Question about HP Pavilion ze2000 Notebook
How would I go about fixing the cermet capacitor short???
Download multimedia audio controller
Posted on Aug 28, 2008
Fix backlight on la40s581b
Check and replace the backlight inverter board. Do not think that it works only with some capacitors. The inverter transformers are the main component on that board, and always gets shorted inside, and is irrepariable.
Feb 25, 2013 | Samsung LA Televison & Video
GE microwave says "shorted keypad", what causes this? How can I fix it?
a shorted keypad is when the tiny capacitors across the keypad,become shorted,the only fix is to replace the membrane keypad........no fix
Dec 14, 2012 | GE Profile PVM1970SRSS 1.9 Cu. Ft....
I have a Bryant AC when it gets hot the fan stops, when it cools down the fan starts back again.
The fan motor is going bad... replace the motor...
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
AirConditioner Trouble - Review the Possibilities
heatman101
Jul 12, 2011 | Bryant Heating & Cooling
Coleman rooftop air conditioner - Unit's fan works well, but when turned to A/C, the compressor short cycles: 2-3 sec on, then off for 15 sec, then on / off again. The compressor gets pretty hot...
It could very well be the capacitor which I would check first because it is a cheap fix. If the capacitor looks pregnant or swollen it could be shorted. You can check it with an ohm meter if you have one. Disconnect the capacitor, writing down where the wires go. Set the ohm meter on the highest ohm setting, and touch the leads to both sides of the capacitor. If the needle goes up and then bleeds back down, the capacitor is good. If the need goes up and stays up, the cap is shorted. If it doesn't move at all, the cap is open. Either shorted or open, it needs to be changed.
Worst case could be that the compressor is "locking up" or the piston is swollen and will not pump but for a few seconds before is seizes. This would mean a bad compressor. Hope this helps.
Jul 03, 2011 | Coleman Mach III Air Conditioner
My pool pump is humming then turns off
If the armature will rotate freely and the bearings are not frozen, then it's probably a bad start capacitor. They are not very expensive compared to a new motor so it might be worth replacing it to see if it's bad.
Sep 08, 2010 | AO Smith Pool Pump Motor Hayward Swimming...
Loud hum out of BaseCube 12 subwoofer
Actually I"m having the same problem. It is most probably the capacitors on the power supply internally. they are known to dry out and go back. cheap easy fix by a competent electronics repair facility. Also Cambridge will fix it for $75 plus shipping
Apr 20, 2010 | Cambridge Soundworks BassCube 12 Speaker
My computer refuses to power-up....I changed batteries/power supplies from an identical machine, and nothing.
When you plug it on the wall do you see the battery charging indicator?
This could also be because of overheating the power socket may have gone bad.
The ze2202AP,AMD sempron2800,not power on,the problem is one cermet capacitor short,part number PC35 10u/35v.It is 927245a.jpgin the 18VDC input circuit.
Jun 16, 2009 | HP Pavilion ze2000 Notebook
POWER FAILURE
you must look around for the reson of this burning look for burnt resisttor--explosive capacitor-----short circuit capacitors----short of winding in pulse transformer-----circuit diagram will be helpful.
Aug 09, 2008 | Sony DAV-SC5 System
AstarLTV-30-MA power supplie board
If the problem is with the power supply, that is an easy fix; even without the schematic diagram.
Is normally some leaky capacitors that failed on the majority of power supplies on these TVs.
Feb 22, 2008 | Astar LTV-2701 27 in. HD-Ready LCD...
Gold Star GWHD5000 capacitors.
If all your doing is washing it out and fixing bent fins it's not necessary to discharge the capacitors. I would only discharge them if I was disassembling it to the point that the capacitors were out in the open or there was a change I could touch the wires on them. To discharge any capacitor is pretty simple really, first make sure the airconditioner is UNPLUGGED , then using two screwdrivers, make sure that you are holding onto the INSULATED HANDLES ONLY, put the tips of the screwdrivers on the terminal connectors on the capacitor and cross the screwdrivers. Sometimes, depending on the capacitor, it is possible to do this with only one screwdriver by shorting across the terminals with the shank of the screwdriver. Just make sure the A/C is UNPLUGGED and you are holding onto the handle ONLY.
Feb 07, 2008 | LG Goldstar GWHD5000 wall/window Air...
HP Pavilion ze2000 Notebook Logo
131 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
