Question about Kenmore Elite 45986 Front Load Washer
HELP!! My washer won't spin!! We cleaned the filter and now it comes up with a F11 code....what is this one???
    President:
  • 1,952 Answers
02 clean drain hose code codes control locked dl door error f02 F11 f2 Kenmore Elite Kenmore Elite Top Load Washer manual pump smell spin sud
Posted on Aug 24, 2008
  • 12 Answers
We've had this problem for about a yr when i finally firgured out how to correct it.
the problem is that the circuit board is attached to the washer, when it starts to shake it causes the connections to loosen and theats the fault code you get.
How I fixed this was to suspend the circuit from a bungie strap this will allow the washer to shake all it wants and the circuit board is stable, connections stay tight andwasher works fine, after 6 months not one error code at all
  • 97 Answers
SOURCE: What does F11 code mean?
F11 is a code that referes to communication error between the central control unit and the motor control unit. Disconnect power. Check wire harness connections to motor and control board. Check drive belt, visually inspect to see if belt is broke. Check drive motor, visually confirm motor operation. It is possible that if the belt broke it may have slung around in the cabinet and damaged or loosened the wire harness connection at the motor. Try unplugging wire harness at motor and then plug it back in securely. Hope this info has helped. Thanks, Tim.
Posted on Jul 13, 2009
pride applia
  • 232 Answers
SOURCE: Kenmore Elite quietpak9 HE4T washer FH error code
go 2 repair clinic on line, same codes for whirlpool duet repair help then error code tab
Posted on Dec 24, 2009
SOURCE: KENMORE washer goes into spin cycle washer stops code f11 appears
unpug for 30 min, resets ccu
Posted on Jan 24, 2010
SOURCE: F11 error
The F11 fault is the motor. I have had this issue myself and found that replacing the contact brushes solved this. The brushes on most electric motors are made from carbon, and wear down with use. They are spring loaded but have a limited life span. These are also cheap to purchase.
Posted on Feb 08, 2010
  • 1382 Answers
SOURCE: stops on spin cycle and gives a f11 error code
F11 is a serial communication error. Communication between the main board and the motor control board is not being sent correctly. This could be a bad main board, motor control board or motor itself. The testing can get pretty involved. Try putting the machine in a self test mode and see if the error clears. Press Cancel, then by pressing the drain spin button once on the left side then move to the spin speed button the the right. Press this button until no-spin lights. Press the prewash button 4 times. C00 should appear in the display. Let it run it's tests, there will be 8 of them and end up on C08. If this doesn't work, it's best you wait for the service tech.
Posted on Mar 30, 2010
Whash machine
The symptoms are pretty specific for the F11 code on the Whirlpool Duet front loaders and clones (Kenmore Elite and KitchenAid):
If the washer starts to fill but the drum NEVER moves, your MCU is bad
If the washer runs through most of a cycle and then gives the F11 before (or during) a rinse or spin cycle, then you have the CCU relay problem.
If you are interested in having me repair your CCU for you, I offer that service on eBay (website coming soon). My username there is "jhagner"
Thanks
Feb 04, 2014 | Kenmore HE4t 3.8 Cu. Ft. King Size...
My washer did fill, but won't spin or drain now and the door won't open
Hi tragz,
If it can't drain, it won't spin. There may be something preventing the pump from draining in the Pump filter. You will need to clean it.
Please follow my below Tip on how to do it:
ACCESS, DRAIN & CLEAN THE DRAIN PUMP FILTER
Kind Regards d")
* If this solution helped you, please rate it
Aug 05, 2011 | Kenmore HE2 Plus Front Load Washer
I keeg getting the dreaded F11 anf DL code!
The following list of codes indicates an electronics communication problem with the washer:
Duet HT® washer - F01, F03, F06, F11, F23, F24, F27, F28, F29, F30, F31, F32, F35, F42, F61, F62, F63, F64, F65, F70, F71, and F99
Duet® washer - F05, F07, F09, F10, F11, F13, F14, F15, F21, F22, and FdU
Duet SportTM washer - F01, F11, F23, F24, F27, F28, F29, F30, F31, and F33
PLACEHOLDER FOR ART
To remove the error display, press Pause/Cancel twice.
If Pause/Cancel does not work:
  1. Unplug washer or disconnect power for one minute.
  2. Plug in washer or reconnect power.
  3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, then call for service.
Take care
Jun 22, 2010 | Whirlpool GHW9400 Front Load Washer
Washer will not spin all the way out
had this problem so husband opened front bottom pannel and drain was cloged bad. the maker should have made a filter to solve this problem. after cleaning it worked fine till now getting f11 code.
Apr 27, 2010 | GE WSXH208A Front Load Washer
F11 error lights flash then stops at last spin . I did clean the filter and took some coins out Whirlpool AWM8163 washer
Jan 23, 2010 | Whirlpool AWM8163 Front Load Washer
My washer keeps coming up with errors
You have a right mixture of errors,
F11 indicates that the pump is not working.
F05 indicates that the pressure switch is jammed on full.
F04 indicates that the pressure switch is jammed on empty.
I would start by checking the pump is working o/k.
Next locate and clean filter.
This can be found by removing the rear panel of washer.
Locate and remove large black hose onto tub, remove filter and clean, refit same, make sure hose is on properly.
Test for leaks.
If no improvement, then I think your only option is to call an engineer out as it could become quite involved.
Good luck.
Plz rate my solution.
Thanks.
Jan 19, 2009 | Hotpoint Aquarius WD640 Front Load...
Error code f35 on my washer
NOTE: If the error remains on the display, call for service.
Dec 19, 2008 | Whirlpool Duet GHW9150P Front Load Washer
F11 code on my HE4t washer
I fixed this myself for $30 and an hour of time.
Took hi-res photos and created a step by step guide.
www.he4tf11.blogspot.com
Dec 09, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite 45986 Front Load Washer Logo
450 people viewed this question
Sal De
fordexpert
Robert Rankin
