Question about Canon Cameras
I have a broken 430ex canon flash. the ready light comes on the screens read and working but no flash and no charge sounds.
The problem was solved and I have a bad bulb. The information was gotten by searching google and then following the photo expert blog.
Posted on Aug 24, 2008
Text is blinking on my 430ex lcd screen zoom --mm. How do I get it to stop?
Check the diffuser is fully retracted. Pull it fully out then all the way back in.
Apr 10, 2014 | Canon Speedlite 430EX TTL Flash
My canon speedlite 430ex does not charge up, batteries are new and rear screen works/lights up any ideas?
Sounds like an internal wiring circuit problem. It's strange that the screen lights up but the flash doesn't charge. You should probably get it checked by Canon.
Feb 11, 2013 | Canon Speedlite 430EX TTL Flash
Just got a Canon 7D. Attached my 430EX to the hot shoe and it won't fire. Tried new batteries and checked the contacts, and it still won't work. Put th 430EX back onto my Rebel XTI, where it has always...
Make sure you using flash grade batteries and not rechargables. try energiser ultra or litiums or duracelll plus but nothing else. if the charge light is not coming up then most likely batteries. I would take it to your local camera shot and test your 7d with one of thier 430 just to make sure the hotshoe didnt short out the flashgun
Feb 21, 2011 | Canon Speedlite 430EX TTL Flash
Speedlite 430ex, pilot light on, flashes when I hit the pilot, but will never fire when taking a picture....the "ready" light below the red pilot light never turns on
Typically, it means your batteries are low but I am sure that you know that already.
The next cause is a mechanical failure. The flash has capacitors that **** up the battery power until they have a full charge and the trigger the ready light. Therefore, if your batteries are good then it is likely that the capacitors are disconnected or have failed. Eitherway, you will most likely have to send it out to a Canon service center. You can find service centers at www.canonusa.com.
I hope this helps. Good luck!
Jan 16, 2011 | Canon Speedlite 430EX TTL Flash
The flash won't fire, and the pilot light won't come on. I've tried new batteries, and that doesn't work. The little LCD screen does have power. I'm wondering if I blew the strobe. Thanks!
Hey i have a 430ex mk1 which when turned on did not fire and red pilot light did not show , i have had the flash since 2006,
i have also tired new batterys and the LCD Light works and the Txt shows up,
did you work out the problem and also how to fix it?
thanks
rick
email
psnp@hotmail.co.uk
Oct 05, 2009 | Canon Speedlite 430EX TTL Flash
430EX won't fire.
Can you short the pins to have the flash fired?a.l9609@gmail.com
May 27, 2009 | Canon Speedlite 430EX TTL Flash
Canon 430EX flash will not flash in slave mode.
This site worked foe me http://flashzebra.com/wizardcables/index.shtml
Good luck
Feb 22, 2009 | Canon Speedlite 430EX TTL Flash
Replacing widepanel screen on Canon 430 EX flash
If you need this repaired I can do this . The price is $108.00 includes shipping .
Berrie Smith Camera Repair bbmw@bellsouth.net
Jun 23, 2008 | Canon Speedlite 430EX TTL Flash
Canon 430EX Flash
I have a 430ex and S5, I don't think the zoom head will move without being mounted on a camera.
If the flash test fires ok, then it should be fine.
Oct 16, 2007 | Canon Speedlite 430EX TTL Flash
Cameras Logo
64 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
