Question about White Sewing 1521
Thread white sewing
    Problem Solver:
  • 5 Answers
Go to the white website & email them from the contact us section. they'll email you back w/ PDF version of manual. that should show u how. they did that for me. goodluck!
Posted on Dec 16, 2008
How do I thread my white mode 742 also bobin thread is not picking up
Sewing Machine 101 The White 764
White sewing machine model 742 sewing discussion topic PatternReview com
Instruction Manual White 742
Even though the following is not your particular model, the process is very similar from one machine to another, so what you aren't able to get from the above links, you may get from these. Be sure to ALWAYS RAISE the presser foot when threading the top thread so the thread will seat properly.
White Sewing Machine 639 How To Upper Thread The Machine Vintage Metal
White Sewing Machine 639 How To Wind Bobbin Front Loading Bobbin Vintage
Nov 18, 2017 | Sewing Machines
I need help with a white sewing machine model 765 I can't get it to sew it doesn't pick up the bobbin thread
First thing to try is a brand new needle. A bent/damaged needle may not be able to pick up the bobbin thread.
Otherwise, it is possible it has a timing issue, ie the needle is arriving at the bobbin at the wrong time in order to connect with the bobbin thread. Search the internet web sites and videos. There is a lot of information on how to fix sewing machine timing. Or take it for service.
Jul 11, 2016 | White Sewing Sewing Machines
White 2037 twin needle keeps breaking thread
Thread breakage occurs commonly with mis-threading. Be sure to ALWAYS RAISE the presser foot when threading the top thread. Also, since you are using 2 threads, thread one completely and then thread the other so the threads do not get twisted in the thread path. If your machine has duel tension disks, thread each tension disk separately with a single thread. Setting the thread spools to turn opposite directions may help.
Also, make sure the needle eye is the right size for the thread. Thick or thin thread could break easily in the wrong needle.
Also, use only good quality thread--no bargain bin or old threads!
twin needle thread breakage Google Search
Nov 25, 2017 | White Sewing 2037 Mechanical Sewing...
White model 935 maintenance help
The top thread breaks
1. the needle thread is not threaded properly
2. The needle thread tension is to tight
3. The needle is bent or blunt
4. The needle is incorrectly inserted
5. The needle thread & the bobbin thread are not set under the presser foot when starting to sew
6. the threads were not drawn to the rear after sewing
7. The thread is either to heavy or to fine for the needle
8. Try a different spool or cone of thread
Jul 27, 2013 | White Sewing 935 Mechanical Sewing Machine
Thread keeps slipping out of the first thread guide while sewing causing the tension to be off
try using a small piece of tape on the thread guide and see if that
helps the thread to stop coming out of the thread guide.
Mar 24, 2013 | White Sewing 1740 Mechanical Sewing...
My sewing machine will not sew it only makes holes in the fabric from the needle
Assure the needle is threaded correctly.
Either its not properly threaded when you start to sew
OR the bobbin isn't correctly installed causing it not to catch the thread when sewing.
OR (possibly just with old machines) the tensioning needs to be adjusted.
It is difficult to say without seeing.
Hope this helps at least some. Good Luck!
Jul 31, 2009 | White Sewing White 3032
Thread keeps breaking
Your machine isn't threaded properly. Check to make sure #1, you have it threaded right and #2 the thread on all 4 spools is in between the tension dials. Good Luck and Hope this helps.
Aug 24, 2008 | White Sewing Speedylock 1600 Mechanical...
White Sewing 1521 Logo
Top White Sewing Sewing Machines Experts
Tally Girl
Tally Girl
Are you a White Sewing Sewing Machine Expert? Answer questions, earn points and help others
