Question about Saeco 00034 Incanto Sirius Super Automatic Espresso/Coffee Machine
Full of Beans
My machine is full of beans (pardon the pun) but the indicator keeps telling me that the bin is empty, and to add more.
I have had this problem, off and on, for six months.
I understand there are two possible causes: The grinder is clogged or the microswitch that senses ground coffee is broken.
Here are possible solutions:
1. Adjust the grinder to the coarsest setting. Remember to press down on the adjuster before turning and only adjust while the grinder is operating. This solution worked for me, after a thorough cleaning (2 below) did not. I hope it lasts.
If this works, thank the benevolent coffee gods. If not, curse the malevolent coffee gods and proceed to step 2.
2. Clean the bean hopper and grinder.
(a) Adjust the grinder to the coarsest setting.
(b) Disconnect the power cord.
(c) Remove the hopper. Held by one larger, silver phillips-head screw in the bottom. Remove the rubber seal beneath the hopper.
(d) Remove the top of the machine. Held by two silver phillips-head screws in the back, two black star-head screws in the top, and two black phillips-head screws in the front, behind the door. (a small flat-head screwdriver will fit the star-head screws) It may help to tilt the machine backwards to remove the top. Also, there seems to be a small plastic catch in front that holds the top that has to wiggle free. Leave the green ground wire connected.
(e) Remove the grinder. First, remove the rubber seal on top of the grinder inlet. Second, remove the two, silver phillips-head screws that hold the motor, and one silver phillips-head screw that holds the grinder adjuster. Remove the two rubber seals below the grinder. Leave the wires connected.
(f) Clean the grinder. Use a vacuum cleaner and a bent coat hanger. Gently remove all coffee debris from between the ceramic grinding teeth. Don't be rough and break something. Remove the ground coffee from the exit port. There's a silver metal door you can gently flip up and down and release a lot of ground coffee.
(g) Clean the hopper. With soap and water and a brush.
(h) Reassemble in reverse order. The circuit board is supported by two plastic prongs on the back piece.
(i) Don't use oily beans. They gum up the works. Also, I understand the oil in properly roasted beans is supposed to stay inside the bean.
(j) If this works, thank the benevolent coffee gods. If not, curse the malevolent coffee gods and proceed to step 3.
3. Replace the micro-switch. I don't know where this switch is, so I would take it to an authorized repair shop. Say a prayer to the benevolent coffee gods that there's a reputable shop nearby that will do good work at a good price in a reasonable time. Purple Turtle Coffee Co in LaPorte TX seems like such a shop when I spoke to Marylee on the phone (281-470-6555) Otherwise, curse Saeco and the malevolent coffee gods and buy another brand. Or give up and go to Starbucks.
Good luck,
- mike
Posted on Feb 16, 2009
  • mikeclarkusa Feb 24, 2009
    My machine quit again so I sent it to the service shop, Purple Turtle Coffee. Shortly thereafter,
    I discovered these other solutions:
    I hit SUBMIT too soon.
    Here are two more solutions:
    "I had the same problem and after contacting Saeco Canada service and giving them my model number ( SUP 021YNR) they told me that this is not the more recent model and that they have had some problems with that model.
    in the more recent model, there is no microswitch to detect the beans
    and that it is made by mesuring the current of the grinder motor.
    suggest to change the value of resistor R102 from 2.7 ohms to 4.7 ohms.
    I have done this modification and it does work very well now
    "Thanks for the help but I was well past that stage. After cleaning half
    a dozen times, changing beans three or four times, soldering the
    contacts on the switch, changing it, replacing the whole doser flap
    sled and anything else I could think to do I finally fixed it. It took
    me months but in the end it was the doser trap door not allowing the
    dozer flap to move back and hit the switch when the grounds came down.
    A simple light bending out fixed it. So...we had a rare mechanical
    issue. The machine does have a design flaw in that it has a long three
    inch shoot for the grounds which makes it susceptible to clogs. Do not
    use oily beans!"
    I did not try either of these two solutions. Good luck.
    - mike
  • 515 Answers
You have to mount a resistance on the power card.
Posted on Aug 27, 2008
Barista supremo thinks it doesn't have coffee beans The red light comes on, doesn't it? The light indicates that the water tank could be empty or the drip tray is full. Tell the coffee machine that it has enough beans, but to please the machine you will fill the water tank and empty the drip tray. Good luck, kolbrun
Sep 10, 2013 | Saeco Odea Giro Plus Coffee Maker
Jura j5 keeps indicating beans need filling once a button for coffee has been depressed. then indicates ready again. Beans are full and I have tried blocking off the sensor (beans full) but still the...
Sometimes certain beans do not move freely throughout the grinder. Oily beans, which is not necessarily a bad thing, do not fall into the grinder easily and tend to stick. It is necessary to sometimes to just poke or stir the beans around with your finger to make sure they fall into the grinder. For a safety measure do this while your machine is turned off.
Apr 20, 2011 | Jura Capresso Jura / Capresso IMPRESSA J5...
I keep getting "Fill Coffee Bin" when the bin is
Sounds like the grinder is blocked. Set the grinder to the coarsest setting (largest number) and try a few more times. If still no luck then vacuum out all the beans, run the grinder again a couple of times and then add a small amount of fresh beans (not from a fridge or freezer as these will be moist and can cause problems) and try making coffee again. If after a few tries it still doesn't work then you will either have to remove the top grinder burr and clean both burrs (not recommended unless you are bit of a handy person) or you could try vacuuming out the beans again and letting the grinder dry out for a while (although unlikely, it could be wet from water spillage). Good luck hope this helps.
Dec 14, 2010 | DeLonghi EAM3400 Espresso Machine
Add beans??
I had this same problem with my Saeco Magic Plus and found that cleaning the burr grinder fixed the problem. Here's a link showing how that is done:
Good Luck!
Mar 07, 2009 | Saeco Primea Cappuccino Touch Plus Coffee...
Saeco Vienna is full of beans but the bean light stays on
the sensor may be stuck that tells the majer there are beens in it ..look in hopper feel around!
Nov 28, 2008 | Saeco Vienna De Luxe Espresso Machine
Saeco Italia SUP021 YR - Red light #29 on solid
Not clear on "Empty bean container/full grounds drawer) - not empty/not full. " But I gather that coffee is not being dispensed. Most Likely the grinder needs cleaning + brew group needs cleaning ( filter ). Do you get water/steam?
Jun 10, 2008 | Starbucks Saeco Italia Digital Barista...
Saeco italia
ok turn the machine on and wait till warmed up. Open door while machine is on and remove the dreg drawer. This you always need to do when the machine is on otherwise it will not reset.
flashing means dreg drawer steady means coffee beans
Apr 05, 2008 | Saeco Incanto Classic Espresso Machine
Coffee Grinder not working
the grinder is most likely stripped and needs to be replaced:-{
Jul 23, 2006 | Saeco Caffe Charisma Espresso Machine
Saeco 00034 Incanto Sirius Super Automatic Espresso/Coffee Machine Logo
254 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
