Question about Dell Axim X50v Pocket PC
Digitizer does not work at all now
I replaced the digitizer and put my PDA back together, but the new digitizer does not work at all. The PDA comes on just fine but when it tells me to touch the screen to begin, no matter how many times I touch it, it will not respond. I sort of suspected the whole time that I was putting the new one in that it would not work anyway because the cable that comes out of it and attaches to the main board was located very slightly higher (toward the top of the unit) than the old one. Also, the cable itself was slightly longer, so that there was more slack when I connected it. This seems very strange to me, though, because in tiny print on the cable, I could see "x50v," so I know it it supposed to be the right part. I would appreciate your help. Thanks.
  • Dell Master
  • 13,433 Answers
Does the new digitizer have the same connector? does it fit in correcty? double check that its well in place, the slack does not matter at all.
Posted on Aug 24, 2008
I just replaced the digitizer and now my screen just has blue red white vertical lines and the touch screen is not working
if it was a complete digitizer and you are getting the color send it back and get another one .it is no good , take your connector plugs back and put them on with out putting it together , it should work this way , go on youtube and ck it out
Apr 25, 2015 | Apple iPhone 5
Digitizer Problem
The digitizer could be bad or it's the wrong model type.
Dec 02, 2014 | Nokia Lumia 920
Replaced screen and digitizer
This could be one of two issues:
1. The cable for the digitizer may have come loose them you put the iPhone back together.
2. The digitizer may be faulty.
Mar 20, 2014 | Apple iPhone 3G
Touch screen is not working, screen comes on as u can see but does not even calibrate. I don't no if I need a new screen or something else
You definitely need to replace the digitizer if possible. Your LCD seems to be fine but the digitizer is either unplugged from the motherboard of the device or is simply in need of replacing. Unfortunately many phones these days have the LCD and DIgitizer fused together and you will have to buy and replace them both as one touchscreen panel.
Oct 07, 2012 | Cell Phones
My palm tx stylus cannot press anything and i have to put in a unlock password (which i know) but i don't want to have to do a hard reset.
If you have the password then you should be able ot make this work. The 5-way button works like a (very annoying) joystick or mouse. You should be able to use that to navigate around instead of the stylus. Once you get into the tx then you want to run the prefs and then the screen calibration. That should get your stylus working.
Unfortunately this can also be the digitizer having failed. There is no driver or reconfig for this so you need to replace the hardware. You can usually purchase the digitizer and screen for about $45. There are dozens of PDA repair shops that sell palm parts. These shops will sell the digitizer (usually with the screen) and they will offer the repair service. This is a repair you can tackle at home. You need jewellers screwdrivers, an old credit card (to pry apart the case without making marks) and a 5 or 5.5 torx screw driver. If you look on the various pda parts web sites you will find instructional videos on doing this. Watch them and see if that looks like something to try (it should, it's actually very easy) then order your parts. This is also a good excuse to replace the battery as it needs to come out anyway so maybe get a new one at the same time.
To find the parts or a repair just use google or bing and search for PDA repair parts. Almost all will have stuff for the various palms. Check out the prices for parts and repair (pays to shop around) but don;t forget to have a look at the instructions.
Oct 26, 2010 | Palm TX Handheld
Everlasting loop when trying to calibrate the touchscreen. After the touchscreen stopped working I did a (soft-) reset and tried to recalibrate the screen (went there using the navigation buttons) because...
If the above works, that's great and you must have really strong fingernails! I had the same problem and tried several of the solutions here, from cleaning around the edges of the screen, to soft and hard resets. They worked for a time, but eventually, the pointer didn't register at all. If simply opening and reconnecting the cable doesn't work, look on Ebay for the replacement digitizer. There are or were many when I looked, ranging from about $8 to considerably more. None of the low cost ones came with instructions, but did come with tools, stronger than my nails! Higher priced offerings were for having them replace the digitizer for you. I ordered the low priced one and hoped I could figure it out. The tools they send are two tiny screw drivers with special tips and a small plastic device to pry the sections apart. If you want to do it yourself, I will be happy to explain what I did. Remember to be really gentle when you do every step. First use the pry tool on the place where the cord plugs in to connect the device to the usb slot on your computer. It is tight, but gently pry out the small black rectangle. You will see two tiny screws inside. Remove those, carefully with one of the screwdrivers that come with the digitizer and set them someplace save. These two screws or bolts have nuts, that you can't really see until the next step. Watch for them if they fall out. The next step is to use the pry tool around the edges of the white plastic face of the Z22 and separate it from the back. I would lay it on the back while you do this. There is a small u-shaped piece that is part of the reset button and it fits on a peg on the back part of the device. Carefully ease the front and back apart. There are 4 small screws that still need to be removed. Save them to replace when done. Remove the innards of the device, but Don't totally separate the sections. There are foil connectors that attach the parts and they need to be intact. Gently ease the digitizer from the white plastic face. It will have another white plastic box on it's back side. Use the pry device to separate the glass digitizer from that white box. You will see there is a gold striped foil connector on your new digitizer, about midway up the side of the device. Find the one that is connected to the old digitizer and ease it out of the slot. Remove the old digitizer. Slide the new connector into the slot on the new digitizer. Position the new glass digitizer correctly over the white plastic box and place the innards face down into the white face of the Z22. Replace the 4 screws. Gently close the case, laying the front onto the back, so you don't displace the reset button part. Snap together and replace the two tiny screws into the section near the power cord connector. (Hopefully you didn't drop the little nuts out, during the process. If you did, you may have to back track until you can see the small white boxes that they slip into, in that location. Email me if you have problems with this. It sounds a lot worse than it was. When I finished, I was really disappointed, because it didn't turn on, the whole screen was black, which was worse than when I started. But, after I plugged it in, and let it charge about 3 hours, it worked perfectly! I am so excited! You can do this if you are patient and gentle.
Jun 15, 2009 | Palm Z22 Handheld
Tungsten T3 Digitizer
Digitizer is about half unplugged. To continue with this will tear the web. If you start a new request as a premium, I can tell you how to replace it. TY. Please post this as fixya.
Dec 26, 2008 | Targus PA870 Universal Wireless Foldable...
I have a iphone 3g got a replacement glass to replace the cracked one but it is only the screen. Am I better of getting a screen with a digitizer?
I recently had the same problem. You can buy the glass by itself (which you already know), but then you would have to chisel away all of the glass from the digitizer which is really risky, difficult, and may ruin the digitizer in the end. If your dropped your iPhone 3G and the glass cracked, you will need to purchase a new glass display AND digitizer. They will come together as the digitizer will already be glued to the glass display. This will cost you about $70 before shipping. If you are doing the repair yourself, you may want to consider getting a pry tool to help you take it apart (about $4). There are some youtube videos by PDA parts that show you how to take apart the phone. I ended up getting my glass display and digitizer from Mission Repair, as it comes with the adhesive strips you will need to afix the display to the frame. I got my pry tool from PDA Parts. Due to the lack of information out there about what to do when the glass on your iPhone 3g cracks, I ended up making a website to help people out. Soon I will have a video tutorial and as well as written instructions with pictures on how to replace the glass and digitizer yourself. The site is Good luck with the repair!
Oct 17, 2008 | Apple iPhone 3G
Cracked touchscreen
There is no need to replace the whloe lcdscreen, you just need to replace the touch screen & panel which is a thin glasstop on the top of the lcdscreen. The whole lcdscreen is expensive, while a touch panel is much cheaper than that. And we could provide all kinds of PDA accessories. Here are some information for you In general, PDA LCD screen comprises the touch screen. LCD screen acts as a display of PDA or SmartPhone, and the likes, which cannot go without LCD screen. Touch screen is short for touch screen digitizer which seizes the upper part of PDA LCD screen. It is pressure-tactile, runs with gentle touch of stylus, finger and other tele-pointing function-possessed device. Different from LCD screen, the touch screen is an optional component for PDA, SmartPhone, and the likes. A PDA can function well even without the assembling of a touch screen for the availability of keyboard.
Sep 09, 2007 | T-Mobile MDA
Dell Axim X50v Pocket PC Logo
229 people viewed this question
Alun Cox
