Question about Olympus Camedia D-370 Digital Camera
Internal memory
Can images stored in the internal memory be saved onto a SmartMedia card?
    Master:
  • 852 Answers
The camera has a Memory Back-Up function located in the Play menu. Please refer to the Reference Manual on the CD-ROM for this procedure.
Posted on Aug 31, 2005
I can't view images on Internal memory when SD card is inserted.
Put the card in, then select "Copy" from the playback menu. You will then be given the option of copying individual images or all of them. See the instructions beginning on page 99 of the manual: http://www.fujifilm.com/support/digital_cameras/manuals/pdf/index/s/finepix_s5700_s700_s5800_s800_manual_01.pdf
Jul 11, 2013 | Cameras
Tip
If your camera will not read or transfer internal images on to memory card
When your camera will not transfer images onto memory card this is often because the image storage has been set to 'Auto'. You need to set it back to internal memory temporarily to allow you to copy the images over to the card. Once you have done this you can set the camera back to 'Auto' and this will reset the system and you will now have access to all of the images on the card.
This particular procedure works with all cameras but the steps outlined here are for Kodak in particular.
Please follow these steps;
1) Insert the card
2) Turn the camera to Auto
3) Press review - "reading memory card"
4) Press menu and scroll down to image storage and press ok
5) Select Internal Memory and press OK
6) Scroll down to Copy - Copy Pictures to memory card
7) Scroll down to ALL and press OK - you should see "Copying" displayed
8) When the screen goes back to the main menu - Scroll to Image storage again and select Auto - OK - "Reading memory card"
You should now be able to see the pictures from your internal memory saved onto your memory card and your camera is once again ready to use.
Hope this helps. Please do register your vote using the Yes/No buttons below to reflect the helpfulness of this Tip.
on Dec 22, 2009 | Cameras
Kodak easyshare m360 says memory full after 3 photos i just bought the camera, what i shell do < shell i buy memory card or usb for it ?
You need to switch the camera over to saving pictures directly onto the SD card.
  • Menu
  • Cam settings
  • Chose AUTO or SD card option
  • Press OK to SD card
Note: If the SD card isn't in the camera or is unreadable the camera will automatically go back to saving you taken pictures on the internal memory.
If you experience problems:
The lever on your SD card might be turned the wrong way so the SD card is reading protective.
Please turn the lever and try again.
The SD card might not be supported by the model: Your camera Memory card support is SD/MMC up to 2 Gigabyte and SDHC up to 8 Gigabyte
The SD card might not be faulty, try another card, since the camera could give you a message like the one you're experiencing.
Try with a different SD card that is supported by the camera.
Once you have set the settings to save onto the SD card directly you might like to transferre your existing pictures from the internal memory onto the SD card:
Question :
How do I transfer pictures from the internal memory of my KODAK Digital Camera to a memory card? Answer :
Follow these steps:
  • On the camera, press Review and then Menu.
  • Select Image Storage.
  • Change to Internal Memory.
  • In the menu listing, scroll down to Copy, and select OK.
  • Select a single picture, or select All.
  • When you have finished copying pictures, reset the Image Storage location to your original setting.
  • Jan 18, 2010 | Kodak EasyShare One Digital Camera
    How do i switch off internal memory
    How to switch the camera over to saving pictures directly onto the SD card.
      1. Menu
      2. Cam settings
      3. Chose AUTO or SD card option and Press OK
      After you have done so I would guess that you would like to transferre the pictures from your internal memory over to the SD card.:
    Question :
    Follow these steps:
  • Jan 17, 2010 | Kodak EasyShare C613 Digital Camera
    Just put a new memory card in the camera but the screen keeps showing internal memory is full
      1. Menu
      2. Cam settings
    If you still experience problems:
    The SD card might not be supported by the model: Your camera Memory card support is SD/MMC up to 1 Gigabyte
      After you having successfully switched over to saving onto the SD card. I would guess that you would like to transferre the pictures from your internal memory over to the SD card.:
    Question :
    Follow these steps:
  • Jan 16, 2010 | Kodak EasyShare C643 Digital Camera
    Move images saved to the internal memory to the optional xD-Picture Card
    The images saved to the internal memory can be copied to the xD-Picture Card, but you cannot copy images from the xD-Picture Card to the internal memory.
    Aug 31, 2005 | Olympus D-545 Zoom Digital Camera
    Move images to the internal memory to the optional xD-Picture Card?
    The images saved to the internal memory can be copied to the memory card, but you cannot copy images from the memory card to the internal memory.
    Aug 31, 2005 | Olympus Camedia D-435 Digital Camera
    Download the images
    In order to access images stored on the internal memory, the SmartMedia card must be removed. Once the card is removed, follow the procedure used to download images stored on the SmartMedia card.
    Aug 31, 2005 | Olympus Camedia D-380 Digital Camera
    SmartMedia card
    Download the images
    Aug 31, 2005 | Olympus Camedia D-370 Digital Camera
    Olympus Camedia D-370 Digital Camera Logo
    51 people viewed this question
    Top Olympus Cameras Experts
    Steven Wander
    Steven Wander
    Jerry Greenberg
    Jerry Greenberg
    Are you an Olympus Camera Expert? Answer questions, earn points and help others
