Question about Mitsubishi XD480U Multimedia Projector
Auto shutdown on Mitsubishi XD series projector
Unit shuts down after about 2 mins use with no warning when suspended in normal ceiling mounted upside down
when I put projector normal way up on table it operates perfectly ??
HELP ??
Tnks
rob Reid
Stripped projector ( including removal of bulb ) and cleaned internals
re assembled and all A1
RR
Posted on Aug 24, 2008
My projector screen is showing my computer screen upside down
Your projector setting needs to be changed from the ceiling mount projection option. It is in setup menu.
Jan 09, 2013 | Mitsubishi Office Equipment & Supplies
MY EPSOM PROJECTOR IMAGE IS UPSIDE DOWN. WHAT DO I DO?
Hi, Your projector is probably set for ceiling mount which will project an upside down image because the projector is normally mounted upside down when installed on the ceiling. Go into the menu and select extended then select projection then select front. That should return the image to right side up.
Aug 22, 2011 | Epson EX30 LCD Projector
I hooked up my Think Pad laptop to an Epson EMP-74 and the image projected is upside down. How do I fix?
Do the following for setting the screen.
1. Press the Menu button
2. Select Projection
In the Projection option,
Select Front : When the projector is in front of the
screen.
Select Front/Ceiling : When the projector is in front of the
screen and suspended from the ceiling.
Select Rear : When the projector is behind the
screen.
Select Rear/Ceiling : When the projector is behind the
ok
Apr 06, 2011 | Epson EMP-74L Multimedia Projector
My image is showing on the screen upside down, how do we fix this problem?
Go into projector menu - view options. (It's currently set for a ceiling mount is why it's upside down.)
Mar 07, 2011 | Mitsubishi XD600U Projector
Turning it back to normal after ceiling mount for LP755
hi,
1. perss menu button
2. select controls
3. then select ceiling projecton (When you turn Ceiling Projection on, the projector turns the image upside down for ceiling-mounted projection. Highlight Ceiling Projection, then click either button to select turn this feature on and off.)
ok
Dec 21, 2010 | InFocus LP 755 Multimedia Projector
My projectors image is upside down. how do i fix
Go to Menu> Extended> Projection> select Front ( to project from the front of the screen ).Front/Ceiling ( If the projector is mounted upside-down from the ceiling ). Rear ( to project from behind onto a transparent screen ).Rear/Ceiling ( to project from behind when the projector is mounted upside-down from the ceiling ).
Apr 11, 2010 | Epson EX30 LCD Projector
How do i mount my hopper projector sv 10 to the ceiling
Yes it should be mounted upside down as you would not want to see the bottom of the projector all the time, unless the bottom is as good looking as the top, which I doubt. I wonder if you bought or got a ceiling mount rack with it. First mount the rack on the ceiling and then fasten the projector to it. And before that its picture has to be turned upside down too.
Aug 11, 2009 | Philips Hopper SV20 Replacement Lamp -...
Image on screen is upside down
The orientation of your projector can be setup from the "Option" menu. You may need to select the "FRONT" and "CEILING" options to display the correct orientation of the image.
Jan 19, 2009 | Panasonic PT-L785U Multimedia Projector
Reverse Image
find the menu for saving the settings, for sure there is a menu saving all your desired settings. good luck!
Feb 11, 2007 | Mitsubishi X490U Multimedia Projector
Mitsubishi XD480U Multimedia Projector Logo
292 people viewed this question
Top Mitsubishi Office Equipment & Supplies Experts
Are you a Mitsubishi Office Equipment and Supply Expert? Answer questions, earn points and help others
