Question about Kenmore 62232 / 62234 / 62239 Bottom Freezer Refrigerator
Unlevel freezer door pops open
Freezer door not level and pops open. how can I level it?
  • 89 Answers
First insure the whole unit is level do this by screwing down or up on the feet with a cresent wrench if thats ok and still have problem you can loosen screws on hinges and level manually most times screws have caps hiding them they just pop off good luck hope this helps
Posted on Aug 24, 2008
Why does the freezer door not close securely?
need to level the refrigerator properly where the doors will gently close themselves. it is normal for the doors to pop another door open if closed rapidly. model number?
APPLIANCE 911
Jan 04, 2016 | Refrigerators
The bottom freezer door on my Kenmore refrigerator 795.7900 pops open each time I close the top door. I have tried adjusting the leveling screws and it hasn't helped. Any suggestions?
Glen you keep adjusting but before that try to find this unusual problem. On its own, doesthe freezer door close witha thud? If not it needs adjustment otherwise other problems could surface.
Mar 03, 2014 | Kenmore 72912 / 72914 / 72919 Bottom...
Leveling a refridgerator
if not level you need to tip it back and unscrew or screw in the feet on it. use a 2ft level on top to be sure which way to go. if just the door, open door and there is a bracket in between the freezer and fridge and it should be adjustable a little bit. unscrew til lose adjust door to right spot and hold while tightening bolts. that should work. if the fridge door is on top and freezer is on bottom then adjust bracket screws on top of fridge.
Jun 24, 2012 | Stainless Cal Flame Refridgerator Steel...
Freezer door pops open when the Refrigerator door is being closed
My new freezer did the same thing. I contacted the company and they went into the whole leveling thing. What it has to do with is the magnetic seal. The magnets are not strong enough to keep the freezer door from popping open when closing the big fridge door. They share the same duct. I level my doors on the fridge and freezer so they swing shut by themselves after opening. Just the force of the big door when it swung closed cracked open the freezer door about a quarter of an inch and if left unnoticed created a puddle and made the fridge run overtime. I solved the problem by placing strong magnets inside the fold of the magnetic seal at the handle end of the door. This is the flap on the outside the door seal. I used six magnets on the top and six on the bottom. The magnets were from discarded Sonicare tooth brush heads. They are very flat and super strong. You can find something on ebay. My freezer door doesn't budge problem solved. I did call the company and told them I solved the problem and they still insisted it was the leveling. Good luck, Art Knapp
Jan 08, 2011 | Refrigerators
Freezer door closing problem
to keep freezer door from popping open close main door more gently try extending front legs a little to help the door swing shut
Aug 04, 2009 | Refrigerators
Side by side freezer door pops open
This is a problem inherent with lots of refrigerators. Side by side or top freezer. The rush of air pops the doors. You might want to adjust the pitch of the box by adjusting the front wheels to a higher level.
Jun 17, 2009 | Jenn-Air JCB2280HES Side by Side...
Refrigerator door pops open, frigidaire top
The refrigerator needs to be perfectly leveled side to side dn should pitch back slightly. Also look at the plane of the doors, that is to say that they should be squared to the cabinet. If they are sagging, you may need to adjust the hinges.
Apr 17, 2009 | Frigidaire FRT21H8 Top Freezer...
Fridge makes a fairly loud humming noise when I close the door
it sounds like your refridgerator might be unlevel try adjusting the legs all the way down to start then level to floor if that doesnt fix it its probably the rubber gromet under the compressor usually there is four of them if one comes out(usually after moving it makes your compressor vibrate you can use almost any gromet of of any junk refrigerator or if you want you can by original replacement parts at one of your local appliance dealer
Dec 18, 2008 | Dishwashers
Leveling old refrigerator
The refrig does not have to be level, as a matter of fact, they tend to work (doors on most refrig's) if the front is a bit higher than the back. If you pop off the lower grill, you will see that the front rollers have a bolt that runs up through the lower frame. Turning on the end of that bolt with a 3/8 inch wrench will allow adjustment of an inch or so, up or down, depending on where it is at now. Only the front rollers are adjustable this way. Back rollers would have to be shimmed to adjust. Check the door hinges to see if the hinge and corresponding hinge cam riser (WR2X4901) are worn. (these parts raise the door slightly as it is opened, and help close the door as the door drops back down when closing.)
Dec 06, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
Lower door wont stay closed
I doubt it. The problem is probably that the unit is on an uneven or unlevel floor. Make sure all 4 corners are 'solid' and the unit is level. Is the door overloaded? Any hinge damage to either door or loose hardware?
Jan 10, 2008 | Amana ABD2533DEW / ABD2533DEB / ABD2533DEQ...
Kenmore 62232 / 62234 / 62239 Bottom Freezer Refrigerator Logo
117 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
