Question about Kenmore Elite 45986 Front Load Washer
Please Help!!! Hi Catriver! Thank you for the info on cleaning the drain. Mine was really in need of a cleaning:) However, the washer still goes into a non spin mode F11....is there another part that needs cleaning? Please help....I'm trying really hard not to call sears out!!!!
  • Anonymous Sep 05, 2008
    my kenmore elite 4E4T shows f-11 and sears says its the main computer board($400),i had a maytag before this one and it lasted 15yrs.without a problem,i will never buy a kenmore again.
  • 15,935 Answers
"F11" is a Serial Communications error between the Central Control Unit (CCU) and Motor Control Unit (MCU). The CCU is the main computer for the washer and is located directly behind the wash tub. The MCU is the Drive Motor Control board and is located in the rear of the washer adjacent to the Drive Motor on the left-hand side (facing from the rear with the back panel removed). The wiring harness can also cause the error, but it is not as common a problem.
Whirlpool is the manufacturer of both model washers and recommends the following troubleshooting advice. Remove the top panel of the washer by removing the three screws holding it in place in the rear. Once the screws are removed, the panel slides back, then off. Remove the rear panel of the washer for access to the drive motor and MCU. Now check the following:
- Check the wire harness connections between the CCU, the MCU and Drive Motor. Make sure all connections are attached and making good contact. Check for any broken wires or connector pins.
- Check the Drive Motor to see if it free spins and that the belt is still attached and not slipping. If the motor is seized, replace it. If the belt is broken or worn, replace it as well.
- Check the MCU. Connector 1 is the Serial Communications Link between the MCU and CCU. Connector 2 is the connector to the drive motor. Resistance checks across pins 1, 2, & 3 are the motor windings. Connector 3 is the power supply - 120VAC should be read across pins 1 and 2 with the door in the locked position. NOTE: The connectors are read 1, 2, and 3 from the bottom to the top with the MCU installed.
- Check the CCU. Verify connectors 7 and 11 are properly installed. Facing from the front of the washer, connector 7 is the 4th connector from the RIGHT along the front. This is MCU Power. Connector 11 is the Serial Communications link from the CCU to the MCU and is located along the left hand side of the CCU (the connectors are numbered 11 through 14 back to front).
- Check the Drive Motor. Remove the connector and perform resistance checks on the motor connector pins. Readings across pins 1 to 2, 2 to 3 and 1 to 3 should read 6 ohms.
In most cases this is an indication of a failed CCU. This is an easy repair that the average do-it-yourselfer can accomplish on their own. If the washer is still under a warranty, parts and labor would be covered. With no warranty, a replacement parts will vary in price depending on where you get them. There are several good websites available that you can order parts on line and have shipped directly to you.
NOTE: Remove all the connectors from the CCU ONE AT A TIME and reconnect to see if the error code goes away BEFORE you decide to purchase a new one. It is not common, but sometimes a flaky connection can generate error codes.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.^^@#$%$
Posted on Sep 29, 2010
Hi...thanks for helping me first of all. The washing machine will wash, but all of a sudden it has gotten really loud and it does not spin out all the way. Any ideas???
hi kyliesmommy1,
I believe your drain motor is not draining the water. This has to happen before your unit will go to the spin cycle.
Please read the following tip, on how to clean the filter (It might just be an obstruction of some kind)
ACCESSING, DRAINING & CLEANING THE DRAIN PUMP FILTER
If this does not help, you might need to replace the drain pump - as it may have become defective.
Kind Regards
JEDEMEYER1
* I really hope this solution helped you, if it did please rate it.
Jul 14, 2011 | LG WM2487H Front Load Washer
Washer will not pump out water and have cleaned the strainer
Depending on the specific model of your washer, probable culprit for "No Drain" with the strainer (filter) clean are:
  • stuck/defective drain valve;
  • defective drain pump/impeller;
  • kinks in or clog drain hose.
Please visually inspect/clean (and replace if needed) the above mentioned components.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Aug 01, 2008 | LG Washing Machines
DOES NOT DRAIN WATER
If motor runs or sounds like it is trying to run, you have a sock caught in the pump. If no noise at all you have a bad lid switch
Jun 07, 2007 | Kenmore 94812 Top Load Stacked Washer /...
Kenmore Elite Frontload washer
Dea, F02 is the code for long drain. Your filter on your pump is probably clogged with lint and stuff. You have to remove the bottom front panel, 3 screws. The panel will drop and come off. The filter cover is right in front. Get yourself a bunch of towels and unscrew the filter cover and twist the filter out. Clean out all the stuff and put it back in. See if the washer comes back to life...Catriver..post back
Apr 28, 2007 | Kenmore Elite 45986 Front Load Washer
Washer will fill and agitate but won't drain and spin
Tweetly, no spin, no drain, usually a sign of a broken lid switch. Also check the switch actuator on the lid. Lid switch part number 3949238. Check that out first and post back. Catriver.
Mar 22, 2007 | Kenmore 24712 Top Load Washer
Washer will not fill
Triple, sounds like you are siphoning. Pull the drain hose out from the drain hole. Make sure you have a air gap where the drain hose goes in. Try this first. Catriver..post back
Mar 12, 2007 | Roper RAS8244KQ Top Load Washer
Kenmore washer
Lori, first check the lid switch, if it's broken, it won't spin or drain. Put it into spin and hold the switch down, see if it drains. Check that first...Catriver..post back.
Feb 23, 2007 | Kenmore 20722
INQUIS SUPPERB II
Rick, if the lid switch was bad, you wouln't be able to drain. Sounds more like a coupler. This goes between the motor and trans. Easy fix. I will attach a photo of how to remove the cabinet and a picture of the coupler. The screws for the top console will be on the back on your model...Catriver..post back.
Oct 04, 2006 | Whirlpool LSB6200KQ Top Load Washer
Washer not rinsing or spinning but doea go around
Loakes, the first thing you want to check is the drain pump. Remove the lower panel and it will be on the right. If the pump is not working the washer of course will not drain and will not go into high spin speed. You will need to verify that first it is getting voltage and second there is nothing jammed in it. Get yourself a pan and a bunch of towels and remove the hoses to it. You will have a lot of water coming out at you. Check the pump impeller and see if something is caught in there. If you still have problems after doing this, some tests will have to be made to determine the problem...Catriver..post back.
Aug 28, 2006 | GE WSXH208A Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
Sal De
fordexpert
Robert Rankin
