Question about Dell Inspiron XPS M140 Notebook
XPS M140 Help Please
I did the Dell computer tune up and now all the computer does is keep re-booting can not do anything at all?????
    Genius:
  • 2,028 Answers
What tune up did you use exactly? Let me know this and I'll get back to you with what has happened.
Posted on Aug 24, 2008
I have a lot of errors on my dell xps m140. I tried looking up the process to reset my computer cause I install the operating system twice and now there are partitions and extra drives. I found one where i...
I suggest you use the Dell recovery installation disc to install Windows BUT instead of installing over the existing Windows directory, delete all the partitions and then create a single partition then install Windows of this single partition.
Nov 20, 2010 | Dell Inspiron XPS M140 Notebook
The dell logo flashes then the screen goes blank. The hard drive keep flashing like the laptop is booting up okay it is a xps m140 and has vista home as a o/s
After the logo flashes, press F8, repeatedly, until a white-over-black "boot menu" is displayed. Choose "Safe Mode", to see if this "minimal" version of Windows will startup successfully.
Dec 13, 2009 | Dell Inspiron XPS M140 Notebook
Need drivers to run windows 98se on dell xps m140
Microsoft (and Dell) stopped supporting Windows 98 a few years ago -- it lasted for over TEN years! So, it is *NOT* likely that you will find drivers for any computer that was "designed for Windows 2000" or "designed for Windows XP" or "designed for Vista".
So, in general, it is a _bad_ idea to connect any computer running Windows 98 to the Internet -- Microsoft has issued many "security-fixes" in the 4 years after they stopped supporting Windows 98 and Windows ME.
Nov 23, 2009 | Dell Inspiron XPS M140 Notebook
Dell XPS M140. No Sound. Checked lighted button,
Make sure any programs that consist of sound for example " Soundman" is running this can cause a conflict with your audio. Check for updates if you can
Jul 30, 2009 | Dell Inspiron XPS M140 Notebook
LCD screen is faint XPS M140
You backlight is failing. That is the bulb that provides the brightness to the screen. You need to replace bulb which is very tricky to do unlesss you have experience or replace the screen.
Please rate this if helpful.
Thanks
May 05, 2009 | Dell Inspiron XPS M140 Notebook
2007 DELL XPS M140 LAPTOP WILL LOCK DUE TO 256M MEMORY STICK
Normally you boot up the laptop without a memory stick in the USB port.
Check your BIOS settings for the boot up device order.
You should have the hard drive as the first boot device, you can have the CD as the first boot device and the hard drive as the second boot device.
You should not have the USB port as the first boot device.
Feb 02, 2009 | Dell Inspiron XPS M140 Notebook
Dell XPS M140 laptop shuts off after powering on
Most laptops that I have worked on that power off that quickly turned out to be an overheating problem. Is the cooling fan running for the brief period that you can hear the hard drive before it powers off ? If the fan is running another potential resolution might be to remove the processor and apply new thermal paste.
Nov 10, 2008 | Dell Inspiron XPS M140 Notebook
Dell XPS M140 Very Slow In Booting Up and General Use
Run a check disc, or hard drive test in the bios, if any part of the test fails, then the hard drive is failing and will need replaced. Delete anything from the start up section of the start menu/programs, and download and run CCleaner form filehippo.com, it will help keep your computer clean and running fast/smoother. Also, are you using Norton? If so, remove it and use the AVG. You can find it at File Hippo as well.
Aug 16, 2008 | Dell Inspiron XPS M140 Notebook
Dell Inspiron XPS M140 Notebook Logo
65 people viewed this question
Alun Cox
