Question about Uniden 5.8GHz Dual Cordless Phone
7805 model need to do a soft reset - see post - did a # and * while rplacing the battery , but has not reset the phone correctly - registration fail message.
  • 1,800 Answers
1. Disconnect Battery from handset(s)
2. Disconnect Phone Cord from wall jack
3. Disconnect Phone cord from base unit
4. Disconnect AC adapter from wall outlet
5. Allow to sit for 30 min
6. Reconnect Phone Cord to base
7. Reconnect Phone cord to wall jack
8. Reconnect AC Adapter to wall outlet
9. Reconnect Battery to hanset until you click or feel the plug snap into place
10. Re-Register Handset by placing on main base in most instances.
please rate this post!!
Posted on Aug 25, 2008
E4 - Erros My uniden phone model TRU 9485 - 4WX after outage power, now on LCD screen appear E4 and it didn't respond to any button when i press. I read some help which they say press 3 button...
Hello
Connect the phone line and power UP the base unit. Place the handset on base to get charged. It must reset automatically when you place the handset on base to charge. If not; resetting both handset and base unit is necessary.
Resetting the Handset
You may need to reset your handset in the following instances:
You lose a handset and purchase a new one. When you try and register to your existing base you get registration
failure.
You are unable to register any handsets to the base.
You had a base which needed to be exchanged by the manufacturer. When you register your existing handsets
to the base, the handsets say #3 and #4, but you only have 2 handsets.
When you are instructed to by the one of the manufacturer's call center representatives.
To reset, do the following:
Press and hold [ ] and [#] for more than 5 seconds. Select DEREGISTER HS.
WHICH HANDSET? appears. Select the handset that you want to de-register, and press the OK soft key.
DEREGISTER HS appears. Select YES, and press the OK soft key.
ARE YOU SURE? appears. Select YES, and press the OK soft key. You will hear a confirmation tone. The
handset will clear its registration information from the base, and then delete its own base information.
MODELS VARY! PLACE HANDSET ON THE BASE FOR REGISTRATION OR REFER TO OWNER'S MANUAL. To
re-register the handset to the base (see page 25).
If the handset cannot contact the base, it will display OUT OF RANGE. Make sure the handset is in range of the
base and the base is connected to power.
Note: It is also possible to reset the handset back to its original factory settings. All changes including Caller ID information
will be erased. For more information on resetting the handset back to factory settings and when you need to
do this, see www.uniden.com or call our Customer Service Hotline. See back cover page for contact information.
Resetting the Handset without the Base
If your original base is not available for some reason (for example, it is lost or somehow incapacitated), you can still
reset the handset and use it with another base.
Move the cursor to select BASE UNAVAILABLE and then press the OK soft key.
BASE UNAVAILABLE appears.
Move the cursor to select YES, and then press the OK soft key. ARE YOU SURE?
appears.
Move the cursor to select YES, and then press the OK soft key. You will hear a confirmation tone. The handset
will delete its own base information without trying to contact the base. When the base information is deleted,
the handset displays MODELS VARY! PLACE HANDSET ON THE BASE FOR REGISTRATION OR REFER
TO OWNER'S MANUAL. Register the handset to the new base (see page 25). of its user manaul.
OK.
Sep 12, 2011 | Uniden TRU9485 Cordless Phone
I have a uniden Tru9466 base station and a uniden TWX 977 that the later that was previously registered with the first displayed a out of range notice so I went thru the process in the owner's manual...
Welcome to FixYa.
  1. Turn OFF your handset (TWX977) and any other handset registered to the base (9466).
  2. Unplug the base from its power source.
  3. Unplug the phone line from the base.
  4. Wait for 15 mins.
  5. Plug back the power source and the phone line.
  6. Turn ON the handset (TWX977)
  7. Reset the handset (TW977) by doing the following:
  • Press the MENU soft key. Select the DEREGISTRATION submenu.
  • ARE YOU SURE? appears. Move the cursor to select YES. Press the OK soft key.
  • To clear other handset information, please follow these steps:
  • From the handset, press and hold [ ] and [#] for more than 5 seconds. Select the DEREGISTER HS submenu.
  • Move the cursor to select the handset ID to be de-registered from the list, and then press the OK soft key.
  • DEREGISTER HS appears. Move the cursor to select YES. Press the OK soft key.
  • ARE YOU SURE? appears. Move the cursor to select YES, and then press the OK soft key. You will hear a confirmation tone.
8. Register the handset by doing the following:
  • With the base in standby, press the MENU soft key.
  • Move the cursor to select REGISTER HANDSET. Press the OK soft key.
  • On the handset, press and hold [#] until you hear a beep.
  • While the handset is registering, HANDSET REGISTERING will appear in the LCD. When REGISTRATION
  • COMPLETE is displayed; the handset has been registered to the base. If REGISTRATION FAILED appears,
  • please try these steps again.
Thank you for using FixYa.
Have a great day.
Jas247
Aug 22, 2011 | Uniden TRU9466 Cordless Phone
HOW DO U CONNECT THE HANDSET TO THE BASE.ALREADY TRIED THE REGISTER BUTTON,DID NOT WORK.IT CAME WITH NO DIRECTIONS,WE BOUGHT AT A FLE MARKET FOR 5 DOLLARS.
Are you sure of the model number? The D1680 should register the handset when you put it on the base for 30 seconds. (You should see Handset Registering followed by Registration Complete.) Then press Talk/Flash to check for dial tone. On this model if the registration fails, charge the battery (or replace the battery and then charge that). Then repeat the registration.
The manual for the Uniden D1680 is available here: http://news.uniden.com/pdf/D1680om.pdf .
For other Uniden phones, like the DEC1060, you need to navigate through the handset menus to find the Handset Registration command. Then press and hold the Register Handset (Find Handset) key on the base for 3+ secondsThen the base and handset will synch. (Low batteries could interfere with the process.)
For the D3288, you access the base menu for Register Accy and then press and hold # on the handset for 30+ seconds. (You will see Registering followed by Registration Complete.)
Additional Uniden cordless phone manuals are available here: http://www.uniden.com/scat/cordlessphones_mnl .
I hope this helps.
(with a flea market phone, my first suggestion is to try a new battery for the handset. They only have a given number of recharge cycles and you do not know the history. However, sometimes the chargers do fail and a new battery will not work. In that case, the phone should be replaced. It isn't worth the cost of out-of-warranty repairs.)
Jul 01, 2011 | Uniden D1680 Cordless Phone
C7 sim card registration failed
You either need to have the phone unlocked, or match it with a sim card of the same network of the phone. here is a similar forum post i hope it helps. http://www.nokiausers.net/forum/nokia-e71-e72/34629-sim-card-registration-failed.html
May 02, 2011 | Nokia C7 (8 GB) Smartphone
I have a uniden TRU9488 preregistered handset from factory, which for years no problem, but stupid me thought "what is this register" and hid register, and now my handset won't work. followed...
What happened is you have deregistered your handset from the tru9488 base. To correct this, you must register that handset with the base. See https://www.manualslib.com/manual/185023/Uniden-Tru9488.html?page=24 for short and sweet instructions for doing this, reproduced below:.
Registering.TCX905.Accessory.Handsets,.or.Other.Compatible.Handsets If.you.purchase.an.accessory.handset,.you.need.to.register.the.handset.before.use..Only.one.handset.can.be.reg-
istered.at.a.time..Handsets.supplied.with.the.phone.are.registered.to.the.base.by.the.factory..When.charged,.pre-
registered.handsets.display.a.handset.ID.number..Handsets.that.have.not.been.registered.display.MODELS.VARY!.
PLACE.HANDSET.ON.THE.BASE.FOR.REGISTRATION.OR.REFER.TO.OWNER'S.MANUAL..(If.an.accessory.
handset.has.ever.been.registered.to.a.base,.you.must.reset.the.handset.before.you.can.register.it.to.a.new.base..
See.Resetting.the.Handsets.on.page.24.)
When.you.register.an.extra.handset.to.the.base,.the.handset.ID.will.be.assigned.
M o d e l s v a r y !
P l a c e H a n d s e t
o n t h e b a s e f o r
1)
Before.registering.the.TCX905.or.other.extra.handset,.the.battery.pack.MUST.be.charged.for.5-20.hours.
2)
With.the.base.in.standby,.press.the.MENU.soft.key.
3)
Move.the.cursor.to.select.REGISTER.HANDSET..Press.the.OK.soft.key.
4)
On.the.handset,.press.and.hold.[#].until.you.hear.a.beep.
5)
While.the.handset.is.registering,.HANDSET.REGISTERING.will.appear.in.the.dis-
play...
When.REGISTRATION.COMPLETE..is.displayed;.the.handset.has.been.registered.to.the.base...
If.REGISTRATION.FAILED..appears,.please.try.these.steps.again.
Aug 10, 2017 | Uniden TRU9488 Phone
Missing manual for Uniden 2.4 Ghz phone
You will need your phone model number, eg "DSS 7805" or the like (yours will be different). Take off the battery cover, gently lift the battery up, and look at the sticker underneath, it should have the model number somewhere within the text there.
Then look up the Uniden website for your country, under Customer Support, Operating Manuals (site menus may be a little different). Find the one for your model.
Aug 04, 2009 | Uniden Cordless Phone
GE DECT 6.0 Model 28111EE2 is not working, registration failed message
I had the same problem, and restoring to default settings did not seem to work either. I just opened the back, unplugged the battery, plugged it back in, and now it works again.
Aug 26, 2008 | Uniden Cordless Phone
Uniden 2645 out of range
The problem of phone not registering is sorted, I simply put that hand piece(2) into base station and it registered straight away, as for the "out of range" problem, we have not had a long enough call today to know yet , hopefully resetting to factory settings helped.
Jul 16, 2008 | Uniden Cordless Phone
Uniden 5.8GHz Dual Cordless Phone Logo
140 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
