Question about HP Office Equipment & Supplies
I bought a HP Photosmart C4340 and my computer doesn't list it in the control panel under " Add a printer." I tried downloading the software on my computer with the CD which came with the printer and it won't load. Please help me.
    Sergeant:
    Novelist:
  • 166 Answers
Try downloading the drivers from here
Just pick your operating system first
http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?prodNameId=3546237&lang=en&cc=us&prodTypeId=18972&prodSeriesId=3221641&taskId=135
A tip with hp printers is to NOT connect them until you have the software installed. so if you have it connected just unplug it run the drivers from the website and plug it in either when the installer tells you or when it has finished installing the drivers
Posted on Aug 24, 2008
Computer won't recognize USB port HP Photosmart 7960
when you plug in the printer and turn it on do you get the sound that a USB device as been added
NO :
try a different cable
YES :
it might be worth trying new drivers only ad downloading the latest version direct from the manufacturer
http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=ps-18223-2&cc=uk&dlc=en&lc=en&os=228&product=305383&sw_lang=
Hope this helps
Dec 14, 2011 | HP PhotoSmart 7960 InkJet Printer
My HP 2410 Photosmart printer is making a clicking nose on start up. In the past I was instructed to unplug it and everything attached to it, including the computer, for 15-30 minutes and it would reset...
Uninstall the printer completely starting from the software.
Go to Start Menu, Control Panel, Add/Remove Programs, select the HP Photosmart software and remove it.
Then, go to Start Menu, Control Panel, Device Manager (usually under Administrative Tools/Computer Management).
Select under "Printers", the HP Photosmart 2410 All-in-One InkJet Printer and remove it.
Restart your computer and follow the instructions from your HP manual to setup your printer again.
Apr 06, 2010 | HP Photosmart 2410 All-In-One InkJet...
My HP Photosmart C6280 will not scan documents to my computer. I have it connected to USB port on my wireless PC. I try scanning thru solution center and that does not work. I have turned off the computer,...
Solution
For Windows XP
*Go to Control Panel > Printers > HP Photosmart c6200 series > Right Click > select Delete
*Load the CD / Downloaded Software for HP c6200 series
*Select add a device > select usb (if preferred)/ wireless
*Wait for the installation to finished and repair the settings.
*Restart PC/ Try Scanning Again.
If it doesnt work, I suggest try uninstalling and reinstalling the software completely using the CD itself.
Hope this works. Good LUCK!
Feb 14, 2010 | HP Photosmart C6280 Printer
Photosmart C7250 All-in-One. Copier, fax and printer work. But I cannot find my scanner icon where it was on my previous computer.
Were you able to install the correct driver for your OS? Usually the scanner application can be found in the list of Programs >> HP Photosmar C7250. If what you are referring to is the icon on your System Tray (lower right corner), you can always add an icon there by right clicking the blank space in your system tray and choose properties. On the taskbar tab, click on Customize, look for the icon for your scanner, click for the behavior and from the drop down button, choose "Always show".
Try to scan also by pressing the scan button in your printer and press start to initiate a scan.
Jan 03, 2010 | HP Photosmart C7250 All-In-One Thermal...
An error occured during the installation of the
Step one: Uninstall the All-in-One software Even if the installation failed, some HP software components might have installed on the computer. Follow these steps to use the Windows Add or Remove Programs tool to uninstall the software.
  1. Disconnect the USB cable from the product.
  2. Click Start , and then click Control Panel .
  3. Click Add or Remove Programs . The Add or Remove Programs window opens.
  4. In the Currently installed programs list, select the following items if they are listed:
    • HP Officejet/Photosmart/PSC All-in-One software 9.0
    • HP Imaging device functions 9.0
    • HP Customer Participation program 9.0
    • HP Solution Center 9.0
    • HP Photosmart Essentials 9.0
    If the list of installed HP programs contains any version numbers less than 9.0, select the following items if they are listed:
    • HP Officejet/Photosmart/PSC All-in-One software XX (where XX represents a version number less than 9.0)
    • HP Imaging device functions XX
    • HP Customer Participation program XX
  5. Click Change/Remove , and then follow the on-screen instructions to uninstall the software.
    NOTE: If a prompt displays asking you to remove shared files, click No . Other programs that use these files might not work correctly if the files are deleted.
  6. Restart the computer when prompted to do so.
Apr 24, 2009 | HP Photosmart C6180 All-In-One InkJet...
Hp photosmart 2610xi does not scan.
Remove all hp software and drivers from control panel>add remove programs. Then go to control panel>system and go to hardware and then device manager, then delete your printer/scanner from the list by right clicking and 'uninstall'. Then restart, and make sure you printer/scanner is unplugged and off. Then once your computer restarts go to hp's website and make sure you selected the right country (at the top), then go to support & drivers and download the software/drivers that are for your printer/scanner. Once drivers/software is install, then connect printer (or follow installation instructions, if different)
Also, just to make sure, plug it in a different USB port (after the reinstallation) incase the old drivers are stuck on the computer somewhere. Drivers usually/sometimes are associated with a specific usb port and will reinstall when plugged in a different port.
Mar 07, 2009 | HP Photosmart 2610xi All-In-One InkJet...
Downloading to computer
Go out to hp.com and click on support then updates and find your camera and download the latest updated software. I have several hp devices including one camera, and have had to download updates for all of them, The discs which come with equipment are made up before the release of the equipment, needless to say by the time you get it, the disc has long been updated.
Aug 11, 2008 | HP Photosmart M415 Digital Camera
Installation Problems, Please help!
try downloading the software from the HP website and then reinstall the printer. But also try to uninstall it using control panel add/remove programs, restart your computer, and then reinstall using the downloaded driver.
Jan 27, 2008 | HP Photosmart C4280 Aio Printer
24 people viewed this question
Ben Johnson
