Question about Toshiba Satellite M115-S1061 Notebook
Negative Video My daughter's 2-yr old M115 laptop "suddenly" (her claim not mine) gone into some sort of a negative video on the LCD display. The display is dim to the point it first appeared to be a bad inverter but changing that produced no change. Colors are out of wack and producing some previously unseen shades. At one point I thought the LCD might have lost the its ability to produce certain colors most notably blue but after I modified some of the color slections I now realize it can reproduce blue when it wants to and that the there is some form of video inversion going on that is tough to describe for at times it isn't obvious at all. The video driver hasn't been updated and a search for an update indicates there is none newer thus I cannot go forward or backward in that regard. Ant external monitor produces normal results thus it is unlikely to be a video chipset issue. Thus far a search of the Internet turned up a single similar ut unresolved XP case though a MAC user indicated this was an operating mode he could actually select or disable with a certain keystroke combo but nobody seemed able to translate the MAC sequence into an XP equivalent to even see if his observations had any merit in a Windows world. Any assitance or suggestions are welcome as she is getting ready to return to school which means a new laptop if I can't get thisresolved timely... TIA Bob
  • RFTechno Aug 24, 2008
    Somehow I do not view contating other forums and waiting for a response that may or may not come to be a solution particularly since I'm a CNET member and could have gone there myself... Is this all there is?
    Genius:
  • 2,035 Answers
Try this ,
1) Power On Display Setting (in TSETUP).
2) Display Panel Position upon power-up.
TheTSETUP options allow for internal, simultaneous and external. Thedisplay selection hotkey (Fn + F5) alternates between these modes inthis same order.
HOWEVER:
If the display panel is closed uponpower-up (long enough for the POST to complete) then the video outputis automatically routed to external. This happens even if the Power OnDisplay Option of TSETUP is set as INTERNAL.
Normally - this can beremedied by hitting the selection hotkey combination once, to toggle tointernal display if the panel was accidentally left down.
·UNLESS: Power On Password is enabled, in this case the password couldbe entered blind because the hotkey won't respond until security ispassed
· OR - turn off the computer and power on again with the display open.
If you want to try to update the driver: Please use this link..
http://www.csd.toshiba.com/cgi-bin/tais/su/su_sc_modItemList.jsp?moid=1468779&rpn=PSMB6U&ct=DL&BV_SessionID=@@@@1589898012.1219545706@@@@&BV_EngineID=cccgadeemhjmkdecgfkceghdgngdgnj.0
Good luck...
Posted on Aug 24, 2008
    Genius:
  • 1,011 Answers
Dear Sir,
This is the problem for not updating the video drivers of your laptop. I suggest to install the Belarc advisor from http://www.belarc.com/free_download.html and install it. It shows the detailed profile of your installed software and hardware, missing Microsoft hotfixes, anti-virus status, etc...... After installed it opened a webpage like html site and there is separate column of Main circuit Board details.
The details is to send me i will find the exact video drivers link for your laptop. ok. Once you have updated the drivers, hope it will be OK.
thanks
good luck
    Master:
  • 848 Answers
This link might help to solve your problem
http://www.laptoprepair101.com/laptop/2006/08/17/bad-video-on-lcd-screen/
    Brigadier General:
  • 6,966 Answers
How is the display before Windows XP loads, say during CMOS/BIOS configuration? If the colors are also way off, then possibly hardware, but if normal than Windows display configuration.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
    Master:
  • 623 Answers
Visit this site
www.toshiba.com/
  • 1,586 Answers
I don't know what to tell you to check on this, but two other places to check for answers are www.cnet.com (the user forums) and www.expertsexchange.com - both have high-level technical knowledge available (as does this forum, but no one has yet replied) and may be able to help you out.
I have a negative Problem with my 37 Philips LCD.I have it only 3 years and suddenly it starts to show negative colors. Is any one know how to solve it?
T'Con board fault. Replace it. Contact any service technician.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Aug 09, 2015 | Philips 37PFL5332D 37 in. LCD Television
Dim screen on HP. Any diagnostics I can run to isolate the problem?
The problem is in the inverter board, "located below the screen" or the backlight behind the LCD display is faulty. In most cases the inverter is the issue and replacement only option, "be aware that high voltage is present when running"
Apr 15, 2012 | HP Compaq nc6220 Notebook
154P1-L04 monitor has lines in my Dell 6000. I bought another monitor and it looks like a old photo negative and hard to read. Cepia look aswell
Either the video adapter is bad or the driver is corrupted. Go to dell.com and download and reinstall the software driver for your model. If it doesn't change the appearance, try the monitor on another pc/laptop. If still bad, monitor display is defective. Thanks
Jan 08, 2011 | Samsung LTN154P1L04 COMPATIBLE LAPTOP LCD...
I can barely see the screen, its very dark. Its a toshiba satellite m115 s1061
Try attaching an external monitor to the laptop & see if you could get any display on it. If this is successful, then you might have either a faulty LCD cable or screen inverter board.
The LCD cable transfers data signal from the motherboard & video card to the LCD screen. It also supplies high voltage DC power to the screen inverter board. The screen inverter board works as a power supply for the backlight lamp mounted inside the LCD screen. It converts low voltage DC power to high voltage AC power needed for the backlight lamp.
Sep 05, 2010 | Toshiba Satellite M115-S1061 Notebook
Fuzzy Screen Display
this sounds to me that water has leaked into the screen
Apr 11, 2009 | Nintendo DS Lite
LCD screen goes to "negative" like image.
you can try reinstalling your video driver.you can download this from dell.
Mar 04, 2009 | Dell Inspiron E1705 (DNDWGA3) PC Notebook
Negative Display
You could try a system restore to set the graphics back to normal. This would uninstall programs you installed since the restore date, but doesn't affect files and folders.
To run System Restore:
Start, Programs, Accessories, System Tools, then select System Restore. Choose a restore point before the problem occurred. It will take about 15 minutes, and hopefully your problem will be resolved.
Jan 04, 2009 | Toshiba Satellite M115-S1061 Notebook
Display problem
Well what i would do is get an external monitor and hook it up and see if you see video on it.
Sometimes the inverter might be bad or the bulb or just the monitor itself.
I wouldn't imagine you need to replace the whole laptop I would try each step and see if it's somthing that you want to do.
If the inverter is gone you can put a flashlight to the LCD and see everything in the background like shadows ect.
If the bulbs are gone can be the same thing with shadows ect.
If the LCD is bad you won't see anything and then it's upto you if you want to purchase another LCD which some people buy from ebay for around $100 give or take.
If it in fact is the motherboard you could buy it off of ebay they have alot of refurbished to new motherboards for affordable prices
Happy Holidays
Dec 24, 2008 | HP Pavilion dv1000 Notebook
Display Issue
Toshiba makes a great laptop but the display video or lcd seem to go bad very quickly I have replaced the lcd in many to solve this problem but be aware a few also had bad video cards (unlikley in your case as the external video is fine) it would seem as the lcd panel has gone bad on yours. the average replacment is around $100.00 to $300.00 depending on where you purchase from.
Oct 24, 2008 | Toshiba Satellite M115-S1061 Notebook
Screen in negative
This looks like a problem the hinge cable that drives the video LCD display, or a at worse the LCD driver IC on the motherboard. but these units are fairly stable please elaborate
cliff
Aug 02, 2007 | Durabrand PDV-709
Toshiba Satellite M115-S1061 Notebook Logo
112 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
