Ovens Logo
Posted on Jun 30, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Is the microwave oven model #MT4078SPQ described on your web page available?
Poul Brinchs Larsen
Level 2:
Sergeant:
  • Expert 159 Answers
  • Posted on Jun 30, 2011
Poul Brinchs Larsen
Expert
Level 2:
Sergeant:
Answers
159
Questions
0
Helped
49521
Points
511
I suppose your microwave oven is a Whirlpool
On their site you can find a user manual for your product
good luck
https://www.whirlpool.com/webapp/wcs/stores/servlet/OCManualsLiteratureSearchResultView?catalogId=10561&langId=-1&storeId=10211
2answers
I have a GE Dual wave II Microwave System (model # jkp68g0k3). Still works great.
You may be able to find a replacement glass for your GE Dual Wave II microwave system by contacting GE's customer service or parts department. They may have compatible replacement parts available, or be able to direct you to a third-party supplier that carries them. You can also try searching for the part online using the model number of your microwave. However, keep in mind that older models may have limited availability of replacement parts, so you may need to consider alternative solutions such as having the glass custom-cut or purchasing a new microwave.
Feb 09, 2023 • GE Ovens
My oven keeps giving the f10 code even though I have replaced the temp sensor and the oven relay panel. What's the next step? It's an electrolux #ew30es6cgw2. Tia
F10 - Runaway temperature. If these error codes shown while the oven is in day time mode, the EOC (electronic oven control) would need to be replaced. Otherwise check the oven temperature sensor (RTD sensor) as described earlier and replace if necessary.
Most of the EOCs incorporated power relays among all other components while some of ovens use a separate power relay board to simplify design and lower cost of production. You can determine it by visual EOC inspection and/or by the wiring diagram for your oven (if it is available). If there are some relays on it, replace the EOC. If there are no relays on the EOC, check the parts list (Search by the Model number) for the relay or power board. If there is a such part, replace it. I'll be glad to help you if any problems with the diagnostic. Just leave a comment on the bottom of the page. In such situation I'll need the complete model number of the oven.
Unable to find model number for electric oven
Hello, Smlmyers -
Look at the image for the location of the sticker with the oven model on this web page:
http://www.stockportrepairs.co.uk/Lamona/Oven
Scroll down the page. The image is near the bottom.
Best wishes from a volunteer answerer in the USA.
Jan 18, 2018 • Ovens
JTP85 microwave shuts completely off with a blank readout.
Your magnetron is overheating, and its attached thermostat is doing its job to protect the magnetron by shutting off the power to the oven until it cools back down to a safe temperature.
An overheating magnetron can be due to:
  • operating oven without cover(s) in place
  • wrong magnetron installed in oven
  • an old or otherwise failing magnetron
  • cracked magnetron magnet
  • improper power line voltage (should be 110-125VAC)
  • foods low in moisture (popcorn & bacon, e.g. - add 1/2 cup of water in rear oven when cooking such foods)
  • failed or inoperable cooling fan or hood vent exhaust fan
  • deteriorating foam weatherstripping seals in air ducts or on outside cover
  • blocked air vents (dust, animal nest debris, insufficient free air space behind & around oven, etc.)
  • clogged or greasy charcoal filter or grease filter
  • blocked duct in hood vent exhaust
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, and it is very helpful when troubleshooting, testing, and locating components.
dee77f7.jpgAt our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Accessing some parts may require you to pull the oven from the wall and remove the cover.
If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
You can download GE owner's manuals and installation instructions here.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
I have purchased a Casera 30L Microwave Oven with Grill and Convection, And have no idea how to use the times necessaryfor utilising the Microwavr Grill anf Roastin Oven.. Could you direct me as to recipe...
First of all, thank you very much for choosing FIXYA today for your technical support needs.
I'm Joe, and I will be more than happy to assist you with your service request.
Cooking in a convection microwave oven certainly is a bit different than using just a standard microwave and does require some special care and technique. Here is a link to an article which describes the general priciples of cooking with convection microwaves and explains some of the special techniques required:
http://whirlpool.custhelp.com/app/answers/detail/a_id/384/~/how-does-combination-microwave-convection-cooking-work-and-how-do-i-use-it%3F
Although there is no documentation currently available online specifically for the Casera line of Microwave Convection ovens, here is a direct link to the ONLINE USER'S MANUAL for a model of convection microwave from Whirlpool with very similar features:
https://www.whirlpool.com/digitalassets/MLPDF/Use%20and%20Care%20Guide%20-%208206204.pdf
To view the Owner's Manual with Operating Instructions just use your mouse to click on the link, which is the underlined and blue highlighted text just above.
This will open a new web browser page automatically for you and allow you to view the information at the website indicated and the contents of the Owner's Manual.
You may need ADOBE READER installed on your computer to read PDF documents, although many computers already have this utility pre-installed.
You can always download this for free at WWW.ADOBE.COM if necessary.
Click on the DOWNLOAD ADOBE READER button on right side of the ADOBE home page when you get there, then follow the onscreen instructions to install the software on your computer.
As far as recipes for convection microwave ovens, there are many freely available online. Here are a number of links which will direct you to many examples of the types of resources currently available on the internet:
http://www.bellaonline.com/articles/art27624.asp
http://easyconvectionmicrowaverecipes.blogspot.com/
http://www.ifood.tv/network/convection_microwave/recipes
http://www.lifestylefood.com.au/recipes/collections/convection-oven-recipes.aspx
http://members.datafast.net.au/kristen/microwaverecipes.html
http://www.recipe-greeting-cards.com/microwave.asp
Just use your mouse to click on any of the six highlighted recipe resource links above which will then open a new browser window for you automatically and allow you to view the information at the website indicated.
Please COMMENT back here to this page if you have any details to add, have any questions, have difficulty accessing the links, or just require further general assistance and I will respond as soon as I see it.
BEFORE leaving a rating OTHER THAN 5 STARS or a negative TESTIMONIAL, please contact me and I will immediately clear up any concerns or answer any additional questions that you might have until you are completely satisfied with the service provided. The FixYa rating system is a very important component of the Marketplace, and unfortunately once you post a rating or a testimonial to a solution, it cannot be changed at all later on.
Be sure to use the small blue ADD A COMMENT button located just below the text of this solution to leave any additional comments for me regarding this particular issue and I will respond right away.
I truly hope that was helpful to you.
Good luck and take care.
Joe.
Oct 26, 2011 • Ovens
Microwave heats fine, finishes timed amount, press end, open door and microwave keeps going like door is closed. Is this a malfunction that requires a recall? Sharp Carosel
Hi - I'm not sure about a recall but certainly not safe to use as you have exposed yourself to radiation if the oven runs with the door open.
Common sense must prevail here - there is a high possibility the door switch(s) is faulty - have it checked thoroughly by a serviceman and check with the company if there were known problems with the particular model in question.
I find it extremely rare for something like you have experienced to occur - have never come across this problem ever - the microwave circuits are meticulously designed to have three door switches to eliminate the very problem described by you.
A but concerned...
Jul 13, 2011 • Sharp Ovens
The bracket which holds the ceiling heating element up in the microwave broke so now the heating element is hanging down into the microwave cavity. How do I get a replacement part and is it easy to...
The brackets are usually made of heat resistant plastic, or bakalite, you can search for parts at www.whitegoods.co.uk but you will need model and serial number, a word of caution, the microwave oven may have to be dismanteled to fix new element holders, you can still get shocks from them even though the mains power has been disconnected, depending on the age of the appliance and availability of parts, it may be a replacement is required.
Hope this has been helpful
john
1helpful
Hello, might you have a manual for GE Microwave oven model #WES1130DMBB. Thank you in advance.
First of all, here is the main ONLINE SUPPORT page for your model:
http://products.geappliances.com/ApplProducts/Dispatcher?REQUEST=SpecPage&Sku=WES1130DMWW
And here is a direct link to the ONLINE USER'S MANUAL for that model:
http://products.geappliances.com/MarketingObjectRetrieval/Dispatcher?RequestType=PDF&Name=49-40566-1.pdf
To view the Support Page or the Owner's Manual with Operating Instructions just use your mouse to click on the link, which is the underlined and highlighted text just above. This will open a new web browser page automatically for you and allow you to view the information at the website indicated or the contents of the Owner's Manual.
You may need ADOBE READER installed on your computer to read PDF documents. You can download this free at WWW.ADOBE.COM if necessary. Click on the DOWNLOAD ADOBE READER button on right side of the ADOBE home page when you get there, and then just follow the onscreen instructions to install it.
Please comment back here to this page if you have any questions, have difficulty accessing the links, or just require further general assistance and I will respond as soon as I see it.
Thank you very much and good luck.
Joe.
Apr 15, 2011 • GE Ovens
4helpful
4answers
KEMC308 Microwave oven door
Had the same problem and bought the part online. It's not difficult to replace, simply hold the door by the handle as you loosen the 2 screws. Put the face of the door on the floor and remove 2 screws holding the plastic insert. You will have to remove the front vent panel (2 Screws) just below the microwave door.Then you might have to move the oven vent over to get to the final 2 screws on the bottom of the plastic panel. Once you have the palstic panel off the springs are exposed, simply look at how it is placed in the holder before you remove the damaged one. Replace and then re-assemle the door.
Whirlpool oven/combo unit
http://www.repairclinic.com/SmartSearch/smartsearch.aspx go here enter your model number then under parts select all parts not listed and its on page two
Feb 08, 2008 • Ovens
Top Ovens Experts
ZJ Limited
ZJ Limited
john h
Are you an Oven Expert? Answer questions, earn points and help others
