PC Laptops
Problem for PC Laptops
Generic problem for all PC Laptops
Laptop LCD screen failure
By Symphony2 on Aug 24, 2008
I was sitting awkwardly in a chair with my laptop and I think I pressed on opposite corners, perhaps separating something internally. My screen went haywire, splitting into lines that rand up and down, very wavy. Naturally I shut it off. The screen has never turned back on. I attempted hooking up an external screen to see if it was the LCD itself, but that didn't work, so I assume it is the video portion of the motherboard itself. Sound about right? Using my rudimentary knowledge, I dismantled the case, but was unable to find any obvious internal damage, like something being unplugged or snapped. The computer will boot up, there is simply no display.
If it is the motherboard, should I attempt to change it out on my own, or take that in to a professional?
Comments:
Aug 24, 2008
- Yes, I did, I have used external monitors before. There was no output whatsoever.
Same Problem
Feb 02, 2009
-   Inspirion E1705: 2/3's of the screen is fine, bottom half is grey and white vertical lines. Out of warranty. The lid is kind of loose.... Is it worth fixing?
-   Guest
Jan 27, 2009
-   I have a Dell Precision M60 laptop. The other day the screen just went blank and the computer crashed. I was able to reboot after a ninute or so into setup but the creen stated showing grey, blank vertical lines, then black and white dots and finally nothing at all at which time the computer appeared to have copletely crashed. The screen is fine for it occasionally works for a brief period before the line appear. What part could be causing the problem? Any ideas?-   fjsd50
Jan 19, 2009
-   hey there i just bought a replacement screen for an aspire 5100 and i put it in and nothing is coming up on it at all. i know theat everything is hooked up but i was wondering if the screen has to be grounded to the inverter. the new (cheap) lcd does not have a bracket on it to screw into the inverter like the original one and i was wondering if that could be the problem -   joeljubicic
Oct 29, 2008
-   lcd blank -   ej69
Best Solution
posted on Sep 07, 2008
Helpful)
crytalburner
Rank: Apprentice
Rating: 85%, 1 votes
replace the lcd at http://www.laptop-lcd-screen.co.uk
Was this helpful?
Yes
No
Solution #2
posted on Aug 24, 2008
Somewhat Helpful)
aayushik
Rank: Wiz
Rating: 75%, 33 votes
when you hooked up ur laptop to an external monitor, did you adjust the display settings, you have to do that if ur operating system is xp or older.
Comments:
Aug 24, 2008
- is there any damage on the hinge?
Was this helpful?
Yes
No
Solution #3
posted on Feb 07, 2009
Somewhat Helpful)
jemker
Rank: Apprentice
Rating: 75%, 1 votes
You cant adjust the display settings if there is no video genius.
Answer to the question, sounds like the video card.
Was this helpful?
Yes
No
Solution #4
posted on Sep 15, 2008
Not Rated)
semperfied
Rank: Apprentice
Rating: 0%, 0 votes
My Compaq Presario M2105's screen stopped working on its own (no trauma) and I did the same thing, I tried hooking up an external monitor when the OS is Microsoft XP. The external monitor came right on and I can use the laptop in that way. Check out the .pdf on their website http://h10025.www1.hp.com/ewfrf/wc/siteHome?lc=en&cc=us&dlc=en
Was this helpful?
Yes
No
Popular Solutions for PC Laptops
Questions and Unsolved Problems for PC Laptops
Answer
the best site i have ever visited,,, thanks fixya guys
Answer
cannot open CD room and cannot start computor to get into operationg system can get into BIOS area... (More)
Answer
control F11 will take a Dell computer back to the day it was new. Can this computer do the same?
Answer
emachine m6810 how do I open the case need to replace or soldier the dc input connector. Unit will... (More)
Answer
My web camera wouldn't go on just now when I was talking to someone on skype and so they couldn't... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For PC Laptops:
Top PC Laptop Experts
Rank: Guru Guru
Solutions: 773
Experience: 30 Years of professional repair and design.
Ask Me
Find more PC Laptop Experts
Top Computer & Laptop Repair
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
