Question about Dell Latitude D600 Notebook
Black screen Solution #6 posted on Aug 24, 2008 bowhunter63 Rank: Apprentice Rating: 0%, 0 votes I called hp today, for the black screen at bootup. He worked me through it perfectly. Seems when the machine sits idle too long the power starts to efecct the mother board. The solution was to remove powercord and battery, press the startup button for 30 seconds then plug back power cord and press power start button again... Then reinstall battery and start with it in again... Worked fin after that I guess hp is aware of this issue.......
    Genius:
  • 2,028 Answers
Yeah, HP has some major issues with their power management system on their boards.
Posted on Aug 26, 2008
What do you have to do to become a Wiz in FixYa? I am new and have put in 41 solutions but am still at Master status. When will I be a Wiz and how long until I am a premium expert?
Rank Average Rating Minimum Number of
Solutions Posted guru.gif Guru 85% or higher, 5 votes minimum. 50 wizard.gif Wiz 80% or higher, 5 votes minimum. 30 master.gif Master No Ratings Required 10 expert.gif Guide No Ratings Required 5 nonexpert.gif Apprentice No Ratings Required Rank Average Rating Minimum Number of
Solutions Posted guru.gif Guru 85% or higher, 5 votes minimum. 50 wizard.gif Wiz 80% or higher, 5 votes minimum. 30 master.gif Master No Ratings Required 10 expert.gif Guide No Ratings Required 5 nonexpert.gif Apprentice No Ratings Required You need to visit the Expert FAQ's section to get answers to this, link is http://www.fixya.com/FAQexp.aspx
but here is an extract:
Ranks are calculated by dividing the total value of the ratings cast on an Expert's Solutions by the Expert's number of rated Solutions. Unrated Solutions, Premium ratings, and Live Chat ratings are not factored into Experts' averages.
Wizz needs 80% or higher ranking, 5 votes minumum and 30 solutions minimum.
The help screens are good so just have a look around and you'll find out lots.
Aug 22, 2011 | FixYa Service
CD PLAYER
You may want to reference this solution posted to my problem by rpgnzls: Try removing the radio fuse & wait a while. It should reset when plugging the fuse back in. Hope this helps!!
Solution #1 posted on Mar 19, 2009 Asker's Rating 0%20stars_w.png noavatar_s.gif
rpgnzls
Rank:nonexpert_s.gif Apprentice
Rating: 0%, 0 votes
Mar 19, 2009 | 2004 Lincoln Aviator
Archos code 104
Make sure you have the correct model # for your Archos, or these suggestiosn from other experts will not work for you:
hotlyq:
Rank: Apprentice
Rating: 96%, 10 votes
Try the steps below:
1. Select 2nd option "Repair" or 3rd "Format the disk"
2. Connect 605 to PC using USB wire and find the Driver named "a605" or similar words
3. Copy a firmware to the ROOT directory on the driver mentioned above
4. Keep the USB connected and select "OK" on 605
5. Re-calibrate the screen under Display menu on 605.
Hope Everything is ok.
posted on Aug 27, 2008
alcalc:
Rank: Apprentice
Rating: 95%, 3 votes
Just a little FYI: hotlyq's solution works just fine, but the firmware file needs to be name exactly as it is downloaded. I downloaded both OSv2.1.0.4 and OSv2.0.1.0 firmwares to the same folder on my PC. Obviously enough I had to give them different names on the disk, I tried both and neither worked. It turns out the recovery system will not use any firmware unless it is named "firmware_a605f.aos". So if you're like me, copy the firmware over to the root of the USB-drive and then rename to firmware_a605f.aos.
Jan 07, 2009 | Archos 605 WiFi Digital Media Player
Parking & tail lights stay on
1 Other User Has The Same Problem Posted by camberggren on Nov 26, 2008 I just encountered the same problem on my 96 Subaru after I had the alternator replaced. One user tried the band aid fix of removing the hazard warning flasher 15 amp fuse in position #27 in the engine compartment fuse panel. It could also be a bad lighting relay. I am still troubleshooting the problem. Solution #1 posted on Aug 12, 2008 0%20stars_w.png
noavatar_s.gif tgmc123
Rating: 92%, 2 votes
The first thing you need to do is figure out if the car has a factory or aftermarket security system them replace the clicking relay accordingly
Nov 23, 2008 | 2006 Subaru Outback
Nokia 2630
call the custumercare or reach the service centre for help.
Oct 31, 2008 | Nokia 6300 Cellular Phone
1989 Plymouth Horizon
replace the egr valve and the PCV valve possible a new air filter also
Mar 09, 2017 | 1989 Plymouth Horizon America
Technical support
slappa71
Rating: 0%, 0 votes
you need to remove the blades and strip it to the bottom of d/w under blades and check if it is blocked. if ok undo drain pipe and blow to check if blocked. good luck SLAPPER
Jun 25, 2008 | Kenmore Dishwashers
What is the default passcode for the Logitech F-0228A Mobile Freedom headset?
Guest
Rating: 0%, 0 votes
Pair Your Headset
Before using, you must pair your headset.
1. Turn phone on.
2. With Headset off, push Talk/Volume up button for 10 seconds. Blue LED will flash rapidly.
3. Follow pairing instructions in phone-setup or connect menu. Your phone should find “Logitech
HS04VXX”Headset and prompt you for a passkey pin.
4. Enter “0000”.
5. Press OK on phone.
6. From Headset device list press “Logitech HS04VXX” Headset.
7. Select connect.
When your Headset is successfully paired, the blue LED will flash slowly.
Nov 11, 2007 | Logitech Mobile Freedom Wireless Headset
Comcast Remote Control Code
10150 worked for my mitsubishi wd65737
Oct 29, 2007 | Mitsubishi WD62527 62 in. LCD HDTV
Camera
noavatar_s.png By nonexpert_s.gif Z71kitty
Rank: Apprentice
Rating: 0%, 0 votes
Press your ok (menu) button.Don't pay any attention to what is on the screen,just press 000000 (6 zeros). This will take you to the service menu.Scroll down to #6 (H/W Test).Go to camera test and select on.Your phone will turn itself off and back on. Try your camera and see if it works.
Oct 02, 2007 | LG VX8300 Cellular Phone
Dell Latitude D600 Notebook Logo
112 people viewed this question
Alun Cox
