Question about Linksys Wireless-G WRT54G Router
Connection Ports How do I turn off the different ports on the wrt54g router
  • Steve Rand
    Steve Rand May 11, 2010
    Wow... i'm definitely not posting a "solution" for this one... mostly because i'm quite sure you can't do that. My WRT54GS has no option for shutting down ethernet ports, and i'm using third-party firmware that is much more flexible than Linksys' firmware.
    Now out of morbid curiousity... why? why do you want to turn them off? It won't save power... is it for security reasons? If so, just don't configure the hub part of the router for anything (or misconfigure it so that those ports are unusable)
  • 89 Answers
You cannot turn off the individual ports of a linksys wrt54g router. you can try to disable the local area connection of the computer that uses the particular port of the router.
Posted on Aug 24, 2008
The router is saying there is no internet connection from the router to the modem.. Please help cause i have internet from modem to computer..
That means that the communication is cut from router to modem. You need to find out what is the problem.
1. check if the network cable from is still working or properly connected2. try a different ethernet cable or network cable from router to modem3. try some other dsl ports (yellow ports) at the back of your modem for ethernet cable connection to the router.4. switch ends of the cable you are using
these steps should fix the problem for if you are going to analyze, the line break comes between the router and modem and the only means of communication of your router and modem are cable, modem port (for the network cable) and router port (for the network cable) which means that the problem is within that point only. This should fix the issue.
Dec 28, 2011 | Linksys Wireless-G WRT54G Router
Hello i need to open some ports in order for my ps3 will function properly..I need the Tcp ports open #'s (80)(443)(5223)(10070)(10080) and also need the UDP ports open #'s (3478)(3479)(3658)(10070) model...
LINKSYS ::::
NAT STRICT
Step 1 : Connect Router - Computer
Step 2 : Open Router Setup by typing http ://192.168.1.1
Step 3 : Click Applications and Gaming
Step 4 : Click DMZ
Step 5 : Select Enable and Give the IP Address of the XBOX/PS3/Wii in it
Step 6 : Click Save settings
Step 7 : Unplug the Power cord from the router and turn Off XBOX /PS3/Wii
Step 8 : Plug the power cord back to the router and wait till the lights are Solid
Step 9 : Turn on the Xbox/PS3/Wii
Step 10 : Test the Connection
Else ...
Under application and gaming you can find port range forward
There you can open the ports one by one
And give the IP Address of the PS3 for all the ports opened
Dec 21, 2010 | Linksys Wireless-G WRT54G Router
Configure Modem Echolife HG520s With WRT54G OR WRE54G
Not sure if I understand properly but your router should have a WAN port or an "Internet" port
your modem should be connected to it and your PC should be on any of the LAN port
Apr 04, 2009 | Linksys Wireless-G WRT54G Router
I have a wrt160n router hooked up to a desktop computer and a
Sound like you have a bad network card on the PC or the router ports have gone bad.
Have you tried different ports on the router?
The problem could also be in the ethernet cable.
Try another cable and see if that makes any difference.
Mar 12, 2009 | Linksys Wireless-G WRT54G Router
Need to add Linksys WRT54G-TM wireless router with Linksys SPA 2102 phone adapter
your SPA2102-R seems to have one ethernet connection and one internet connection.
your WRT54G-TM seems to have one internet connection and 4 ethernet connections.
What you are trying to achive is; plug a ethernet cable into the ethernet connection on your SPA2102-R then plug the other end into the internet port of the WRT54G-TM
hope this helps, I have assumed that you intend to use a DSL broadband supplier not ADSL.
if you are changing service from DSL to ADSL then your WRT54G-TM needs to be first in line configured and working. then plug the internet port from the SPA2102-R into any of the WRT54G-TM ethernet ports.
Nov 06, 2008 | Linksys Wireless-G WRT54G Router
Problem with wired connection
if it is the power suplly issue you could pick up a replacement power cord at radio shack I had the same issue with mine only I was in a rush and picked up a adjustable power supply from radio shack and taped the power tip to the router with 3m electrical tape corrected problem no more power lose. good luck hope this helps
Sep 11, 2008 | Linksys Wireless-G WRT54G Router
LimeWire
If the firewall is turned on you router you will have to turn off the ports that LimeWire uses.
Aug 04, 2008 | Linksys Wireless-G WRT54G Router
Add di-704p to an existing network
What you want to do should be quite easy:
1. Just connect one of the LAN ports of the DI-704P to a LAN port of your WRT54G. Try using a standard network cable. If the port status lights does not turn on on both sides when you connect the cable, use a "crossover" cable. Important: leave the DI-704P WAN port empty.
2. Disable the DHCP server on your DI-704P, your WRT54G will be the DHCP server.
3. Assign a static IP address to you DI-704P, different from your WRT54G. Example, if your WRT54G has 192.168.2.1, you may assign 192.168.2.4 to your DI-704P. Make sure that the IP address you assign is outside the DHCP range configured in your WRT54G and that the subnet mask is identical on both.
You will then be able to use your print server from any wired and wireless computer and the remaining LAN ports both on the WRT54G and DI-704P.
Feb 18, 2008 | D-Link DI-704P Router
Pls. help
When dealing with a router there are multiple IP address scenarios, on the internet service provider's (ISP) side you can have either a static or dynamic IP address. I believe most routers by default are set to accept a dynamic IP address from the ISP. Where the ISP permits the router can also assign IP addresses to each device that attaches to it allowing a single ISP connection to be shared by multiple computers. This is also generally the default for routers purchased for home use and the wireless adapters also accept the dynamic IP assignment from the Router. With the logical discussion out of the way I believe you wish to discuss the physical connections to be established. Again this is a generic discussion not knowing your specific environment. port types - I will refer to phone ports (technically RJ-11 either two or 4 wires (these cables plug snugly into phone jacks and modem connectors) and ethernet ports (technically RJ-45 which are 8 wires and to big to fit in phone and modem ports) First you have a connection provided by the ISP for DSL this is your phone line where filters are attached to your voice phones and an unfiltered phone connection goes into the DSL modem's phone port often with an ethernet port. If you have cable generally the cable company provides a connection to a cable modem which has an ethernet or other port to connect to your system. The ethernet port generally connects to the wan port (generally separate) of your wrt54g router with an ethernet cable. Computers can be attached to the wrt54g router using the 4 ethernet ports in a group provided they have an ethernet port too. Wireless cards connect to the wrt54g router through radio waves and with antennas on the router and often internal to the wireless adapter (often embedded in a notebook computer today). These details are enclosed with your ISP's instructions and the Linksys router instructions often with pictures to help the explanation.
see
http://www.linksys.com/servlet/Satellite?c=L_Product_C2&childpagename=US%2FLayout&pagename=Linksys%2FCommon%2FVisitorWrapper&cid=1149562300349
if you do not have the user manual.
Nov 30, 2007 | ASUS AAM6010EV Router
Linksys Wireless-G WRT54G Router Logo
64 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
