Question about HP DeskJet 952c InkJet Printer
Hp deskjet 952c printer does not print, how to clean ink jets?
Printer skips or does not print on paper. Both color ink and black ink cartridges are fairly new.
  • mitchell_fel Oct 21, 2008
    I have got a hp950c printer and both the cartridges are new, but it still prints a blank page
5 Suggested Answers
Bubbabear64
  • 2794 Answers
SOURCE: How to change black ink cartridge of HP Deskjet 6980
Lift the cover up.
The ink jet carriage should park in the center of the carriage.
Gently lift on the front of the ink jet until it removes. Some you have to lift up and some you have to lift down on. Just be careful.
HP inkjet cartridges tell you on the front of the stick by a dot weather it is tri color or black.
Posted on Jun 13, 2008
beetry_bulls
SOURCE: The color ink in my hp deskjet 920c won't work
try cleaning the contacts (bronze like) with dry cloth both the cartridge and the cartridge holder most of the times there exist some liquid forms on both areas. since you frequently remove the cartridges; their might be a broken part on the cartridge holder. the broken part, use, is to make sure the cartridge is in absolute contact with the cartridge holder's. the size the said broken part is 2 mm in all sides. so small that it has a big function.you dnt even recognize.
Posted on Sep 05, 2007
  • 10 Answers
SOURCE: HP Deskjet 5940 reversed ink cartridges
It is best for you to take time to a Hp Center. You will damage the cart if you try to take them out. Hp service center has special tools which they use to take the cart out. If you are really good to them they will even do it free for you. It will not take more than 10 mins for the job.
Thanks
Posted on Aug 15, 2008
wayneard
  • 1901 Answers
SOURCE: hp deskjet 3845 won't print in color
When you click on "Print" and the window comes up, click on "Preferences".
Click on the "Color" tab. There should be an option to print in color or grayscale. Select "Color".
Posted on Oct 18, 2008
leroyal
  • 2120 Answers
SOURCE: new tri color ink cartridge will not print red
Probably bad, there's actually no way to check ink levels.
Posted on Jan 22, 2009
My printer goes through the motion of printing but the paper comes out blank. I've an hp deskjet d2360 and there is ink in it
Possibility cartridge print head dry.
Solution 1:
Do a clean process
cartridge automatically. Press START - Control Panel - Printers and Faxes - HP Deskjet d2360 right click and select Printing Preferences - Select the Color tab - select Printer Services - select Clean cartridge, wait for the cleaning process is completed - Perform Test print. If the print test results, has good graphics, press Finish. If the graph is not clear or drop out, repeat the cleaning process once again.
Solution 2:
1. Open the cover printer, cartridges will move to the middle position.
2. Remove the cartridge (be careful, do not touch the element cartridges or print head by hand), then stick the tip cartridge (print head) to clean water
3. Then, attach the print head to a tissue paper. If there is a tissue paper used in ink (black cartridges, black block lines, and color cartridges, three color red yellow blue lines), means the flow of ink to the print head is normal. If the
tissue paper no trace of ink, attach back into the water, repeat the above process.
4. After process is complete no.3, clean the cartridges with a tissue paper (careful, do not touch the element cartridges or print head by hand, because it will damage the cartridge). After cartridge clear of the water, insert the cartridges into printer.
Sep 24, 2011 | Office Equipment & Supplies
My printer isn't printing from the black ink cartridge -only color. I've replaced the black ink cartridge twice, so I know it isn't the cartridge.
Run a few "print-head-cleaning-cycles", to UNCLOG the ink-jets that should be spraying the black ink onto the paper.
Feb 21, 2011 | HP DeskJet 3740 InkJet Printer
Prints ok in color graphics, prints text in very light blue, barely readable
Check that the jets are clean as it sounds like there may be a restricted flow of ink - assuming that there is sufficient ink in the cartridge. Try printing the test picture in the HP Printer Asistant software. This requires black as well and a lack of black would show up. If the black cartridge is full and you suspect that the jets are blocked, try leeching the jets clean by pressing a piece of tissue paper over them. If that does not help stand the cartridge in a saucer of hot water for a while, wipe off the bottom of the cartridge and try it again. There is also a cartricge cleaning sequence in the HP Printer Assistant probram
Jan 18, 2011 | HP DeskJet 3650 InkJet Printer
Color ink cartridge does not work
Have you tried the steps described on the HP website for what to do if you've got a missing color? Click here to view those instructions.
Give those instructions a try and let me know how it worked?
I am an HP employee. I do not represent HP on this website.
May 26, 2010 | HP DeskJet 952c InkJet Printer
How do i clean my head on my hp deskjet 952c printer?
just full ink cartridge and wipe print head under it, this model not same with other model that the printer head separate with ink cartridge.
Mar 25, 2010 | HP DeskJet 952c InkJet Printer
How to set hp deskjet 3550 inkjet printer to print in only black and white by ignore the color ink,for the important document. endliam< endliamc@gmail.com>
To Save the color ink you can change the printer settings to Black Only.
To Setup:
  1. Press START Button.
  2. Select RUN Command.
  3. Type these commands in CAPS.
  4. CONTROL PRINTERS and press OK or Enter.
  5. Now you will get Printers & Faxes Window.
  6. There you select the ink jet printer which you want to change the color settings.
  7. Right Click on it and Select Printer Properties later.
  8. Select Printing Preferences
  9. There you can see lot of window tabs (just like a worksheets). Depends on printer in any of the TAB you can see the option Black Only / GrayScale Printing Only.
  10. Choose the appropriate option and Select APPLY.
  11. Then give a test page for it.
That's it...
Hope this will be helpful to you..
Thanks & regards
Nandu :)
Dec 31, 2009 | HP DeskJet 3550 InkJet Printer
Have new ink cartridges, however when I print a test page, nothing but the windows logo prints
You mean, the black color is completely absent from the printed page? Either the black cartridge is faulty and needs to be cleaned, or (less likely) the cartridge carriage is faulty.
Try running the "Printer Head Cleanup" routine from the printer manager maintenance menu.
Aug 28, 2009 | HP DeskJet 952c InkJet Printer
Ink cartridges will not slide due to leaking ink underthe printer
Sorry to hear about the mess. Let's start with the clean up of the ink. Use a dry cloth or paper towel to wipe up the ink that has spilled out of the cartridge. Wipe gently so you don't do any damage to the internal components of your printer. The ink will likely color the inside of your printer - That's okay. Just make sure you get anything that puddles. It should not look wet.
On to the non-moving cartridge carrier. The standard fix for this is to do a hard reset on the printer. Follow these steps.
1. Unplug the power cord and remove the paper from the paper tray.
2. Move the carriage all the way to the right, close the lid and reconnect the power cord.
3. The printer will make some noise as it starts back up. Wait until it stops making noise.
4. Open the printer lid. The carriage should return to its normal position.
5. Try printing again.
If this does not work, then damage has been done to the internal components. You will need to get the printer serviced by a repair person.
Jul 20, 2009 | HP DeskJet 952c InkJet Printer
Ink cartridges
The symtoms of a dried out cartridge is white lines through the printed letters.
I've seen brand new dried out cartridges.
Aug 08, 2008 | HP DeskJet 882c InkJet Printer
How to remove the top of the 952c to get to the ink reservoir.
HP 952c = Deskjet Printer
Like ALL HP deskjets of this design:
Turn Printer ON (allow for test cycle), then lift top hinged panel.
Print cartridges will be parked in protected area to the right.
When top panel is lifted, they will move out for easy access.
They will NOT move out if printer is OFF.
So Please turn ON as first step.
Best to install new cartridges as opposed to cleaning.
If cleaning, utilize software option for clogged cartridges.
If they are leaking, replace them with new cartridges.
All this is available on HP web site.
Aug 04, 2008 | HP DeskJet 952c InkJet Printer
HP DeskJet 952c InkJet Printer Logo
60 people viewed this question
Seeker5211
Seeker5211
mukhtar21 shaikh
mukhtar21 shaikh
