Question about HP LaserJet 2100 Printer
Smudged printing Printing is smudged ... 'looks like a car tire drove over it' is the best way to describe it. Have done the cleaning routines .... what else can I do?
  • 138 Answers
Sounds like you are either having a cartridge or fusing assembly issue. Here's how to isolate it. Look at the "tire tracking" and find where the mark repeats itself. Measure the distance between the 1st occurance and the repeat and use the guide below to identify the source.
38mm or 1.5" = cartridge
55mm or 2.17"= cartridge
62mm or 2.44" = Lower Fuser Roller
74mm or 2.91" = Upper Fuser Roller Film
93mm or 3.66"=cartridge
If the spacing is cartridge, simply replace the cartridge. If it is fuser you will need a replacement fuser. Replacement rebuilt fusers are available for about $65.00 plus shipping on exchange from Dale at Seattle Platen, 1-800-221-2388.
Posted on Aug 28, 2008
Canon printer is printing with smudged text, how do I resolve it?
Most Canon printers have a clean print heads function. Search the menus until you find it. This is maintenance you should perform on your printer routinely. Once you do that and it still is smudged, remove the ink cartridges and clean the end of them carefully (you don't want ink to go everywhere). Look where the cartridge(s) connect to the print head. They may be dirty as well and need to be cleaned. Go to the following website and they go into specifics on how to clean your printer:
How to Clean Clogged Printer Heads
Nov 15, 2017 | Canon Office Equipment & Supplies
Printer smudging
sounds like the rollers are contaminated/ and or the print heads have stuck on them. you can use alcohol on a cotton swab to clean them.
Oct 13, 2013 | Kodak Office Equipment & Supplies
Smudged horizontal lines
Try cleaning your rollers, it worked for me. I hope this helps.
Feb 13, 2013 | Canon Pixma MX410 All-In-One Printer
My bizhub c250 is printing smudged copies. It seems to have print a lite image from a previous copy. Im left with a streak along the top of what Im trying to print out. Any suggestions? The smudge is...
Hi Mike13660,
Usually the fault you are describing is caused by the fuser section being left in envelope mode.
Open the right hand side door, then lift the grey fuser cover up. Look at the levers on the fuser unit, make sure they aren't pointing at the envelope symbol. If they are, push them upwards. then close everything and try again.
Feb 09, 2011 | Konica Minolta bizhub C250 All-In-One...
Use a hp deskjet 35200(3500). when unit is printing all lines are blurd and paper gets black streaks all over. The printing is unreadable and smudged.Is there a manner to clean this up?
Streaks:Cleaning interior
Start a print from tray 1/manual feed and just as the trailing edge of paper is entering the machine; quickly open it to stop print and take out the cartridge and look at it
Feb 06, 2011 | HP Office Equipment & Supplies
Smudged on right side
If cleaning the print cartridge with the built in slide does not work then you can lightly shake it. it may need to be replaced. Also the cleaning of the drum with denatured alcohol will clear that up sometimes.
Nov 30, 2009 | HP LaserJet 4 plus Printer
Photos print wet and smudged
all the dx /cx range do this when printed on the high quality settings you just have to let ink dry about half hour or use a lower seting when you print on gloss paper hope this helps
Dec 07, 2008 | Epson CX8400 All-In-One InkJet Printer
Epson Stylus CX5000 blurry or smudged printing
epson uses pigmented ink and compatibles use dyes and thus if the paper is not of good quality then you can have this problem.
do the following
change the paper and try.
As there will be ink in the head and the ink feed tubes , print some 10 -15 copies of all color prints so that the original ink starts to get into the head and then the paper.
this should solve your problem
Also use your printer every 2 -3 days if you dont have any prints then give a noozle check and then switch off the printer. This will avoid the printer from doing a head clean very time you switch on the printer and also the ink will give you more output as there is less amount of head cleaning
Aug 09, 2008 | Epson Stylus CX5000 InkJet Photo Printer
HP LaserJet 2100 Printer Logo
229 people viewed this question
Ben Johnson
