Question about Dishwashers
Dishlex Global 300 Ecco light flashing, while motor is draining constantly. Can't change the setting. It was turned off in the rinse cycle accidentally. Help!!!!
  • mavo334 Aug 27, 2008
    Thanks for your reply. We did get a mechanic out who probably did the same as you recommed. Anyway all is well now. Thanks
  • jsbaulch Sep 04, 2008
    I have a global 300. The rinse light keeps flashing and the cycle wont complete. The hose and the trap are not blocked.
    Sergeant:
  • 351 Answers
Water in the flood switch tilt the dishwasher back then try again
Posted on Aug 27, 2008
Have a dishlex dx302 it starts. timer counts down and shortly after error code CL /beep happens. can you help me.
It is possible that the machine does not start off the cycle because there are errors or feedback from the inputs. For the program to start up the main program controller must initiate the INLET/PUMP MOTOR/DRAIN to work when it is commanded .If this does not happen then the voltage at these points must be checked or the fault relates to no voltage/drive from the controller. This means the controller is a suspect.
If the water flows then the flow should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor. The water pressure must be good and the spraying must be seen to be good. If there is low pumping or pressure then the spray arms will not turn around to inject with pressure. If so the pump must be checked for clogging.
Finally after the wash the drain valve will be activated, the water is allowed to come in to rinse and then finally the drain valve/pump activated so as to drain off all the water.
Make sure that a fault in any of the cycle will relate to the specified action, so check the command from the program module and then the executing device be it the valve or motor or pump.
Please check the link below:
http://www.espares.co.uk/advice/dishwashers/a/3
Thank You for using Fixya
Aug 17, 2011 | Electrolux 24 in. EDW5505EPS Stainless...
The eco light is flashing constantly on my Dishlex Global 300 dishwasher, it is making a noise like a pump is running continously, but the unit will not operate. Can you give me some possible faults and...
The symptoms on a Dishlex Global 300 dishwasher:
  • eco light is flashing constantly;
  • noise on pump running continuously;
  • but the unit will not operate.
Possible corrective actions include:
  • water level - pls check incoming water pressure, filter, water level sensor, water valve;
  • base/bottom overflow sensor - there is a float switch in the base of the machine inside a small plastic dish. Behind the kick panel, access through a metal lid/panel/cover secured by 2 small screws. Dry completely the area;
  • Air/dry/ventilate the unit/system for a couple of days;
  • reduce incoming water pressure.
Hope that this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Oct 26, 2008 | Dishwashers
My Dishlex Global 300 dishwasher stops mid cycle and the rinse light keeps flashing ?
I think I had the same problem. I don't know much about dishwashers, but the "Flashing Rinse" has something to do with the drain, or the drain pump (which is why the water doesn't drain).
My dishwasher stopped its cycle, after having filled up with water, even though everything else worked fine, because the drain pump was not even turning on. So I guess, the first question I asked was, is the drain blocked? No. When this happened the first time, the flashing rinse cam up. After that, the dishwasher just wouldn't drain, and there was no longer a flashing rinse.
So then, I figured, the drain pump is probably rooted. The drain pump is found underneith the dishwasher, just behind the front panel on the left hand side.You'll need to remove the metal covers from the front and the left.
When this happened to me, I thought I'd need to buy a new pump, so I pulled the other one out (its a bit fiddly, you have to disconnect the two electrical wires, then remove the drain pipe from it, and then wiggle it off. But when I got it out, I unscrewed it (it has the special hexagonal screws, not phillips or flathead), and it turns out, a fairly large fruit seed had got into the drain pump and blocked it, preventing it from spinning. I put it back together again, and it worked.
It so far has beaten paying $100 for a new pump.
If you want a visual of what the drain pump looks like, look up the dishwasher part number #8905912, you should be able to find it on the internet. Hope this helps.
Jul 29, 2010 | Dishwashers
Dishwasher stops part way through cycle
Sorry I have taken along time to reply but I lost my email access for awhile.Now the fault with your dishwasher is its taking too long to drain.Please reply if you still require help.Once again sorry for not getting back to you sooner.
May 27, 2010 | Dishwashers
Dishlex global 300.... The normal light starts flashing mid wash
i think it means the water heater in the dishwasher is not working,or the element is shot.
my 300 had a burning smell before the light started flashing.
Feb 07, 2010 | Electrolux Dishwashers
Dishlex Global 300. Eco light flashing and nothing happens.
could be the water inlet valve or solenoid
Jan 25, 2010 | Dishwashers
Pump motor runs continuously, ''Eco'' flashes continuously
Hi
soyunds like it flooded the base
You need to dry out the base of the machine thoroughly and it should re set
Feb 14, 2009 | Electrolux 24 in. EDW5505EPS Stainless...
Dishlex global 500 rinse and wash problem
This was due to a faulty pump motor which I have now replaced.
Jan 10, 2009 | Dishwashers
Eco light flashing on Global 300
drained out where the float is, haven't run a full cycle yet but a partial cycle worked. i think definitely drain the float tank.
Apr 18, 2008 | Dishwashers
Dishwashers Logo
342 people viewed this question
Top Dishwashers Experts
