As soon as the alignment sensor does not work correct, or does get information it does not expect you get an error.
The band whit the very small lines on it, should be clean and in one piece. It is connected to the print head and registers the slightest movement of the head. Check if the band is there and if it looks "new"
old subzeros the CONDENSER FAN MOTOR RUNS OLD THE TIME. SAME WHIT THE EVAPORATOR FAN MOTOR. RUNS ALL THE TIME. now fos systems whit 2 compressor the condenser fan motor run for both compressor. only stop when both compressor stop......
disconnected your water line to your fridge and let it rum in to a bucket so you will have fresh water for your fridge but before plug it back to your fridge pour a example in to a cup and drink it to see how it theist like.
if that don,t solve your problem,
there is a way to get rid of bad rubber taste on the water , but is kind of hard to do first
you need to take you refrigerator out side
because is going to be messy find some kind of water pump and a bucket and some hose.
disconnect the water line going out of the water valve to your ice make and rig your hose together whit that one.
on the bucket pour a full bottle of Synthetic vinegar "yes the same stuff you put in your salt", make sure is synthetic not the natural kind
using a pump flush your refrigerator whit the vinegar, you can add some water if you need
if there is two water valves do the same on both.
good luck.
Would you like to tell someone the make and model, or shall we just guess?
