Question about Panasonic NN-P295SF Microwave Oven
New Microwave not working
My New Microwave was installed today and did not work. Fan and everything working but not the oven. The model is NN-P295 Inverter, 1100w. I tried what the manual said, but did not work at all.
  • Panasonic Master
  • 9,098 Answers
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If it's still not working, you'll need to contact your nearest Panasonic-authorized servicer.
Posted on Aug 24, 2008
The Mocrowave Panasonic NN P295 stopped working. Not a single light is on. I checked the power at the receptacle - is OK. May be the fuse inside the microwave was blown. How can I replace the fuse. Where...
Did you recently have trouble with the cooktop lights?
Sometimes when the cooktop lights blow or are inserted or removed while the oven is still plugged in, the filaments can short, causing a surge that damages the controller.
They can be repaired. More details here.
Nov 05, 2011 | Panasonic NN-P295SF Microwave Oven
Where is the thermal switch located
If your model is NN-P295, then the service manual is here.
You can order Panasonic parts from
Encompass here.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Most microwaves have a thermal cutout or thermostat on the magnetron, on the top of the cooking cavity, and often on the floor of the oven or above the bottom cover.
Jul 13, 2011 | Panasonic NN-P295SF Microwave Oven
My NN-P295 wouldn't allow me to turn off the light about a week ago, so it remained on all the time. Then last night it was making a strange clicking noise. I got up to find the source of the noise and the...
It sounds to me you have short in the keypad controller system, from your description this is a very dangerous fire hazard situation, and the microwave in my view should replaced.
Feb 21, 2011 | Panasonic Microwave Ovens
We have a Panasonic Microwave. model number NN-P295 1100W. We had a leak above our microwave 3 days ago. The fan immediately came on and will not shut off. No features will work on the microwave. We...
This not good! from your description the problem is in the keypad controller, on the back of the keypad is a circuit board that contains the microprocessor and additional parts that control vital areas of the microwave oven. The leak has penetrated the vital areas where the electronics are housed, I suggest you replace the microwave oven because the cost will probably more than what a new one will run.
Feb 08, 2011 | Panasonic NN-P295SF Microwave Oven
My Panasonic nn-s262 microwave/fan keeps reseting every time I try to use the microwave. The fan works fine and the light worked fine until today, it now resets the microwave. What can it be?
internal short that can damage your control panel but do not try to fix it yourself its got 4000v !!! sorry :( your life worth more then this microwave.
Dec 30, 2009 | Panasonic NN-S262SF Microwave Oven
Panasonic NN-P295 Cooktop Light not working
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid in about a week.
At our Web site, you can get details of our service, plus we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
This can often also affect the exhaust fan operation, too. The lights and fan can be inoperable or stuck on too.
Feel free to contact me directly (and please remind me of your full model number) for more information & help.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Jan 23, 2009 | Panasonic NN-P295SF Microwave Oven
Pansonic model nn-p295 over the range microwave oven
In most cases, this is a problem with the inverter or a bad magnetron.
Due to the lethal voltages used and produced, I do not recommend that an inexperienced person work on these.
I would recommend that you contact your nearest Panasonic-authorized servicer. You can find one here:
http://www2.panasonic.com/webapp/wcs/stores/servlet/vServiceLocator?storeId=15001
We're happy to help and we appreciate your thoughtful rating of our answer.
Nov 28, 2007 | Panasonic NN-P294SF Microwave Oven
Panasonic NN-P295SF Microwave Oven Logo
262 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
