Question about Harley Davidson Harley-Davidson Motorcycle Desktop Telephone
My sons Dr250 Suzuki's gear leaver shaft has slipped into the motor and has no gears, I can pull it back out to its original position to select gears, the question is what is supposed to stop the shaft moving in and out ? is it an external cir-clip or internal
    Genius:
  • 2,028 Answers
I believe that on these models the retaining clip is internal,and the shaft seats into a bearing at the other end. If the bearing has come apart it will allow the shaft to slide in and out also. Drain and check the fluid for metal or excessive shavings. If it were external, you should be able to see the groove for the clip with the shaft pulled out. Most likely, you're going to have to pull the engine, and split the cases to get to the tranny in order to fix the problem. Pain in the arse, I know, I've done it a few times on my dirt bikes. Assuming this is the DR250 enduro style dirt bike I'm thinking it is. If I'm wrong on the bike type let me know, and I'll see if I can get more info, cause I believe Suzuki also made a DR 250 S in the late 80's or early 90's, which was a sport bike.
Posted on Aug 24, 2008
My gear select shaft on my gsf1200 Suzuki bandit has pushed in too far to get the circling back on and I can't select gears
yes a bit of a job
a repair manual would help a lot
this is what you cant see
the shaft goes to the other side of the bike
you should be able to undo exterior engine covers
and sort out the shift shaft problem
Sep 17, 2016 | 2003 Suzuki GSF 1200 Bandit S
Why does my RM125 not drive? i start her up pull back clutch leaver and slip it into gear i loose the hand its goes forwards very slowly instead of pulling off normal? whats wrong?
does it fell like its going into gear? if yes,when you let the clutch out does try to move?.This would indicate the clutch was worn out,if it won't go into gear it would mean the cable or clutch were out of adjustment.
Sep 13, 2014 | Suzuki RM 125 Motorcycles
My 1999 ktm 300exc is stuck in first gear.
is the gear leaver returning to position after trying to select a gear.it could be that the shaft from the leaver is bent or the drum is stuck or return spring is broken.
Oct 07, 2013 | KTM Motorcycles
Wall-e u comand robot, will not move forward he just turns, can i fix the right wheel?
On the in side of the body (cube) is a white gear the size of a 50cent coin. It is pressed on a drive shaft. The inter ring is cracked and slipping. It makes Wall E turn around and around. I'm looking for a replacement or some one with a makerbot to reproduce it. If any one finds one let me know at. stevepiper@usa.com
Apr 19, 2012 | Disney Wall-E U-Command Remote Control...
Gears are stuck
chances are the gear selecter shaft was pushed in when it went over and possibly jammed the selector fork remove the clutch cover and have a look you might get away with just knocking it back into place if nothings been damaged
Dec 17, 2009 | 1991 Honda NT 400
2003 Toyota Camry drivers side power seat stuck
This is not necessary...as many have stated...use a hammer with switch in reverse position. Hammer the seat back...it will catch...
Aug 25, 2009 | 1992 Toyota Camry V6
ZAFIRA 2006 CANT REFIT SELECTOR SHAFT AFTER REMOVEL?
If you mean the gear selector. Fit it Into position. Remove the Cover from the gear lever, Hold the gear leaver to the left. Place a 6mm Allen Key or Small bladed screw driver in the hole on the left to lock the lever into position. Under the bonnet twist the 'Remote to the right or left(not sure which way). There is a White Pin with a spring on it. This will push in and lock. The gears should the n be set up. Tighten the lock nut on the selector 'Stub' that's on the rear of the gear box and bingo the gear leaver is set.
Jan 30, 2009 | Cars & Trucks
Gear Selecting
it might be your gears which are worn out and causing gear slips.. but there is high probability of your clutch plates getting spoilt.. the clutch plated work as disengaging the gears shaft to the main engine shaft.. sometimes when the clutch plates are very much use enough..,they stop working and cant retain to disengage the gears.. so first of all get your clutch checked well and then preoceed if it doesn't fix your problem.. heyii there is a shaft coming ut of the engine crank that connects to your transmission shaft which drives your gears and hence wheels.. so your 2nd gear must have worn out and for that reason the gear isn't working well.. get your gear box opened and check the gear.. Belated Merry X-mas and Happy New Year [:)]
Dec 27, 2008 | 2003 Suzuki GZ 125 Marauder
Not printing at all. Screen appears as series of exclamation marks
I had the same problem with my label marker. Changing the batteries fixed the problem
Jan 08, 2008 | Dymo LabelManager 300 Desktop Labelmaker...
Lands Phones Logo
88 people viewed this question
Top Harley Davidson Lands Phones Experts
ted dux
Ronny Bennett Sr.
Ronny Bennett Sr.
David Payne
David Payne
Are you a Harley Davidson Lands Phone Expert? Answer questions, earn points and help others
