Question about Delphi XpressRC XM Satellite Radio Receiver with Vehicle Kit
Xpress RC Not turning on
Radio was working, it has been working. I checked & tested all power up into the holding cradle. Evrithig has power, yet it will not turn on no matter what I try? The delphi.com that's mentioned on the users guide cant find any tech support there. Can anyone help? please!
  • Rolando4333 Aug 24, 2008
    I tried your previous solution.Disconnect all power, wait at least 1hr. press power button while plug in power supply. The screen flashed very quickly and went black again and will not turn on. Still radio not turning on at all.
    Genius:
  • 1,665 Answers
    Scholar:
  • 163 Answers
Its cover must be revoved to inspect for any fuse blown and power supply output.
If warranty has not expired better take it to an authorized service shop.
Posted on Aug 24, 2008
    Genius:
  • 1,011 Answers
Have u checked it by changing battery.
regards,
dont rate it untill helpful
    Genius:
  • 1,269 Answers
If you can open the casing, check blown fuse or any related internal circuit components. Also please test the power cable itself
    Genius:
  • 2,035 Answers
Try to reset the unit by removing the battery and power source from the unit ,IF your unit still under warranty you can get it serviced by the company: please use this link to contact the company support:
http://shopdelphi.com/consumers/support/faqs/nav200/#18955
Good luck/..
  • Anand Kumar
    Anand Kumar Aug 25, 2008
    This could the problem with battery you need to replace the battery on unit ,you can search the internet for completable battery ,but you need do it yourself this may result in out of warranty or you can give to company if its under warranty or you give to local electronic service center to fix the issue...
    Brigadier General:
  • 6,966 Answers
Initially, pls try:
  • removing all the power connectors to simulate a reset and unit will revert to factory defaults. Let the connectors off for an hour or so. Thereafter, pls try again.
  • press on the power button when reconnecting the power connector.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
  • Louie  Role
    Louie Role Aug 26, 2008
    Hi again,
    Your postback/comment that the "screen flashed very quickly" is significant. This is indicative that the battery is not getting charged which in turn could mean:
    • the lighter adapter is not providing +5VDC, pls recheck using a DVM. It may also be possible to be reading +5VDCV (but with no load) meaning their is voltage but goes down when plugged in. This is open the case when the cigarette lighter adapter has corrosion on either its tip or ground/body. You can also check for corrosion, loose connection in the internal fuse holder of the lighter adapter. Scrape the tips/terminals/connectors to ensure positive contacts;
    • the battery itself would need replacement;
    • the internal circuitry of the Delphi would need a looking over. It is receiving power (+5) but is not charging the battery;
    • firmware problem. normally would reset when internal battery is removed. Would require an in service repair if faulty.
    Would appreciate further updates.
Xpress rc - my display will not light anymore and/or flashes in and out like a neon light...is there a fix?
my pioneer radio was workin fine untill i was messing wit the wires in tha back n the ignition wire sparked aginst my keys. is this y my radios screen light does not work anymore?
Mar 17, 2010 | XM Radio (XMP6000)
Xm radio
Looks like my company is going to purchase a new fm radio for the company truck, I should be able to plug the xm radio into it.
Jun 03, 2009 | Delphi SKYFi XM Radio Receiver
Delphi Skyfi2 won't turn on anymore.
I have the Skyfi 2 with car cradles. I have had them for about 7-8 years. I bought two brand new power cords to use with the cradles so I could move the Skyfi 2 to different vehicles. Neither power cord will power up the Skyfi 2 when in the cradle. I contacted the company I bought them from and they sent me two more cords. These cords are brand new as well. They too do not power the unit. My original power cord still powers the unit but I am trying to eliminate having to move it to each vehicle. I then bought a complete unopened kit from ebay. Using the new kit parts only, my Skyfi 2 will not power up. Did they change the kit since I bought mine and now it is not compatible. Everything looks identical so it is driving me nuts. Any help is appreciated, Thanks!
May 29, 2009 | Delphi SKYFi2 SA10101 XM Radio Receiver
The remote does not turn on the Delphi XM Xpress on car unit
This problem is caused due to the fact that xm has designed there radios to completely shut off all power with the unit therefore the unit once off will not be able to recieve information from the remote. This manufacturing defect was confirmed by the xm representative, they also explained that the company is currently planning to fix this issue on the new 2009 model xpress rc
Mar 30, 2009 | Delphi XpressRC XM Satellite Radio...
New Delphi installation over older delphi car kit
Just installed the xpress RC in my Durango, replacing my SKYFi2. Both units are Delphi (all of the newer xpress RC's are made by Audiovox now, but Amazon sent me the Delphi made unit). Everything swapped out with the exception of the 12dc power cord. Had to use the one included in the new unit, plug size that goes in the new cradle for the RC is different. In the new unit I did get two "user guides" in Spanish and none in English (I wish America would adopt one friggin standard language. English) but other than that it was quick and painless.
Jan 07, 2009 | Delphi XpressRC XM Satellite Radio...
In circuit remote sensor is broken
IT IS VERY SIMPLE TO CHECK THE REMOTE CONTROL FIRST . WHAT YOU NEED IS A RADIO THAT HAS AM BAND ,TUNE IT TO ANY AM STATION THEN HOLD THE REMOTE CONTROL CLOSE TO IT AND PRESS ANY BUTTON IT SHOULD MAKE THE RADIO SOUND DISTORTED EXAMPLE (TA TA TA) IF THAT HAPPENS THE CONTROL IS WORKING . IF NOT THE R.C. IS DEAD . PLEASE PROVIDE FURTHER DETAILS AFTER U PERFORM THIS TEST
Nov 18, 2008 | Televison & Video
TH-79A amateur radio
TH-79A Kenwood HT and with the power off, hold down the MR button and the PTT switch, and while holding both of these turn on the power. The HT will come up in the remote control mode with the display indication "RC" on one band and the normal display on the other band.
To get the HT out of the "RC" mode just repeat the MR+PTT+Poweron sequence
Oct 30, 2008 | Kenwood PB-34M, ,TH-22AT,TH-42AT,TH-79A,...
Delfhi Xpress RC
Turned unit on and setup 88.3 FM and I get no connection to any stereo? The Antenna is about 75% or better signal but no sound at all. I plug my old Roady XT into the same power and antenna and it works fine on any FM frequency?? Any help would be great.
Jul 28, 2008 | Delphi XpressRC XM Satellite Radio...
Screen locked on "Checking media"
When the radio locks up on the Checking Media page you hold the + button to the volume and the MODE button wait for 3 seconds and it will turn off...  Thanks to Delphi for this assistance!!  Chris K.
Jun 02, 2008 | Delphi SKYFi3 XM Radio Receiver
Delphi XpressRC XM Satellite Radio Receiver with Vehicle Kit Logo
701 people viewed this question
Top Delphi Audio Players & Recorders Experts
John
John
Darrell
xxxxxx xxx
Are you a Delphi Audio Player and Recorder Expert? Answer questions, earn points and help others
