Question about Hampton Bay Heating & Cooling
I have a Hampton Bay fan model FE4-50S2dO Ineed wireing info for 3speed switch
SOURCE: broken globe on Hampton Bay Ceiling Fan (Vercelli model HD278017)
My fan just stopped working - no lights no fan :( and I just can't seem to find any type of switch - only the remote, which lights up just fine. Can anyone help???
Posted on Jun 08, 2008
  • 79 Answers
SOURCE: Fan switch broken, wires out when opened
I googled Hampton Bay Manufacturing and this is what I found:
Hampton Bay fans are manufactured by "King of Fans Manufacturing, FL". The contact number for them is 800-330-3267. ...
Maybe they can supply you with a wiring diagram.
Posted on Jun 11, 2008
SOURCE: I'm selling a Hampton Bay
As long as you have the remote and the receiver that go in the top it will work
Posted on Jan 21, 2009
  • 10865 Answers
SOURCE: i bought a hampton bay ceiling fan model uc7083t but i didn't
hi there i can help. There is a "dip switch" on nearly all fan remote units, much like a garage door opener has. To keep all the fans in your home from operating at one time, each fan needs a seperate "code". To use your other remote, you need to locate the receiver unit in the fan, usually in the "canopy". This is the bowl looking piece against the ceiling. then note the "code" which is the position of the switches. For instance, most have a block with 4 switches, and if the first is "on", and the remaining are "off", that is it's set code. This "code" can be changed to any combination of "on , off" that you like. BUT, you must also open the remote control and set it's switch to the exact same "Code", or order of "on off" as your Fan receiver. (Usually the control "Dip switch" is in the battery compartment.
Posted on Jun 20, 2009
Need Wiring Diagram of Hampton Bay fan model 68168
Race, Link below is your manual with the wiring hook up.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://www.homedepot.com/catalog/pdfimages/c6/c61d23c0-2ae9-465c-bad7-5ec275986b1c.pdf
HAMPTON BAY ALTURA Use And Care Manual
Jun 16, 2016 | Hampton Bay Dryers
Westinghouse 3speed fan switch 77288
It's the westinghouse switch. Many results on search. I just wasted 2 hours playing switching wires all combos. Others suggested the switch from Lowe's. Harbor breeze #0033905 . Plug wires back in as you listed Black L, Grey 1, Brown 2, Purple 3. Works perfectly for $3.98 plus tax.
Others said you can call Hampton Bay and get the replacement also.
Sep 24, 2013 | Hampton Bay Dryers
Hampton Bay Ceiling fan will not come on
greetings home electrition
it's most likely the switch has failed
but on rare ocation the switch comes un wired
also somtimes the switches stick they stick in the on or off position
try pulling the chain and listen for the usual click if it aint there then the switch is pooch if click is there start look at the wires failing that replace the switch
there cheep 2-5.00
Jul 29, 2009 | Hampton Bay AC414-LRU 52'' Kemper...
3-speed switch replaced with hampton bay switch. Only low speed works.
The cause to the problem was replacing a HUNTER fan switch with a Hampton Bay switch. Before removing the old switch, I noted and marked the color and position of the 4 wires. I then duplicated the connections to the new switch.
But the wire positions of Hampton Bay vs Hunter are not identical, therefore 2 wires
were crossed.
The correct way is to note the color of the wires with the corresponding NUMBER
marked on the switches, then duplicate this on the new one.
Du-uh!
Jul 23, 2008 | Hunter 23852 Classic Original Ceiling Fan
Jun 08, 2008 | Dryers
Need Wiring instructions
no problem just wire the black to black and white to white. connect the ground and cap off the blue wire, its used only for ooptional light assy
Apr 03, 2008 | Hampton Bay 73554 Antigua Ceiling Fan
Heating & Cooling Logo
54 people viewed this question
Top Hampton Bay Heating & Cooling Experts
Tim Whalen
Pete Norton
Are you a Hampton Bay Heating and Cooling Expert? Answer questions, earn points and help others
