HP DeskJet 5650 InkJet Printer Logo
Posted on Jun 30, 2011
The ink light is blinking, i've replaced the ink but it is still blinking
1 Related Answer
Anonymous
  • 88 Answers
  • Posted on Apr 05, 2012
SOURCE: Ink light icon on screen of HP Photosmart 375 printer won't turn off
Calibrate the printer.
Testimonial: "Thanks Tom - I calibrated the printer, the icon is still there, but at least I can print using the computer cable"
1helpful
Signal lights won't blink
The relay is bad, look in your manual for location and unplug and replace. Advance auto should have it.
1helpful
Epson 1440 printer repair
both the paper/ink buttons blinking in red simultaneously means fatal error. Use AP for figure the latest fatal error code. Btw, i have Service manual for 1400. Contact me at aicaxz(at)yahoo(dot)com
Cannon MP990 C610 error
Inkjet cartridges dry up very soon. You have to use it everyday. Or clear the nozzles using hot tap water soak. Or try new cartridges again.
2answers
Why can't I turn my canon printer on? I've checked and double checked that all connections are tight. I may be low in one ink cartridge but since I can't turn the machine on I can't...
If the printer is plugged into an AVR or a UPS try plugging it directly to a known good power outlet to make sure that it's not the UPS or AVR that's causing the trouble.
Another thing you can try is to make sure that the power cable is ok. Eventhough it's intact wires from inside the power cable might have melted so try swapping power cables or if you have a power tester check for the continuity of electricity on the power cable.
If both looks good and the printer still does not want to turn on, check if the power light has any sign of life, does it give a blinking amber light or no light from the printer comes out at all?
If there is a blinking light or a steady amber light try to remove all the printer components (inks, cartridges, etc. and put them back in then try turning the printer on)
If it still does not work please provide the model number of the printer as a service might be needed to make sure that the capacitors, IC's and the PC-board of the printer is ok.
P.S don't forget to check the fuses to make sure that they are in good condition.
Hope this helps!
4helpful
HP Deskjet 1280 : The resume light keeps on blinking.
Can I get the reply now? I have a whole lot of documents waiting to be printed.
k24674
Grand Canyon Tech
Grand Canyon Tech
