Question about LG Washing Machines
Lg front loader
Can i open the door after the washer has started
  • margaret9m Aug 25, 2008
    thanks for the help
    Sergeant:
    Novelist:
  • 166 Answers
You shouldnt be able to open the door when the washer has started and for a few minutes after it gets finished. Id=f you can then you have a faulty safety switch. The only way to open it when its started is to turn the dial to stop, and wait a few minutes until the lock turns off ( you will hear a click) then you can open the door, if its filled with water, then you shouldnt open it unless you want a puddle, you can put in on spin and get the water out before opening the door
Hope that helps
Posted on Aug 24, 2008
How to fix a EHE error code
1. Start the drier normally
2. Before the "EHE" error appears, open the drier door!
3. Because the door was opened during program, "dE" error is shown
4. Close the door and press "start/pause" to continue
5. Program will continue normally; problem fixed!
Apr 30, 2014 | LG WM3431 Front Load Washer / Dryer
Le Error on front load machine
Hello,This a common problem for all front loaders. Your washer will not drain or work 'cause your outlet filter is clogged. Usually this small door is on the left side front below of your washer. Expect some water to come out when you open the door, etc. Clean out your filter and refit.....things should be fine.
Thanks
May 22, 2010 | LG WM-2277HW Front Load Washer
My LG front loader is washer leaking water.
Could be the bladder from the drum to the door of the door seal. It could also be the drain pump hose.
Sep 13, 2009 | LG Washing Machines
Mold and mildew in door deal of LG front loader WM
Barb,
This is a problem with all front loaders. We have used those cleaning tablets in a regular hot cycle per the directions on the box. You can also try placing 1 cup of crystal dishwashing detergent in the tub and fill the soap dispenser with bleach and run a quick cycle full hot.
Aug 09, 2009 | LG WM-2277HW Front Load Washer
Front door does not release
press the pause/ play button. This will unlock the door
Jul 11, 2009 | LG WM2688H Front Load Washer
LG Washer front loader stopped mid wash and is lock can't open door
unplug/plug unit. drain water via hose behind lower left panel on front.
Jun 03, 2009 | LG WM-0532HW Front Load Washer
LG Sense Clean DD error code "FE" front loader washer/dryer combo
my lg senseclean wash mashine shows the sign Cl on the display and the door cannot be open what does it mean?
Jan 03, 2009 | LG 4.0 Cu. Ft. 7-Cycle Front-Load Washer -...
Front loader washing machine
This is normal, the unit usually goes into a SD or slow down mode. To stop this press the start pause button and the door will unlock.
Sgt 48
Jun 04, 2008 | LG WD-3243RHD Front Load Washer / Dryer
LG Front Loader WD-8074FHB
sometimes you just have to force the door but first try hitting the machine near the door lock sometimes this helps the door interlock may be stuck in the closed position
Mar 02, 2008 | LG WM1812C Front Load Washer
Washing Machines Logo
71 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
