-   After cleaning unit my humidifier wont blow any mist. No lights are on and Water detection bobber is okay.
-   Guest
Dec 05, 2008
-   cleaned my humidifier changed the filter and now the orange light says on and no mist is put out -   einnoc
Dec 05, 2008
-   cleaned and changed filter as I always have, worked fine before but
now will not work.-   einnoc
Oct 02, 2008
-   I cleaned it out and replaced the filter cartridge as I have done at least twice before and now the orange light that usually indicates the water tank is empty never turns green and mist never comes out.-   adambender
Interestingly enough as soon as I posted here, I was able to find the source of the problem. It appears that during cleaning the water level sensor, a bobber which normally floats as the water level rises, became stuck the to bottom of the water base - see below for the picture. I was able to use a small wooden spoon to lightly apply pressure and release the bobber so that it could float, and instantly the vapor started flowing again.
I haven't used the Air o Swiss #7133 humidifier in a while - I took off the water reservoir to clean...
(More)
I haven't used the Air o Swiss #7133 humidifier in a while - I took off the water reservoir to clean the bottom section and noticed a part on the bottom that has a metal attachment and a wick of some sort - not sure where this goes.. It kind of looked like it did not belong there. Any ideas?? Thin part about 5" long with a white wick in the middle - perhaps some overflow piece??
I have one packet of replacement material for the cartridge. Do I just poor out the old material...
(More)
I have one packet of replacement material for the cartridge. Do I just poor out the old material and put in the new in my Air-O-Swiss 7133?
I recently cleaned my Air-O-Swiss and now the humidity detector says its 80% all the time (which is...
(More)
I recently cleaned my Air-O-Swiss and now the humidity detector says its 80% all the time (which is definitely not true). Any ideas on how to reset or fix this? I've tried drying it outdoors completely, but no luck.
