Question about Canon PowerShot S2 IS Digital Camera
Flash Problem The flash does not fire. Sometimes even when I press the flash button what can I do?
    Sergeant:
  • 255 Answers
Using the flash When shooting with the built-in flash, open the flash manually. The flash does not pop-up automatically. The flash will not fire if it is closed. The flash will work when it is opened up. When the flash is open, the (flash on) icon or (automatic) icon will appear on the LCD monitor (or in the viewfinder). Flash on: The flash fires in every shot. Automatic: The flash fires automatically. Press the (flash) button to switch between the and flash modes while the flash is open. In some shooting modes, the flash mode does not switch even if the flash button is pressed. Please refer to Functions Available in Each Shooting Mode in the Camera User Guide provided with your camera for more information. When you are not using the flash, close it manually. When the flash is closed, the flash will not fire and the icon appears on the LCD monitor (or in the viewfinder).
Posted on Aug 31, 2005
4 Suggested Answers
SOURCE:
hsanfor
  • 71 Answers
SOURCE: my canon xsi on camera flash won't pop upeven after i press flash
I would suggest taking it to a technician to have it repaired. It does not seem like something you should try to fix yourself.
Posted on Jun 20, 2009
  • 4 Answers
SOURCE: camera does not fire external flash
Also be certain that the flash is screwed onto the shoe as tightly as possible.
Posted on Feb 28, 2009
  • 23 Answers
SOURCE: flash not firing properly
Could be the metering mode you are in. Could be the subject is too far away. Could be ISO is set wrong. Could be the lens aperture can't open up enough. Could be the exposure compensation isn't set correctly. Could be FE Lock is still on and the composition has changed. Does the <flash> icon continue to blink? Then you are too far away.
Posted on Dec 06, 2008
Canon pc1251 flash won't fire
If it even won't fire in a manual mode, when it is dark and you did press the flash button, it could be defect. Be aware that in some Basic Zone modes the flash won't fire. If you did put it in sport and in a few other modes it won't work. So try it in dark and don't forget to switch the flash on.
Dec 10, 2014 | Canon Cameras
How do I turn flash on and off?
The multi selector is the round control on the rear of the camera with the OK button in its center.
The flash mode button is the top button on the selector, it has a lightning flash icon.
Press the flash mode button on the multi selector.
Highlight the desired mode and press the center of the multi selector.
The flash modes are:
AUTO; Flash fires automatically when lighting is poor.
AUTO WITH RED-EYE REDUCTION; Reduces "red eye" in portraits.
OFF; Flash will not fire even when lighting is poor.
FILL FLASH; Flash fires whenever picture is taken. Use to "fill-in" (illuminate) shadows and back-lit subjects.
SLOW SYNC; Flash illuminates mainsubject; slow shutter speeds are used to capture background at night or under dim light
The selected flash mode icon appears at the top of the monitor.
Oct 22, 2014 | Nikon COOLPIX L3 Digital Camera
THE FLASH ON MY NIKON P500 IS NOT WORKING WHEN IT IS RAISED AND I SELECT FLASH ON IT SAYS RAISE FLASH HOW I CAN THIS
To be sure something could be wrong with your camera flash, please put the camera in automatic and try making a picture in a dark situation. The flash should be pop up and fire, when the camera is in focus, and you press the shutter button fully.
Perhaps you know there are situations, the flash does not fire, even when you open it yourself. In the P, S, A and M, it only can fire if the ISO setting is on auto. Some scenes you can select, also won't fire the flash, even when you put it up.
there are more things, to shooting with flash than jute putting it up.
But when you try it like I said above you schools see a flash icon on the display for a few seconds and the flash should fire. If not, I'm afraid you must contact the Nikon service centre close by you.
success.
Feb 01, 2014 | Nikon COOLPIX Cameras
Sony a200 Flash pops up then flashes as if its shorting and I am unable to take any photos.
Are you shooting in low light? Sometimes the flash will fire multiple short bursts to aid in focusing. If the camera is not in focus, then depending upon your setting it will not fire.
Oct 31, 2012 | Sony Alpha DSLR-A200 Digital Camera
My flash stopped working on my nikon coolpix L110..
The Nikon Coolpix is a compact digital camera that is well-suited for amateur to semi-professional photographers. Occasionally, some issues with the built-in flash can occur. If the hardware is damaged, the camera must be taken in for repairs. More often, problems occur because of obstructions or issues with the camera's settings and are easily repairable. Follow the troubleshooting guide to fix the built-in flash.
Instructions:
1.Ensure the Nikon Coolpix digital camera battery is fully charged.
2.Wait several seconds before pressing the shutter-release button if the "Flash Ready" indicator light is flashing red. Press the "Flash Mode" button once or twice to change the flash settings from "Off" to "On" or "Auto" if the "Flash Ready" indicator light is off.
3.Ensure there are no obstructions, like your finger or the camera strap, that are preventing the flash from firing if an error message appears on the display screen and the flash is not firing when the flash mode is set to automatic.
4.Press the flash back into the camera after every photo to ensure the flash always fires in "Auto" mode instead of just in low illumination settings. Press the flash back into the camera to turn off the flash in "Manual" mode; otherwise the flash will continually fire.
5.Change the auto focus setting from "Infinity" to "Auto," "Macro Closeup" or "Self-Timer" by pressing the "Focus Mode" button once, twice or three times to automatically turn the flash back on.
6.Use only Nikon external flash accessories to avoid damage to the built-in flash and camera circuits.
I hope you find it very helpful. Thanks.
Aug 25, 2011 | Nikon COOLPIX L4 Digital Camera
The flash will not go on on my camera, even when i put it on auto and i press the flash button on the main screen it just says "press and hold the disp button to deactivate silent mode" and will not turn...
you need to deactivate the slient mode at the menu.once slient mode is activated the flash will not fire.i think u might had accidently activate the slient mode
Sep 23, 2010 | FUJIFILM FinePix XP10 XP11 Digital Camera
Kodak es c875 flash problem
Try to do this press the flash button then chose the Fill Flash so if you take picture it will always fire the flash., May be your using the Auto Flash.
If your flash will not fire using the Fill Flash setup it means the Flash is defective call tech support toll free 1 800 235 6325 ext 12
You may also see the flash setting if you press the menu button and under menu button look for setup
Nov 15, 2009 | Kodak EasyShare C875 Digital Camera
The flash pops up, but it doesn't flash
It is normal that when you press the shutter button half the flash won't fire because you're focusing on a subject upon pressing the shutter half way
It's just like you are locking a subject upon pressing the shutter half way
Aug 23, 2009 | Canon PowerShot S1 IS Digital Camera
Flash doesn't fire
Should fire from test button. If not flash tube is blown.
Jul 08, 2017 | Digital Concepts 952AF for Pentax Flash
Red dye reduction
You can find your manual here....www.olympus.co.jp/en/support/imsg/digicamera/download/manual/zoom/man_c725uz_e.pdf
You find how to disable red eye function on page no: 63 in that manual.
For quick reference i am giving the details briefly,
The flash modes are as follows:
AUTO FLASH:
Automatically fires in low-light and backlight conditions.
RED EYE REDUCTION FLASH:
This mode significantly reduces
the phenomenon of “red-eye”
by emitting about 10 preflashes
before firing the regular
flash. This mode works the
same as the auto-flash except
for the pre-flashes.
To change between flash modes:
1 Press the (flash) switch.
● The flash pops up.
2 Press the / (flash mode) button
repeatedly until the desired flash mode
indication appears.
● The flash mode changes ,
● If / is not pressed within 2 seconds after the selection screen is
displayed, the selection screen disappears.
● To de-activate the flash (Flash Off mode ), push the flash back into the
camera.
3 Press the shutter button halfway.
● When the flash is ready to fire, the
(flash stand-by) mark lights.
4 Press the shutter button all the way.
● The flash fires.
Hope my info solves your problem,
Thanx for using fixya,
Good Luck.
Sep 30, 2008 | Olympus Camedia C-725 Digital Camera
Canon PowerShot S2 IS Digital Camera Logo
2,163 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Doberman
sathish kumar
sathish kumar
Are you a Canon Camera Expert? Answer questions, earn points and help others
