner Logo
278 people viewed this question
Top Fedders Heating & Cooling Experts
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Bill Long
Are you a Fedders Heating and Cooling Expert? Answer questions, earn points and help others
