Question about Durabrand Televison & Video
Remote the remote to my tv is broken how do I get to game mode
I think it may have been more helpful if it was written in ENGLISH !!!!!!!!!!
Posted on Sep 27, 2008
    President:
  • 1,952 Answers
Use new remote
Posted on Aug 24, 2008
  • mohammed marika thambi
    mohammed marika thambi Aug 24, 2008
    u will use tv menu to game but not satisfied be you need new remote
I'm trying to get my TV into game mode. How do I do that?
Please try the following:
  • With the TV on, press the Menu button which will take you to the main menu
  • Then select the "Setup Menu" and press enter
  • Select "Game Mode" and press enter
  • Select "On" and press enter
  • Then press Exit to leave the main menu
These steps should get you going, however if you have trouble please tell me the exact model of your Samsung TV and I can give you further instructions:
Feb 28, 2011 | Samsung Televison & Video
Tv is stock on tv mode. How to change to game mode?
You need the remote to change to game mode. The original remote doesn't appear to be available. A substitute remote with the function is here: http://www.remotes.com/remotes/servlet/rs?a=Search&o=c&uid=0&m=DWT2405&uuid=12931247714820 . The Game button switches to and from game mode. Other universal remotes may work but a source or input button is needed. Then try various codes for either Durabrand or Funai TVs (Funai built the TV). The other issue is that the remote needs to have been programmed at least 6 months after the TV was released. The remotes that are programmed via a USB connection to a computer will definately be able to match the function.
I hope this helps.
Dec 23, 2010 | Durabrand DWT2405 24" TV
How to get universal remote to turn the tv to game mode
I don't know if this can be done with a universal remote, but if you can let me know which brand and model of universal remote you are using, I will check if it is possible. If your universal remote has an "AV", "SOURCE" or "INPUT" button, try these but make sure the game system is switched on so you are able to see if/when you have changed to the correct mode.
If you don't have the original Symphonic remote, you should be able to switch the TV to game mode using the buttons on the front of the TV as follows:
1. Switch the game system on
2. Press the "MENU" button on the front of the TV
3. Highlight "PICTURE" using the CHANNEL UP/DOWN buttons
4. Press the VOLUME UP button once to enter the PICTURE menu
5. Highlight "GAME MODE" using the CHANNEL UP/DOWN buttons
6. Use the VOLUME UP/DOWN buttons to set "GAME MODE" to "ON"
7. Press "MENU" to exit the menu and play games.
The menu should automatically close anyway if you don't press any buttons for about 15 seconds.
When you have finished playing your game, repeat the above steps to set "GAME MODE" back to "OFF" and return to watching TV.
Hope this helps. Please post back for further assistance if needed.
Regards,
BElectric.
Dec 23, 2010 | Symphonic ST419E TV
How to change the tv mode. Its on AV mode and i want to change it back to TV mode
Hello
You can set the Game mode and External input mode at the same time by pressing the GAME button on the remote control. "GAME" appears on the TV screen. To exit the the Game mode and the external input mode, press the GAME button on the remote control again. To cancel GAME mode only, adjust the PICTURE control. The game mode will be set ot 'OFF" automatically. In this case "VIDEO" instead of "GAME" appeares on the TV screen. When you press the GAME button if the TV is off, the TV turns ON and will be in the GAME mode and external input mode automatically.
Nov 06, 2010 | Durabrand DWT1304 13" TV
How do I get the game mode back on?
[USING THE GAME BUTTON]
You may also set the Game mode and external
GAME button on the remote control. “GAME”
● To exit the Game mode and external input
control again.
● To cancel the Game mode only, adjust the
picture control. The Game mode will be set to
[OFF] automatically as explained in the previous
section. In this case, “VIDEO”(external
input mode) instead of “GAME” appears on
the TV screen.
● When you press the GAME button if the TV is
off, the TV turns on and will be in the Game
good luck
Jan 30, 2010 | Durabrand DWT1304 13" TV
How to get TV off game mode without remote (not a
is there a TV/Video or menu button on the front of the tv? if so try the tv/video button, that should scroll through the the components you have on your tv. dvd, game cable etc. If no tv/video, hit the menu button and then use either channel up/down or volume up/down to scroll through your component options.
Dec 27, 2009 | Sylvania 6427TE 27" TV
Help with Game Mode/Channel Switch Please!
Go to Radio Shack and get an universal remote control, i have a Phillips Universal for mine. it has a tv/vcr button that also is an "input" button to switch channels to do this.
Aug 26, 2008 | Symphonic ST420FF 20" TV
Broken remote, can't access video mode
800-256-2487 customer service number for your manufacturer
Jun 14, 2008 | Symphonic ST427FF TV
Game Mode
problem solved,I did what everyone else seemed to do. The remote had a tv/vid button and it worked to set the game mode. All solved.
Mar 06, 2008 | One For All URC-3021 Remote Control
Dwt 1905 tv stuck in game mode
Comcast universal remote code for dwt 1905 is 0171, just tried it, it works
Nov 26, 2007 | Durabrand DWT1905 TV
Televison & Video Logo
54 people viewed this question
Top Durabrand Televison & Video Experts
matt martin
matt martin
Are you a Durabrand Televison and Video Expert? Answer questions, earn points and help others
