Question about Hoover Floormate H3000 Upright Wet/Dry Vacuum
Won't dispense cleaning solution
Linkage from handle works well and operates plunger. tank has fluid and is not plugged (dispenses when I manually push into spring-loaded valve. Still am not getting fluid to the scrubber head; not sure when the supply tube delivers the fluid to and the Hoover online manual was no help whatsoever.
  • 8 Answers
I had this same problem. There is a solution posted elsewhere on this website. Search for Hoover Floormate H3000.
The following solution is the one I tried: Remove the fluid dispensing tank and put a small dab of hot glue on the tip of the blue/greyish "plunger" piece that is located in the middle of the black rubber circle. Let the hot glue dry (this forms an extension to the plunger piece...) and replace the fluid tank.
I did this and my machine is working properly again! Whoever posted this solution was very helpful!
Posted on Aug 29, 2008
    New Friend:
I took a pen cap from a Bic pen and cut the cap down to just a little taller than the plunger piece (located around the rubber circle). It fits over that plunger piece and inside that rubber circle. It seems to stay there when I had to remove the solution tank to refill it but if the cap comes off while removing the solution tank, then possibly hot glue the cap onto that plunger piece. The solution now flows out of the tank and onto the floor nicely when the trigger is pulled to dispense the solution onto the floor.
Posted on Dec 08, 2012
How to fix clog on hoover floormate fh40010?
I was having the same issue with my NEW just out of box Hoover FH40010. First run on the floor was great then the water/cleaner stopped dispensing!!! I found that when is assembled it out of the box I did not have the handle "plugged-in" properly!! I reattached it to where there is NO gap in the handle when pushed firmly into place and locked in the base. WATER SOLUTION NOW WORKS PERFECTLY!!!
Nov 30, 2012 | Hoover FloorMate Hard Floor Cleaner -...
My hoover steam vac is not releasing the cleaner
http://www.hoover.com/pdfs/manuals/F5914900.pdf this is the manual for your model
Godbless
Problem: Clean solution won’t
dispense
Problem: Brushes/brush indicator
won’t rotate during floor cleaning
Possible cause
Possible solution
• Not firmly plugged in
• Plug unit in firmly
• No voltage In wall plug
• Check fuse or breaker
• Blown fuse/tripped breaker
• Replace fuse/reset breaker
Possible cause
Possible solution
• Recovery tank full/automatic
shut off engaged
• Remove and empty recovery tank
• Blockage In tool on end of hose
• Remove tool and clear blockage
• Recovery tank lid not on
correctly
• Make sure lid is on securely
• Recovery tank front panel not
replaced after stair or upholstery
cleaning
• Replace recovery tank front panel
(page 14)
Possible cause
Possible solution
• Solution tank not firmly in place
• Make sure tank is securely locked in
position
• Solution tank empty
• Refill tank according to instructions for
surface being cleaned
correctly
• Make sure lid is firmly in place
• Pump needs to be “primed” (when
using tool)
• See “Before using tool” section, p. 13
Jun 15, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Solution does not dispense
The trigger that releases the water is connected by a piece of plastic inside the handle. This plastic tends to bend over time, so it won't press the plunger high enough. I brought it to a vac repair place for the same reason and they added an extension which made all the difference. If I were to do it myself next time, I would look to see if a metal rod were possible to take the place of the plastic. Maybe not, but it would be worth a look.
Nov 05, 2008 | Hoover Floormate H3000 Upright Wet/Dry...
No dispensing of water from container.
Check the bottom of the tank, there should be a gasket on the valve at the bottom of the tank. Must be on the tank and not sitting in the hole. Make sure the tank is sitting firmly and not off set even a little. Loosen the cap for the flow indictor while running, then tight when fluid starts leaking out, stop when the spinner starts spinning. Other then that you may have a clogged line somewhere.
Jul 08, 2008 | Bissell 7920 ProHeat Pro-Tech Upright...
Hoover 3010 FloorMate Plus not dispensing liquid
With the tank off, can you see if the rod in the handle is hitting the spot where the tank sits on, if not then there is a problem in the handle. If it is, then the reservior asm may be bad, it is what the tank sits on.
Jun 14, 2008 | Hoover H3030 FloorMate SpinScrub 500...
Hoover Floormate won't dispense clean solution
The tank sits on what is called a reservior asm, that may have gone bad. Does the water flow out of the tank when you push in the valve at the bottom?
May 09, 2008 | Hoover Floormate H3000 Upright Wet/Dry...
Detergent won't dispense
Check the valve at the bottom of the tank, does it push up then come back by itself (part #43513014)? If it is ok, then there may be a problem with the plate that the tank sits on or the plunger inside the handle isn't pushing to release the detergent.
Feb 08, 2008 | Hoover F7220900 SteamVac V2 Upright Vacuum
Cleaner does not dispense
Check to make sure that the back end of the top housing is tight against the bottom, Sometimes they break loose. Make sure that the gasket at the bottom of the tank is on and is in place. Does the hand spray work? If it does then the heat inside the handle is plugged up. Pump belt broke or is slipping, could have a bad pump. The cap for the flow indictor is leaking air. There are alot off reasons why it may not be spraying.
Nov 10, 2007 | Bissell 1698 PowerSteamer ProHeat Upright...
Bissell proheat 1698 cleaner not spraying water
MY CARPET CLEANER WAS NOT SPRAYING ANY WATER OR CLEANING SOLUTION. I TOOK THE BACK OFF OF THE HEATER THAT IS IN THE HANDLE. IT WAS CLOGGED WITH CALCIUM DEPOSITS. I CLEANED THE HEATER AND PUT IT BACK TOGETHER AND IT WORKS GREAT. KEN
Feb 25, 2007 | Bissell 1698 PowerSteamer ProHeat Upright...
Hoover FloorMATE 3000 won't dispense cleaning solution.
I had the same problem with my Hoover Floormate H3000 and found the solution elsewhere on this website. Try doing a search for Hoover Floormate H3000. The posted solution is basically as follows:
Remove the liquid dispenser tank and set it aside. Look into the cavity of the machine where the tank attaches and find the plastic "plunger" piece (the one on my machine is a blue/grey color) that is surrounded by a black rubber circle. Put a small drop of hot glue on the tip of this plastic "plunger" piece and let it harden. Replace the liquid dispenser tank and try the machine again. My machine dispensed liquid properly after this fix-it.
I really appreciate the poster who provided this simple solution!
Nov 19, 2006 | Hoover Floormate H3000 Upright Wet/Dry...
Hoover Floormate H3000 Upright Wet/Dry Vacuum Logo
331 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
