Question about E-Machines eMachines Monitor E15T4
What is correct resolution for e17t4w
Cannot seem to find the correct resolution setting for monitor, things are too small or too flat, etc.
Found correct setting on vista windows support, for emachines flat screen 17". the setting is 1280x720.
Posted on Aug 24, 2008
My Samsung SyncMaster 913V (Black) 19 in. Flat Panel LCD Monitor, does not work correctly. Every time I reboot my computer the screen only works for a few seconds and after that it gets black and a...
Resolution setting of computer is not compatible with spec on monitor. Adjust computer res setting to agree with monitor and you will be good to go. If settings are ok then the issue lies within the innards of your monitor.
Apr 15, 2017 | Samsung SyncMaster 913V 19" Flat Panel LCD...
My NEC MultiSync LCD 1765 monitor boots up to the lowest resolution available. When I attempt to correct the resolution through the Display Options in my Control Panel Settings, I set it at the highest...
Try connecting the NEC to a different computer, to see if it correctly accepts 1280-by-1024.
If so, then there's nothing wrong with the monitor, and the fault lies with either the video-adapter in your computer, or something messed-up with your installed copy of Windows.
Try replacing the video-adapter.
Dec 29, 2010 | NEC MultiSync LCD1765 17" Flat Panel LCD...
Are Dell monitors not compatible with older HP Pavilion Computer? I tried to connect my HP CPU to a Dell monitor and it will not recognize it at all.
It shouldn't make any difference which monitor you are connecting to any computer. In fact, I am running a 19" HP Flat Panel on my Dell Dimension 2400 right now. It is NOT a wide screen monitor as the Dell built in graphics card will not support the RESOLUTION RATIO required for the wide screen. Check what setting is "native resolution" for your monitor and see if your graphics card will support it. If not, using your old monitor, try different resolution settings. Right click on your desk top, click on properties and that should bring up the display properties box. Try a lower setting as larger settings are the ones that will give you a black screen. It will probably give you a smaller picture on your old monitor, or perhaps smaller or larger icons on the desk top. Accept the new settings, turn off your computer and switch monitors, and turn your computer back on. If you get a picture, but it does not fill the whole screen or the icons seem too large or small, then go back into properties from the desktop and try a different resolution ratio until the picture seems correct.
Jul 18, 2009 | Dell Computers & Internet
The monitor on my laptop is pink. I.e., all application backgrouns, start button, desktop icons, scroll bars, etc. etc. It has nothing to do with my "display settings." The pink comes and goes. Can anybody...
It has something to do with the connection between your screen and computer.
Try tightening or wiggling the VGA connector between your computer and screen.
Hope this helps!
Jun 22, 2009 | eMachines E17T4W 17" Monitor
My type pics etc looked squished horizontally
There is a fix have you tried auto configuring the monitor?
Apr 03, 2009 | Hannspree 22" widescreen LCD Flat Panel HD...
Monitor appearance is short and fat
set the resolution to its native resolution 1440 x 900 this should correct things.
Oct 07, 2008 | Gateway FPD1975W 19" LCD Monitor
Resolution problem
A Chip on the monitor circut board must be reflashed. You need to send back to Planar, do an rma. They were very responive to me, sent me a replacement.
Sep 07, 2008 | Planar PL2010M 20" Flat Panel LCD Monitor
Monitor is enlarged, wont return to normal size
Hi, three possible things. 1) You have activated the magnifier. Go to Start, All Programs, Accessories, Accessibility, Magnifier - deactivate, should be a small window bottom left of the desktop. or 2) Your screen resolution somehow changed. Right click on any clear part of the desktop, go to properties, Settings Tab. Adjust screen resolution to desired setting then click Apply/OK. or 3)You are in Safemode. Restart and if same large icons etc, do # 2. Hope that this be of some help to you. Pls post how things turn up. Regards
Apr 27, 2007 | Gateway FPD1960 19" Flat Panel LCD Monitor
E-Machines eMachines Monitor E15T4 Logo
149 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
