Question about Samsung SF-560 All-In-One Laser Printer
Jam 1 and no cartridge error message - Samsung SF-560 All-In-One Laser Printer
If you have a sf-560R then you will need the correct toner cartridge.
Posted on Jan 09, 2009
  • 146 Answers
According to Samsung the power supply board can be damaged if the toner/drum cartridge is removed and/or installed with the power on. The exit flag optical sensor is located on the power supply board and this is why the message appears. Jam 1 and Jam 2 means replace the power supply board. Jam 3 means replace the main board. Of course be sure to check the mechanical function of the sensor flags to make sure they are not broken or a spring has come off before replacing boards. Also be sure to power down and unplug unit before swapping consumables.
Posted on Dec 22, 2008
Error message is " paper
Check for a tiny piece of paper or some toner that may be covering a sensor.
Jan 07, 2011 | HP LaserJet P2055d Printer
Printer reads out "Carriage Jam". Have done all the usual stuff.... shut down,unplugged, cleaned around connections and still reads out "carriage jam". Makes a lot of noise after opening carriage and...
hi
v\:* {behavior:url(#default#VML);} o\:* {behavior:url(#default#VML);} w\:* {behavior:url(#default#VML);} .shape {behavior:url(#default#VML);} Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Hp Cartridge issue
Complete the steps below in the order presented to resolve the problem. It might not be necessary to complete all of the steps.
Step one: Reset the printer
  1. Without turning the power off, remove the power cord from the back of the printer and from the wall socket.
  2. Wait 30 seconds and reconnect the power cord to the printer and to the wall socket. Turn the unit on if it is not already turned on.
  3. Check the printer for the error message. If the error message still displays, go to the next step.
Step two: Clean the cartridge contacts
Figure 1: Lifting the top cover
Lift the top cover.
  1. Locate the ink cartridge indicated in the error message. Squeeze the gray tab below the cartridge slot to release the latch, then lift the latch.
Figure 2: Unlatching cartridge
1 - Black cartridge
2 - Color cartridges
  1. Remove the cartridge indicated in the error message.
Figure 3: Removing cartridge
Gather cleaning materials:
    • Distilled, filtered, or bottled water (do not use tap water or alcohol or platen cleaners)
    • Lint-free cloth or swab. Eyeglass wipes and coffee filters work well.
  1. Lightly moisten the swab and squeeze out excess moisture.
  2. Holding the cartridge by its handle, wipe the copper contacts.
Figure 4: Wiping the contacts
1 - Copper contacts
  1. Replace the cartridge, then close the latch and the printer top cover.
Jul 29, 2010 | HP OfficeJet 6210 All-In-One InkJet...
MFC-640CW Switch on error message: "Unable to Init! - User Guide says this is a mechanical fault or jam - not a jam all clear. There is an empty Cyan ink cartridge message as well which is correct. Also...
If there is no jam it is generally a mechanical issue such as...
1. The planetary arm assembly not engaged correctly
2. Ink cartridge/purge switch harness not connected correctly
3. Purge cam switch broken
4. Gear(s) on maintenance unit broken
5. Paper feed motor broken
6. Main PCB defective
I find that if there was a paper jam, and the user pulled the paper out, option 4 is most likely. It is the smallest of cracks but ruins everything!
You will need to contact your local ASC for repair, find it here.
Thank you for using FixYa! – Don’t forget to rate our service.
Nov 09, 2009 | Brother MFC-640CW All-In-One InkJet...
59.40 error code
That's a main motor error, something could be jammed in transport, or a generic toner cart. that is too hard to turn, try powering on with toner removed...
Aug 20, 2009 | HP 4250 Monochrome LaserJet Printer
Error message everytime i print
the E error message is for 2 reasons.either its a paper jam in the printer or the cartridges r faulty.there r two cartridge 1colour and 1 black.as 1 of them may had gone faulty.just replace the cartridge and it will work properly.
Dec 15, 2008 | HP PSC 1315 All-In-One InkJet Printer
Error inkcartridge
Error message: No color or black ink cartridge-->Press the Color Copy button to install a new ink cartridge.
Solution: The indicated ink cartridge is not installed. Please install the necessary cartridge(s).
Error message: Color or black ink out -- >Press the Color Copy button to begin replacing the ink cartridge.
Solution: The indicated ink cartridge is out of ink. You will need to replace the necessary ink cartridge(s).
Error Message: Ink cartridge error -- > Press the Color Copy button to begin replacing the ink cartridge.
Solution: There is something wrong with the ink cartridge. Make sure the cartridge is genuine Epson ink. Also, try reseating the cartridge (remove it, and then reinstall it).
Error Message: Paper jam or misfeed -- > Press the Color Copy button and clear the paper jam by hand if necessary.
Solution: Paper is jammed. Check for any obstructions under the unit's cover, and in the paper tray.
Error Message: Paper out -- > Load paper in the sheet feeder and press the Color Copy button.
Solution: Load paper in the sheet feeder, and then press the Color Copy button to continue printing.
Error Message: Scanner unit open -- > close the scanner unit
Solution: Carefully close the scanner and press it down until it clicks securely into place.
Error Message: Scanner error -- > See your documentation and call service if necessary.
Solution: Press the ON button to turn off the Epson Stylus CX3200. Unlock the transportation lock, if necessary. If it is already unlocked, toggle the lock back and forth, 5-10 times. Turn on your Stylus CX3200 again.
Error Message: Printer error -- > See your documentation and call service if necessary.
Solution: Press the ON button to turn off the Epson Stylus CX3200. Disconnect it from power, and then reconnect it to power. Press the ON button to turn on the Stylus CX3200
Nov 28, 2008 | Epson Stylus CX3200 All-In-One InkJet...
Supply Memory Error
It sounds like you are having two diffrent problems. I don't think they are associated with each other.
First, the memory supply error. The cartridges on this machine have a chip. The chip could very well be faulty causing this supply error message. Change the black cartridge and see if the message clears. if it dosen't then the antena that reads that chip needs to be replaced. I suspect the cartridge is the problem.
Second, the paper jams. This can be caused by a worn p/u roller as you mentioned. Sounds like the jam happens first then the error, based on your description.
The black thing you refer to on the door is called the "transfer belt assembly".
Aug 21, 2008 | HP Color LaserJet 2600n Printer
5300 kodak eazyshare printer
Well, here is the proper way of fixing or troubleshooting that paper jam error in your printer
Open the printer access door and remove both of the ink cartridge, then remove also the printhead, after that close the printer access door, without those parts. Then it will show a message in the printer screen, "Printhead is missing or has come loose" or "Printhead Not Detected" Install the printhead, just the printhead without the ink cartridges. After that close the printer access door. Then it will show you a message"Ink cartridges is not installed,install ink cartridges". then open again the printer access door, then install the black ink cartridge without the color ink cartridge. then close the printer access door, then message must be " Color ink cartridge is not installed, install color ink cartridge" then install the color ink cartridge." the message must be,"New printhead is detected calibration require, load paper and press start"
Thats the way of overiding the paper jam error message of your kodak all in one printer
hope this will help you guys
by: E.brown
Happy Printing(", )
Kodak AIO tech support 1-800-421-6699
Jun 04, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Printer shows Carriage Jam, but I can't find it.
many reason coses carriage jam bout i think that the in coder belt faulty
Mar 23, 2008 | HP Photosmart C4150 All-In-One InkJet...
Carrier Jam
i have a problem with my printer it gives a message saying 'clear carrier jam' with a big noise.its not working it is going too fast
Sep 26, 2006 | Lexmark P6250 All-In-One InkJet Photo...
Samsung SF-560 All-In-One Laser Printer Logo
1,005 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
