Question about Kenwood Audio Players & Recorders
CD cartridge stuck in Kenwood KDC C461
Hi! The cartridge is stuck in my Kenwood KDC C461 CD changer. I have removed power from the unit and removed it from my car to bring it inside. Before I screw something up, I'd like to know if you have any advice to un-stick it.
Thanks!
Michael Tipton
  • Anonymous Mar 19, 2014
    cd cartridge does not eject on a Kenwood KDC-C462
  • 2,071 Answers
If for some reason you would opt for user performed action, then pls try:
1. reset, unplug from the mains for at least an hour and try again;
2. check if there is a slide switch of some sort at the rear of the unit;
3. check if there may be a pinhole somewhere along the bottom of the loading tray where a blunted point safety pin maybe inserted;
4. open the top cover and manually eject the tray;
5. check internally if there is a mechanical problem such as a slipping/cut belt, gears that do not mesh correctly;
6. if the unit has been in use for some time, it may simply need cleaning and re-application of lubricant in the mechanical assembly.
The slider mechanism, depending on the age of the unit and , consists of the small chrome rail, a drive motor, a small gear assembly, and (in some units) a small belt that drives the slider unit via the motor. This small belt causes all sorts of problems. If the belt is broken or slipping, it can cause skipping, dropouts, or simply no start up at all. Also, if the belt breaks in the middle of the disc, the drive mechanism gets hair or dirt wrapped up into the gears, or the pick-up assembly doesn’t return to the start position (called home), the unit will (99% of the time) refuse to release the disc, causing it to become stuck inside the unit. There’s a little micro or leaf type switch located at home position that sometimes gets dirty or breaks and, causing this problem also.
DON'T FORGET TO RATE;
Posted on Aug 25, 2008
Kenwood 6 disc cd changer
screw needs to be replaced and making sure the bracket it not bent... thus , not allowing the cartridge to come out,,,
May 12, 2014 | Kenwood KDC-C465 6-Disc CD Changer
Where is the reset button on my kenwood kdc-c719 cd changer
there is no reset button, the reset is to disconnect power to the unit and see if it starts up ok, you do say problem but if it is loading problem then resetting it will not fix it.
Sep 18, 2010 | Kenwood KDC-C719 10-Disc CD Changer
Cartridge will not reject CD discs
i had this when i got one off ebay, take it apart (cover) usually 6 screws, the cartridge inserts may not be aligned inside (part cd sits in) if that is the case you need to remove it/them. it tokk me 40 mins of carefull prise and pull
Jul 01, 2010 | Kenwood KDC-C719 10-Disc CD Changer
Disc changer wont work. kenwood kdc-c461
have you tryed all the wires the power might not be going to it or 1 of the main wire might of come out. or might just have to get a new cd changer
Oct 31, 2009 | Kenwood KDC-X692 Car CD/ MP3 Player
Can't eject cd magazine - E-99 error message
I put a small pin in the reset button a few times and that then got the catridge to eject.
Apr 14, 2009 | Car Audio & Video
Kenwood KDC-C717 - E-99 error
Reset the unit ithe reset button is on the cd changer
Dec 01, 2008 | Kenwood KDC-MP205 CD Player
Compatability question
HI, Yes i managed to solve my problem by going to the website www.kenwood-electronics.co.uk
May 22, 2008 | Kenwood Car Audio & Video
Error message e099
Hi try resetting the unit, or down powering the changer. this could reset the unit. if not then it wil need to be repaired
May 22, 2008 | Kenwood KDC-CPS89MP 10-Disc CD Changer
515 people viewed this question
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Don Hart
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
