Loss of video, then auto shut down. No further Pc operation
Greetings Everyone:
First, allow me to describe this set up, and then to the current status.
  • A GigaByte GA-K8NXP-SLI ATX Mobo with a 939 socket
  • An AMD Athlon 64 FX-55 CPU
  • An ATI Radeon X850 XT & Same card with X850 PE
  • Four (4) Crucial Ballistix 1 Gig each memory sticks
  • A Creative SoundBlaster Audigy 4
  • Two 400 Gig Hard Drives Raid / SATA Striped configured with individually mounted fans -800 Gig / 100G space being used
  • Two large radiator: One at front intake & one at rear at exhaust with tubing from reservior see-thru tank to the pump, to the CPU, to both radiators in a loop with non-conductive XP Fluid & temperature gauges for monitoring plus alarm.
  • A 700 watt power OCZ supply
  • All other periferals not worth mentioning.
  • Windows XP Pro., SP2 and hardly used for gaming. Mainly business related uses and website building.
  • I even Hvac air from duct tapped from central heating and air in proximity of air intake fan in front of front radiator.
  • I know,.. It's like having a racecar to go to the corner store with. But the capabilities were there.
    Then, when all of a sudden, striped lines to the far left of the monitor screen, blank darkness and auto shut-down of the whole Pc. Pause, and there was an 'Uh-oh'. The attempt to restart, and nothing. I had another power supply on hand, so I changed over temporarily and the computer started - but no video and no sound.
    First guess was to obtain another power supply and video card (for just in case) Upon their arrival, they didn't make a difference. But now, the little dancing lights that usually turn on from the Crucial Ballistix Ram DDR cards don't do a thing and into a few minutes of the pc running, it shuts itself off.
    Any suggestions of what may have happened would be great. If the Motherboard, I can replace but then how to restore raid and configuration to bring all records back as before.. (Bios maybe) and No, I didn't use a back up, but it's all there between two striped hard drives.
    • Anonymous Oct 29, 2008
      magaria
    • 781 Answers
    I reckon you have cooked the M/board
    Posted on Aug 24, 2008
    What causes PC to shut down during idle?
    This might be down to the power settings, by default the hard drive is set to shut down after 15 mins of inactivity, to check open control panel and select Power Options, this will show you the current plan settings, click the Change plan settings and then Change Advanced power settings, expand the Hard disk option and then Turn off hard disk after, this will show the time this can be set to 0 which will stop it shutting down.
    You can also adjust display settings etc. in this area at the same time.
    May 13, 2014 | Microsoft Windows 7 Home Premium 64BIT...
    Hello, I recently purchased a Logik mp3 player, model number L8BGMP410. I am very happy with this handy way of carrying around a few hundred of my favourite recording. My only problem with this device...
    You can set the auto off time.The available option are 15,30,60,120 minutes and disable.
    How you can adjust is described on page 26 of the user manual which is download-able from here:
    http://diplo-best.com/review/LOGIK/L4GBMP410
    Thanks.
    gylacz
    May 03, 2011 | Audio Players & Recorders
    Microsoft Windows 7 is not running to well with my Compaq Presario 5000. It actually never ran good in all of the MS Windows...even WinXP. The big issues i'd like to resolve (and as mentioned...these...
    There isn't any problem with windows 7 not running well with your pc. The problem is with your pc's Processing system and RAm is really low. I would suggest you to change or upgrading the CPU and RAM in your pc.
    Please let me know if you have any further questions or concerns.
    Thanks.
    May 25, 2010 | Compaq Presario 5000 PC Desktop
    Describe your acer monitor al1914 Problem screen not working right. The clarity and the color are dim. Tried to auto reset, but no luck so far. please help!
    As far as the clarity concerned, the PC Video setting should be set to the native resolution of this monitor, which is 1280 x 1024 @60Hz for best picture.
    Try it on another PC also, otherwise you may have to open it up but we need to narrow down the problem first.
    http://s807.photobucket.com/home/budm/allalbums
    http://en.wikipedia.org/wiki/Capacitor_plague
    http://www.badcaps.net
    Please post back what you find so we can guide you further and will also help other people as well.
    Apr 10, 2010 | Acer AL1914 19" LCD Monitor
    Yamaha RX-V1600 shuts down in seconds
    Your Yamaha RX-V1600 has an audio output transistors are mounted to a large heat sink which keeps them cool during operation. They are electrically isolated from touching the heat sink by an electrical insulating washer. But, in order to keep them cool and allow for good thermal conductivity of the heat generated by the output transistors the washers are treated with a heat conducting grease. Over time this grease will dry out and lose its heat conductivity ability allowing the temperature of the transistors to rise; as the heat goes up they conduct more current and cause the protection system to activate and shut the set down (in order to avoid damage to the set).
    You need to check or replace the transistor that's on the heat sink. Or you may contact a pro to replace it for you.
    Mar 14, 2010 | Yamaha RX-V1500 Receiver
    I am going to install a new graphics card, do i need to disable my integrated card firts and then shut down and install the new one?
    In your BIOS it should be set so as to auto detect integrated graphics or AGP.
    This is the default setting for HP and Compaq machines.
    Install the card and see what happens, if you have no video, shut down the machine and either remove the new card and then set the BIOS to auto detect or if you saw the BIOS splash screen with the new card installed but got no graphics, then again go into the BIOS and set it to auto detect.
    Nov 03, 2009 | Computers & Internet
    Shut down of laptop after blue screen appears
    When you hit F12 or whatever F key to go to the boot drive menu, make sure the cd is in and that you select CD/DVD Drive and the dvd should prompt you to hit any key or will automatically start loading for the recovery. Just tell me if you need further assistance.
    Feb 01, 2009 | Toshiba Satellite A135-S2386 Notebook
    Camera shutting down and zoom not operating
    I took my camera apart again to show you a picture of it. The yellow arrows show the position where they used to be. The screws are next to the camera on the table.
    Greetings, Ron.
    Aug 14, 2008 | Pentax Optio A10 Digital Camera
    Malata #dvp-558 all regions dvd player
    Greetings esb1,
    On the Harmony website they have a nice feature that allows you to see if your current audio video equipment will operate with their remotes. You should be able to just select the type of unit, manufacturer, and model number and it will say if its supported.
    This handy tool can be found at:
    http://myremotesetup.com/EasyZapper/New/Main.asp?WebProcessAction=Start&ReturnUrl=%2FEasyZapper%2F%2E%2FNew%2FProcSpice%2Flanding%2Easp&ClassId=PrSpice%2EProcSpice&RelativePath=ProcSpice%2F
    Happy Channel Surfing
    Jon
    Go Ahead. Use Us.
    Jul 11, 2008 | Logitech Harmony One Advanced Universal...
    Minolta X370 film loading problem.
    Hi, check the camera set in auto /manually in auto function, check battery might drain the current , dis engage camera to lense to release the mirror by pressing button beside lense , turn lense in left or right .
    Feb 04, 2008 | Photography
    Computers & Internet Logo
    437 people viewed this question
    David Payne
    David Payne
