Question about Compaq Audio card Sound Card
No sound from my computer
Music, movies, and any sound that comes out of my computer doesnt come out of the speakers but after looking into it everything says its working properly Can not set up program and not found CD-Rom
Loss Audio Driver: AC Realtek 97 by upgrade
System Operation: Window xp professional 2006
Model: Compaq Evo D510 SFF
Board: Compaq 07E4h
Version 68602 v 2.20
System Type: x86 based pc
COMP: T309 KN9Z 1619
  • Anonymous Oct 15, 2008
    no audio device found
  • 83 Answers
Hey Mathsafet
You Need To Install The sound Max
And here Is
------Download Link-----
Posted on Aug 24, 2008
I have no sound in my computer i need to know what to do ???
Posted on Nov 09, 2008
I have no sound and wont print.tryed to reinstall printer software loaded but printer is not in where printer
is not in printer set up.
and gives me messegs. print spooler not running/rpc server not available.
can any one help.thanks william
Posted on Oct 16, 2008
  • 52 Answers
Hii
listen friend in your computer in sound setting if you have
them
not in game . the drivers stuff .
see if you can switch the output singal
My dell laptop doesn't produce any sound
first try to check if you have a sound driver.... if they have try to update...., if doesnt work try to connect usb powered speaker.....then try again to play a cd movie that you want.....
Jan 11, 2013 | Dell Latitude D610 Laptop Computer -...
I hear echo sound every time i play music/movie and i cant figure out to turn it off "how"
Does it happen with headphones in as well? If not, do you have a built-in-microphone? Sometimes the sound coming of the speakers can be picked up by the microphone, resulting in an echo sound. Make sure that the microphone is off (or test it by covering it up while playing some music), and quit out of any applications that are using it.
If you hear it in the headphones as well, it could be a sound card problem, which means it would need replacing. If you don't hear it in the headphones, but hear it in the speakers and don't have a mic, it's either your speakers, or (more likely) your computer just doesn't get along with whatever software you're using to play movies/music.
Sep 17, 2011 | Acer Aspire 6930-6771 Laptop
All speakers on x-530 pass test but no sound comes from the center speaker when movies or music is played
Is the speaker system set up in Windows as a 5.1 speaker system? If so, the problem with the sound is the program used to play the audio. For example if you are watching a movie and the player used does not support 5.1 then it will not play the audio properly. If the sound works correctly playing a game in 5.1 you should be able to figure it out from there.
Mar 09, 2011 | Logitech X-530 Computer Speakers
I using conexant hd idio inputand output device. I record my sound but after play back i cannot heard sound
If you cannot hear the sound you have recorded. Make sure that the sound you record generates the visual pattern. This confirms that at least your microphone is working.
  • In any of the upper case your audio driver must be install and your audio hardware must be in working order. You can check this in Windows Device Manager. To go to device manager you right click "My Computer" in XP and In Windows Vista and Windows 7 its "Computer. After right clicking it select Manage and on the left pane select the Device Manager and you will see the list of devices and their installed drivers. Make sure all the audio devices and there drivers are not showing any errors.
  • Make sure that you speakers are not mute. If you take a look at the bottom right corner of your computer screen you will see a speaker icon.make sure there is no "X" or any other RED signs on them which represents mute states.
  • Similarly check other related settings. Go control panel after going to the start menu and look for the "Sound" icon and make sure there is not anything suspicious.
  • If all the above is fine and okay than look for any problems in your speakers that are open or if you are wearing them as Headphones or earphones and try to replace them to test them. Maybe the sound is coming but the speakers might be faulty make sure you increase the volume of the speakers when you hear any recordings.
  • Make sure the speakers are okay by listening to music or movie that you might get free from internet or in Disk collections. This is the way you can easily detect the problem.
  • If you can hear sound from music and movies than your microphone hardware might be faulty.
Good Luck!
Jan 14, 2011 | HP Pavilion Tx1110us Notebook
The speakers wil not play on the background and the center.
If you connected to a 5.1 surround card and checked and they are connected ok you can hear all the speakers when you play music, movies that are in 5.1 format only. If you want to hear also all of them if you listen to stereo movies/music you must set the sound card to emulate multi channel. Also the player you use to listen music/wath movies must be set to 5.1 and must accept Dolby Digital/ DTS decoding if your sound card doesn't(eg. VLC media player-has integrated DD and DTS decoding and codecs for all tipes/formats).
Oct 13, 2009 | Logitech X-530 Computer Speakers
Z5500 : No Vocals Coming in 5.1 Movies
The same thing happened to me and i just had to reset the system by turning it off and then holding input+settings for like 5 seconds until it shows what firmware version you've got it meqans it's reseted and that should solve your problem.
Apr 03, 2009 | Logitech Z-5500 Computer Speakers
I can't hear people talking when i watch a movie?
I had the same problem and found that there was a connection problem with the center speaker. Do a sound check on all speakers and see if the sound is coming out of the center one. If not then just check you have connected it properly.
Jan 01, 2009 | RCA DRC220N DVD Player
Technics
are you trying to use the surround sound for movies or music ? , ive got the dvd version of this system (sc-dv290) and ive noticed the surround sound tends not to perform well with music , but sounds great with movies. i think its because the movies have dolby digital and music does not. The dolby pro logic in my opinion doesnt really make that much of a difference in sound unless the sound is cranked up past 44db on the amplifier. the only cables you need are the ones that are attached to the surround sound speakers and they cannot be removed so it cant be the wiring . I reckon you have a 1 - faulty system 2 - listening to music 3 - maybe not pressing the pro logic button on the sound processor. Hope this helps
Sep 11, 2008 | Technics SC-DV290 System
i make format 2 my lap top ok
and worke fine but there are no sound
but it give me finde new hard were >>
Aug 23, 2008 | Edirol UA-4FX External Sound System
No sound on movie playback
This camera does record sounds. But, it doesnt look like it has a speaker in it to play them. So, yes unfortunately you wont be able to hear what you record unless you are using something else to playback what you have recorded.
Good Luck.
Apr 09, 2008 | Sony Cyber-Shot DSC-S500 Digital Camera
Computers & Internet Logo
485 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
