Question about Palm Treo 750 Smartphone
Screen going bad?
Was wondering if my screen is going bad and needs to be replaced. I sometimes get black lines on the screen when I press the button to turn the screen on. Doesn't do it all the time but probably 1 out of 10 times when I press the button. Works fine when screen is lit and don't see any black lines. Only happens when screen is first activated to turn on.
Thanks,
Teresa
  • greilly Mar 06, 2009
    Thanks Greg
  • Palm Master
  • 13,433 Answers
Noting to worry about untill you start seeing black lines all the time, then I would say you might have to replace the screen or the mainboard if your screen is fine.
Posted on Aug 24, 2008
Why does my flat screen have black line and smudge on screen?
If you have a black line on the screen press menu button on emerson tv remote. If line id still there then the lcd screen is bad. If war contact auth servicer. If out of war relace the tv.
May 10, 2014 | Emerson EWL3706 37 in. LCD Television
Sony Bravia (52 in.) Screen not working
It is not the LCD screen that is bad. It is a problem with one of the control boards. What is the model number?
Nov 24, 2013 | Televison & Video
Acer Aspire 9110 problem
Sounds like your video is bad or the laptop is not getting power from the ac adapter or battery. Make sure your ac adapter power cord is good.
Mar 27, 2012 | Computers & Internet
My screen has a black line on the right side and has lines going across sometimes you can see double
Chances are, that the LCD screen is starting to bad. The screen might need to be changed. The best way to test is to connect an external monitor to it, and see if it comes up. if it does, then it is in the Video card/component, otherwise the screen will need to be replaced.
Please rate. Thank you.
Apr 02, 2011 | HP Tablets & eReaders
Black line down right side of screen
turn off laptop.
press and hold on the D then press Power button.
during the LCD BIST test check if the black line down right side of the screen is visible. if yes LCD needs to be replaced. if not connect your laptop to an external monitor check if the black line display appears to the ext monitor, if yes uninstall / reinstall video driver if fails replace video card or if it is built in replace motherboard.
if no ext monitor available then run PSA (press and hold Fn key then press Power button)
check if the black line is visible. Check also in BIOS is black line is visible, if yes then uninstall reinstall first the video driver if fails replace LCD.
Oct 11, 2009 | Dell Inspiron 9200 Notebook
The display on my inspiron 6000 in jumpy at the bottom 1/3 of the screen. no evidence of any damage to case or screen. Just started with a black line and now jumps around and has white lines in the bottom....
Generally the problem is caused due bad LCD inverter cable. Kindly run the LCD diagnostics
How to Run diagnostics
1. Shut down the computer
2. Disconnect the AC adapter and Battery
3. Press the power button for 10 sec.
4. reconnect both AC adapter and battery
5. Press FN key+ power button
6. Follow the screen prompts.
If the LCD problem is shown in diagnostics your screen would have to be replaced.
Thanks for using Fixya
proton
Jul 27, 2009 | Computers & Internet
The screen wont turn on anymore. the buttons can sometimes but the screen stays black.
When you say the buttons "sometimes" lite up, do you mean just when they feel like it or only when you power it up or off? And is it making any noise when you power it up? If they're only working when you turn it on and then they go off, then you have a firmware problem and you need to have it re-flashed.. If they turn on and stay on, and it makes noises (like you can hear the keytones when ya press them) then it has got a bad LCD and that's a pretty inexpensive fix (check Ebay for a replacement screen)
May 20, 2009 | Motorola Cell Phones
Black band running from top to bottom of screen
this will need to go into the shop to get one of the video processing boards replaced that controls that part of the screen , this will happen when it gets to hot inside the set ,( thermal break down)
electech
Oct 31, 2008 | Philips 42PF7320A 42 in. Plasma HDTV
Hitachi 51g500 screen gone black
Yes worth repairing but not a crt problem. the crt's are powered by a high voltage transformer and sometimes it's caps that goes bad and in turn knocks out the crt's. but they are ok, it's in the high voltage line.
Aug 12, 2007 | Hitachi 51G500 51" Rear Projection...
Screen Adjustment
On your monitor at the bottom there is 3 buttons. The one all the way to the left is the "menu" button. The next one (going right) is the "NEGATIVE" button. The next one (going right) is the "POSITIVE" button.
You can move your screen around. First, start by pressing the menu button.Then, a menu in blue, with a bunch of little white icons will appear. Next, go over two icons by pressing the positive button twice. Then, proceed to push in the "menu" button again. A bar will appear. By pressing your negative button, your screen will move left. Pressing your positive button will make your screen move right. Adjust your screen until the black on both sides are of even proportion. Then, press the menu button to return to the orginal menu you started at. Proceed to press your positive button two more times. Then, press your menu button. Then, once again, use your positive button, and your negative button to adjust your screen to even out the black on the top and bottom.
Dec 24, 2006 | HP Compaq FS 7550 17" CRT Monitor
Palm Treo 750 Smartphone Logo
200 people viewed this question
Top Palm Computers & Internet Experts
Michael Vincent Cruz
ray gallant
Raj Patel
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
